root/Development/ray/src/common/header.c
Revision: 2.12
Committed: Tue Feb 25 02:47:21 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.11: +1 -56 lines
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * isheadid(s) returns true if s is a header id line
11 * headidval(r,s) copy header identifier value in s to r
12 * dateval(t,s) get capture date value
13 * isdate(s) returns true if s is a date line
14 * fputdate(t,fp) put out the given capture date and time
15 * fputnow(fp) put out the current date and time
16 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
17 * isformat(s) returns true if s is of the form "FORMAT=*"
18 * formatval(r,s) copy the format value in s to r
19 * fputformat(s,fp) write "FORMAT=%s" to fp
20 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
21 * globmatch(pat, str) check for glob match of str against pat
22 * checkheader(i,p,o) check header format from i against p and copy to o
23 *
24 * To copy header from input to output, use getheader(fin, fputs, fout)
25 */
26
27 #include "copyright.h"
28
29 #include <stdio.h>
30 #include <string.h>
31 #include <time.h>
32 #include <ctype.h>
33
34 #define MAXLINE 512
35
36 #ifndef BSD
37 #define index strchr
38 #endif
39
40 extern char *index();
41
42 char HDRSTR[] = "#?"; /* information header magic number */
43
44 char FMTSTR[] = "FORMAT="; /* format identifier */
45
46 char TMSTR[] = "CAPDATE="; /* capture date identifier */
47
48 static int mycheck();
49
50
51 void
52 newheader(s, fp) /* identifying line of information header */
53 char *s;
54 register FILE *fp;
55 {
56 fputs(HDRSTR, fp);
57 fputs(s, fp);
58 putc('\n', fp);
59 }
60
61
62 int
63 headidval(r,s) /* get header id (return true if is id) */
64 register char *r, *s;
65 {
66 register char *cp = HDRSTR;
67
68 while (*cp) if (*cp++ != *s++) return(0);
69 if (r == NULL) return(1);
70 while (*s && !isspace(*s)) *r++ = *s++;
71 *r = '\0';
72 return(1);
73 }
74
75
76 int
77 isheadid(s) /* check to see if line is header id */
78 char *s;
79 {
80 return(headidval(NULL, s));
81 }
82
83
84 int
85 dateval(tloc, s) /* get capture date value */
86 time_t *tloc;
87 char *s;
88 {
89 struct tm tms;
90 register char *cp = TMSTR;
91
92 while (*cp) if (*cp++ != *s++) return(0);
93 while (isspace(*s)) s++;
94 if (!*s) return(0);
95 if (sscanf(s, "%d:%d:%d %d:%d:%d",
96 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
97 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
98 return(0);
99 if (tloc == NULL)
100 return(1);
101 tms.tm_mon--;
102 tms.tm_year -= 1900;
103 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
104 *tloc = mktime(&tms);
105 return(1);
106 }
107
108
109 int
110 isdate(s) /* is the given line a capture date? */
111 char *s;
112 {
113 return(dateval(NULL, s));
114 }
115
116
117 void
118 fputdate(tv, fp) /* write out the given time value */
119 time_t tv;
120 FILE *fp;
121 {
122 struct tm *tm = localtime(&tv);
123 if (tm == NULL)
124 return;
125 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
126 tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday,
127 tm->tm_hour, tm->tm_min, tm->tm_sec);
128 }
129
130
131 void
132 fputnow(fp) /* write out the current time */
133 FILE *fp;
134 {
135 time_t tv;
136 time(&tv);
137 fputdate(tv, fp);
138 }
139
140
141 void
142 printargs(ac, av, fp) /* print arguments to a file */
143 int ac;
144 char **av;
145 FILE *fp;
146 {
147 int quote;
148
149 while (ac-- > 0) {
150 fputword(*av++, fp);
151 fputc(ac ? ' ' : '\n', fp);
152 }
153 }
154
155
156 int
157 formatval(r, s) /* get format value (return true if format) */
158 register char *r;
159 register char *s;
160 {
161 register char *cp = FMTSTR;
162
163 while (*cp) if (*cp++ != *s++) return(0);
164 while (isspace(*s)) s++;
165 if (!*s) return(0);
166 if (r == NULL) return(1);
167 do
168 *r++ = *s++;
169 while(*s && !isspace(*s));
170 *r = '\0';
171 return(1);
172 }
173
174
175 int
176 isformat(s) /* is line a format line? */
177 char *s;
178 {
179 return(formatval(NULL, s));
180 }
181
182
183 void
184 fputformat(s, fp) /* put out a format value */
185 char *s;
186 FILE *fp;
187 {
188 fputs(FMTSTR, fp);
189 fputs(s, fp);
190 putc('\n', fp);
191 }
192
193
194 int
195 getheader(fp, f, p) /* get header from file */
196 FILE *fp;
197 int (*f)();
198 char *p;
199 {
200 char buf[MAXLINE];
201
202 for ( ; ; ) {
203 buf[MAXLINE-2] = '\n';
204 if (fgets(buf, MAXLINE, fp) == NULL)
205 return(-1);
206 if (buf[0] == '\n')
207 return(0);
208 #ifdef MSDOS
209 if (buf[0] == '\r' && buf[1] == '\n')
210 return(0);
211 #endif
212 if (buf[MAXLINE-2] != '\n') {
213 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
214 buf[MAXLINE-2] = '\0';
215 }
216 if (f != NULL && (*f)(buf, p) < 0)
217 return(-1);
218 }
219 }
220
221
222 struct check {
223 FILE *fp;
224 char fs[64];
225 };
226
227
228 static int
229 mycheck(s, cp) /* check a header line for format info. */
230 char *s;
231 register struct check *cp;
232 {
233 if (!formatval(cp->fs, s) && cp->fp != NULL)
234 fputs(s, cp->fp);
235 return(0);
236 }
237
238
239 int
240 globmatch(p, s) /* check for match of s against pattern p */
241 register char *p, *s;
242 {
243 int setmatch;
244
245 do {
246 switch (*p) {
247 case '?': /* match any character */
248 if (!*s++)
249 return(0);
250 break;
251 case '*': /* match any string */
252 while (p[1] == '*') p++;
253 do
254 if ( (p[1]=='?' || p[1]==*s) &&
255 globmatch(p+1,s) )
256 return(1);
257 while (*s++);
258 return(0);
259 case '[': /* character set */
260 setmatch = *s == *++p;
261 if (!*p)
262 return(0);
263 while (*++p != ']') {
264 if (!*p)
265 return(0);
266 if (*p == '-') {
267 setmatch += p[-1] <= *s && *s <= p[1];
268 if (!*++p)
269 break;
270 } else
271 setmatch += *p == *s;
272 }
273 if (!setmatch)
274 return(0);
275 s++;
276 break;
277 case '\\': /* literal next */
278 p++;
279 /* fall through */
280 default: /* normal character */
281 if (*p != *s)
282 return(0);
283 s++;
284 break;
285 }
286 } while (*p++);
287 return(1);
288 }
289
290
291 /*
292 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
293 * matches the specification in fmt, 0 if no input format was found,
294 * and -1 if the input format does not match or there is an
295 * error reading the header. If fmt is empty, then -1 is returned
296 * if any input format is found (or there is an error), and 0 otherwise.
297 * If fmt contains any '*' or '?' characters, then checkheader
298 * does wildcard expansion and copies a matching result into fmt.
299 * Be sure that fmt is big enough to hold the match in such cases,
300 * and that it is not a static, read-only string!
301 * The input header (minus any format lines) is copied to fout
302 * if fout is not NULL.
303 */
304
305 int
306 checkheader(fin, fmt, fout)
307 FILE *fin;
308 char *fmt;
309 FILE *fout;
310 {
311 struct check cdat;
312 register char *cp;
313
314 cdat.fp = fout;
315 cdat.fs[0] = '\0';
316 if (getheader(fin, mycheck, &cdat) < 0)
317 return(-1);
318 if (!cdat.fs[0])
319 return(0);
320 for (cp = fmt; *cp; cp++) /* check for globbing */
321 if (*cp == '?' | *cp == '*')
322 if (globmatch(fmt, cdat.fs)) {
323 strcpy(fmt, cdat.fs);
324 return(1);
325 } else
326 return(-1);
327 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
328 }
