root/radiance/ray/src/common/header.c
Revision: 2.2
Committed: Thu Feb 20 11:40:36 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.1: +19 -2 lines
added quoting of arguments containing spaces to printargs()
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * header.c - routines for reading and writing information headers.
9 *
10 * 8/19/88
11 *
12 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
13 * isformat(s) returns true if s is of the form "FORMAT=*"
14 * formatval(r,s) copy the format value in s to r
15 * fputformat(s,fp) write "FORMAT=%s" to fp
16 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
17 * checkheader(i,p,o) check header format from i against p and copy to o
18 *
19 * To copy header from input to output, use getheader(fin, fputs, fout)
20 */
21
22 #include <stdio.h>
23 #include <ctype.h>
24
25 #define MAXLINE 512
26
27 #ifndef BSD
28 #define index strchr
29 #endif
30
31 extern char *index();
32
33 char FMTSTR[] = "FORMAT=";
34 int FMTSTRL = 7;
35
36
37 printargs(ac, av, fp) /* print arguments to a file */
38 int ac;
39 char **av;
40 register FILE *fp;
41 {
42 int quote;
43
44 while (ac-- > 0) {
45 if (index(*av, ' ') != NULL) { /* quote it */
46 if (index(*av, '\'') != NULL)
47 quote = '"';
48 else
49 quote = '\'';
50 putc(quote, fp);
51 fputs(*av++, fp);
52 putc(quote, fp);
53 } else
54 fputs(*av++, fp);
55 putc(' ', fp);
56 }
57 putc('\n', fp);
58 }
59
60
61 isformat(s) /* is line a format line? */
62 char *s;
63 {
64 return(!strncmp(s,FMTSTR,FMTSTRL));
65 }
66
67
68 formatval(r, s) /* return format value */
69 register char *r;
70 register char *s;
71 {
72 s += FMTSTRL;
73 while (isspace(*s)) s++;
74 if (!*s) { *r = '\0'; return; }
75 while(*s) *r++ = *s++;
76 while (isspace(r[-1])) r--;
77 *r = '\0';
78 }
79
80
81 fputformat(s, fp) /* put out a format value */
82 char *s;
83 FILE *fp;
84 {
85 fputs(FMTSTR, fp);
86 fputs(s, fp);
87 putc('\n', fp);
88 }
89
90
91 getheader(fp, f, p) /* get header from file */
92 FILE *fp;
93 int (*f)();
94 char *p;
95 {
96 char buf[MAXLINE];
97
98 for ( ; ; ) {
99 buf[MAXLINE-2] = '\n';
100 if (fgets(buf, sizeof(buf), fp) == NULL)
101 return(-1);
102 if (buf[0] == '\n')
103 return(0);
104 if (buf[MAXLINE-2] != '\n') {
105 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
106 buf[MAXLINE-2] = '\0';
107 }
108 if (f != NULL)
109 (*f)(buf, p);
110 }
111 }
112
113
114 struct check {
115 FILE *fp;
116 char fs[64];
117 };
118
119
120 static
121 mycheck(s, cp) /* check a header line for format info. */
122 char *s;
123 register struct check *cp;
124 {
125 if (!strncmp(s,FMTSTR,FMTSTRL))
126 formatval(cp->fs, s);
127 else if (cp->fp != NULL) /* don't copy format info. */
128 fputs(s, cp->fp);
129 }
130
131
132 /*
133 * Copymatch(pat,str) checks pat for wildcards, and
134 * copies str into pat if there is a match (returning true).
135 */
136
137 #ifdef COPYMATCH
138 copymatch(pat, str)
139 char *pat, *str;
140 {
141 int docopy = 0;
142 register char *p = pat, *s = str;
143
144 do {
145 switch (*p) {
146 case '?': /* match any character */
147 if (!*s++)
148 return(0);
149 docopy++;
150 break;
151 case '*': /* match any string */
152 while (p[1] == '*') p++;
153 do
154 if ( (p[1]=='?' || p[1]==*s)
155 && copymatch(p+1,s) ) {
156 strcpy(pat, str);
157 return(1);
158 }
159 while (*s++);
160 return(0);
161 case '\\': /* literal next */
162 p++;
163 /* fall through */
164 default: /* normal character */
165 if (*p != *s)
166 return(0);
167 s++;
168 break;
169 }
170 } while (*p++);
171 if (docopy)
172 strcpy(pat, str);
173 return(1);
174 }
175 #else
176 #define copymatch(pat, s) (!strcmp(pat, s))
177 #endif
178
179
180 /*
181 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
182 * matches the specification in fmt, 0 if no input format was found,
183 * and -1 if the input format does not match or there is an
184 * error reading the header. If fmt is empty, then -1 is returned
185 * if any input format is found (or there is an error), and 0 otherwise.
186 * If fmt contains any '*' or '?' characters, then checkheader
187 * does wildcard expansion and copies a matching result into fmt.
188 * Be sure that fmt is big enough to hold the match in such cases!
189 * The input header (minus any format lines) is copied to fout
190 * if fout is not NULL.
191 */
192
193 checkheader(fin, fmt, fout)
194 FILE *fin;
195 char *fmt;
196 FILE *fout;
197 {
198 struct check cdat;
199
200 cdat.fp = fout;
201 cdat.fs[0] = '\0';
202 if (getheader(fin, mycheck, &cdat) < 0)
203 return(-1);
204 if (cdat.fs[0] != '\0')
205 return(copymatch(fmt, cdat.fs) ? 1 : -1);
206 return(0);
207 }
