1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* header.c - routines for reading and writing information headers. |
6 |
7 |
* Externals declared in resolu.h |
8 |
9 |
* newheader(t,fp) start new information header identified by string t |
10 |
* isheadid(s) returns true if s is a header id line |
11 |
* headidval(r,s) copy header identifier value in s to r |
12 |
* dateval(t,s) get capture date value |
13 |
* isdate(s) returns true if s is a date line |
14 |
* fputdate(t,fp) put out the given capture date and time |
15 |
* fputnow(fp) put out the current date and time |
16 |
* printargs(ac,av,fp) print an argument list to fp, followed by '\n' |
17 |
* isformat(s) returns true if s is of the form "FORMAT=*" |
18 |
* formatval(r,s) copy the format value in s to r |
19 |
* fputformat(s,fp) write "FORMAT=%s" to fp |
20 |
* getheader(fp,f,p) read header from fp, calling f(s,p) on each line |
21 |
* globmatch(pat, str) check for glob match of str against pat |
22 |
* checkheader(i,p,o) check header format from i against p and copy to o |
23 |
24 |
* To copy header from input to output, use getheader(fin, fputs, fout) |
25 |
26 |
27 |
#include "copyright.h" |
28 |
29 |
#include <stdio.h> |
30 |
#include <string.h> |
31 |
#include <time.h> |
32 |
#include <ctype.h> |
33 |
34 |
#define MAXLINE 512 |
35 |
36 |
#ifndef BSD |
37 |
#define index strchr |
38 |
#endif |
39 |
40 |
extern char *index(); |
41 |
42 |
char HDRSTR[] = "#?"; /* information header magic number */ |
43 |
44 |
char FMTSTR[] = "FORMAT="; /* format identifier */ |
45 |
46 |
char TMSTR[] = "CAPDATE="; /* capture date identifier */ |
47 |
48 |
static int mycheck(); |
49 |
50 |
51 |
void |
52 |
newheader(s, fp) /* identifying line of information header */ |
53 |
char *s; |
54 |
register FILE *fp; |
55 |
56 |
fputs(HDRSTR, fp); |
57 |
fputs(s, fp); |
58 |
putc('\n', fp); |
59 |
60 |
61 |
62 |
int |
63 |
headidval(r,s) /* get header id (return true if is id) */ |
64 |
register char *r, *s; |
65 |
66 |
register char *cp = HDRSTR; |
67 |
68 |
while (*cp) if (*cp++ != *s++) return(0); |
69 |
if (r == NULL) return(1); |
70 |
while (*s && !isspace(*s)) *r++ = *s++; |
71 |
*r = '\0'; |
72 |
return(1); |
73 |
74 |
75 |
76 |
int |
77 |
isheadid(s) /* check to see if line is header id */ |
78 |
char *s; |
79 |
80 |
return(headidval(NULL, s)); |
81 |
82 |
83 |
84 |
int |
85 |
dateval(tloc, s) /* get capture date value */ |
86 |
time_t *tloc; |
87 |
char *s; |
88 |
89 |
struct tm tms; |
90 |
register char *cp = TMSTR; |
91 |
92 |
93 |
while (isspace(*s)) s++; |
94 |
if (!*s) return(0); |
95 |
if (sscanf(s, "%d:%d:%d %d:%d:%d", |
96 |
&tms.tm_year, &tms.tm_mon, &tms.tm_mday, |
97 |
&tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) |
98 |
return(0); |
99 |
if (tloc == NULL) |
100 |
return(1); |
101 |
tms.tm_mon--; |
102 |
tms.tm_year -= 1900; |
103 |
tms.tm_isdst = -1; /* ask mktime() to figure out DST */ |
104 |
*tloc = mktime(&tms); |
105 |
return(1); |
106 |
107 |
108 |
109 |
int |
110 |
isdate(s) /* is the given line a capture date? */ |
111 |
char *s; |
112 |
113 |
return(dateval(NULL, s)); |
114 |
115 |
116 |
117 |
void |
118 |
fputdate(tv, fp) /* write out the given time value */ |
119 |
time_t tv; |
120 |
FILE *fp; |
121 |
122 |
struct tm *tm = localtime(&tv); |
123 |
if (tm == NULL) |
124 |
return; |
125 |
fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR, |
126 |
tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday, |
127 |
tm->tm_hour, tm->tm_min, tm->tm_sec); |
128 |
129 |
130 |
131 |
void |
132 |
fputnow(fp) /* write out the current time */ |
133 |
FILE *fp; |
134 |
135 |
time_t tv; |
136 |
time(&tv); |
137 |
fputdate(tv, fp); |
138 |
139 |
140 |
141 |
void |
142 |
printargs(ac, av, fp) /* print arguments to a file */ |
143 |
int ac; |
144 |
char **av; |
145 |
FILE *fp; |
146 |
147 |
int quote; |
148 |
149 |
while (ac-- > 0) { |
150 |
fputword(*av++, fp); |
151 |
fputc(ac ? ' ' : '\n', fp); |
152 |
153 |
154 |
155 |
156 |
int |
157 |
formatval(r, s) /* get format value (return true if format) */ |
158 |
register char *r; |
159 |
register char *s; |
160 |
161 |
register char *cp = FMTSTR; |
162 |
163 |
164 |
165 |
166 |
167 |
do |
168 |
*r++ = *s++; |
169 |
while(*s && !isspace(*s)); |
170 |
*r = '\0'; |
171 |
return(1); |
172 |
173 |
174 |
175 |
int |
176 |
isformat(s) /* is line a format line? */ |
177 |
char *s; |
178 |
179 |
return(formatval(NULL, s)); |
180 |
181 |
182 |
183 |
void |
184 |
fputformat(s, fp) /* put out a format value */ |
185 |
char *s; |
186 |
FILE *fp; |
187 |
188 |
fputs(FMTSTR, fp); |
189 |
fputs(s, fp); |
190 |
putc('\n', fp); |
191 |
192 |
193 |
194 |
int |
195 |
getheader(fp, f, p) /* get header from file */ |
196 |
FILE *fp; |
197 |
int (*f)(); |
198 |
char *p; |
199 |
200 |
char buf[MAXLINE]; |
201 |
202 |
for ( ; ; ) { |
203 |
buf[MAXLINE-2] = '\n'; |
204 |
if (fgets(buf, MAXLINE, fp) == NULL) |
205 |
return(-1); |
206 |
if (buf[0] == '\n') |
207 |
return(0); |
208 |
#ifdef MSDOS |
209 |
if (buf[0] == '\r' && buf[1] == '\n') |
210 |
return(0); |
211 |
#endif |
212 |
if (buf[MAXLINE-2] != '\n') { |
213 |
ungetc(buf[MAXLINE-2], fp); /* prevent false end */ |
214 |
buf[MAXLINE-2] = '\0'; |
215 |
216 |
if (f != NULL && (*f)(buf, p) < 0) |
217 |
return(-1); |
218 |
219 |
220 |
221 |
222 |
struct check { |
223 |
FILE *fp; |
224 |
char fs[64]; |
225 |
226 |
227 |
228 |
static int |
229 |
mycheck(s, cp) /* check a header line for format info. */ |
230 |
char *s; |
231 |
register struct check *cp; |
232 |
233 |
if (!formatval(cp->fs, s) && cp->fp != NULL) |
234 |
fputs(s, cp->fp); |
235 |
return(0); |
236 |
237 |
238 |
239 |
int |
240 |
globmatch(p, s) /* check for match of s against pattern p */ |
241 |
register char *p, *s; |
242 |
243 |
int setmatch; |
244 |
245 |
do { |
246 |
switch (*p) { |
247 |
case '?': /* match any character */ |
248 |
if (!*s++) |
249 |
return(0); |
250 |
break; |
251 |
case '*': /* match any string */ |
252 |
while (p[1] == '*') p++; |
253 |
do |
254 |
if ( (p[1]=='?' || p[1]==*s) && |
255 |
globmatch(p+1,s) ) |
256 |
return(1); |
257 |
while (*s++); |
258 |
return(0); |
259 |
case '[': /* character set */ |
260 |
setmatch = *s == *++p; |
261 |
if (!*p) |
262 |
return(0); |
263 |
while (*++p != ']') { |
264 |
if (!*p) |
265 |
return(0); |
266 |
if (*p == '-') { |
267 |
setmatch += p[-1] <= *s && *s <= p[1]; |
268 |
if (!*++p) |
269 |
break; |
270 |
} else |
271 |
setmatch += *p == *s; |
272 |
273 |
if (!setmatch) |
274 |
return(0); |
275 |
s++; |
276 |
break; |
277 |
case '\\': /* literal next */ |
278 |
p++; |
279 |
/* fall through */ |
280 |
default: /* normal character */ |
281 |
if (*p != *s) |
282 |
return(0); |
283 |
s++; |
284 |
break; |
285 |
286 |
} while (*p++); |
287 |
return(1); |
288 |
289 |
290 |
291 |
292 |
* Checkheader(fin,fmt,fout) returns a value of 1 if the input format |
293 |
* matches the specification in fmt, 0 if no input format was found, |
294 |
* and -1 if the input format does not match or there is an |
295 |
* error reading the header. If fmt is empty, then -1 is returned |
296 |
* if any input format is found (or there is an error), and 0 otherwise. |
297 |
* If fmt contains any '*' or '?' characters, then checkheader |
298 |
* does wildcard expansion and copies a matching result into fmt. |
299 |
* Be sure that fmt is big enough to hold the match in such cases, |
300 |
* and that it is not a static, read-only string! |
301 |
* The input header (minus any format lines) is copied to fout |
302 |
* if fout is not NULL. |
303 |
304 |
305 |
int |
306 |
checkheader(fin, fmt, fout) |
307 |
FILE *fin; |
308 |
char *fmt; |
309 |
FILE *fout; |
310 |
311 |
struct check cdat; |
312 |
register char *cp; |
313 |
314 |
cdat.fp = fout; |
315 |
cdat.fs[0] = '\0'; |
316 |
if (getheader(fin, mycheck, &cdat) < 0) |
317 |
return(-1); |
318 |
if (!cdat.fs[0]) |
319 |
return(0); |
320 |
for (cp = fmt; *cp; cp++) /* check for globbing */ |
321 |
if (*cp == '?' | *cp == '*') |
322 |
if (globmatch(fmt, cdat.fs)) { |
323 |
strcpy(fmt, cdat.fs); |
324 |
return(1); |
325 |
} else |
326 |
return(-1); |
327 |
return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */ |
328 |
