--- ray/src/common/header.c 1989/02/02 10:34:33 1.1 +++ ray/src/common/header.c 1996/03/12 11:29:16 2.7 @@ -1,4 +1,4 @@ -/* Copyright (c) 1988 Regents of the University of California */ +/* Copyright (c) 1994 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -8,61 +8,243 @@ static char SCCSid[] = "$SunId$ LBL"; * header.c - routines for reading and writing information headers. * * 8/19/88 + * + * newheader(t,fp) start new information header identified by string t + * isheadid(s) returns true if s is a header id line + * headidval(r,s) copy header identifier value in s to r + * printargs(ac,av,fp) print an argument list to fp, followed by '\n' + * isformat(s) returns true if s is of the form "FORMAT=*" + * formatval(r,s) copy the format value in s to r + * fputformat(s,fp) write "FORMAT=%s" to fp + * getheader(fp,f,p) read header from fp, calling f(s,p) on each line + * globmatch(pat, str) check for glob match of str against pat + * checkheader(i,p,o) check header format from i against p and copy to o + * + * To copy header from input to output, use getheader(fin, fputs, fout) */ #include +#include +#define MAXLINE 512 +#ifndef BSD +#define index strchr +#endif + +extern char *index(); + +char HDRSTR[] = "#?"; /* information header magic number */ + +char FMTSTR[] = "FORMAT="; /* format identifier */ + + +newheader(s, fp) /* identifying line of information header */ +char *s; +register FILE *fp; +{ + fputs(HDRSTR, fp); + fputs(s, fp); + putc('\n', fp); +} + + +int +headidval(r,s) /* get header id (return true if is id) */ +register char *r, *s; +{ + register char *cp = HDRSTR; + + while (*cp) if (*cp++ != *s++) return(0); + if (r == NULL) return(1); + while (*s) *r++ = *s++; + *r = '\0'; + return(1); +} + + +int +isheadid(s) /* check to see if line is header id */ +char *s; +{ + return(headidval(NULL, s)); +} + + printargs(ac, av, fp) /* print arguments to a file */ int ac; char **av; -FILE *fp; +register FILE *fp; { + int quote; + while (ac-- > 0) { - fputs(*av++, fp); + if (index(*av, ' ') != NULL) { /* quote it */ + if (index(*av, '\'') != NULL) + quote = '"'; + else + quote = '\''; + putc(quote, fp); + fputs(*av++, fp); + putc(quote, fp); + } else + fputs(*av++, fp); putc(' ', fp); } putc('\n', fp); } -#define MAXLINE 512 +int +formatval(r, s) /* get format value (return true if format) */ +register char *r; +register char *s; +{ + register char *cp = FMTSTR; -getheader(fp, f) /* get header from file */ + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (r == NULL) return(1); + do + *r++ = *s++; + while(*s && !isspace(*s)); + *r = '\0'; + return(1); +} + + +int +isformat(s) /* is line a format line? */ +char *s; +{ + return(formatval(NULL, s)); +} + + +fputformat(s, fp) /* put out a format value */ +char *s; FILE *fp; +{ + fputs(FMTSTR, fp); + fputs(s, fp); + putc('\n', fp); +} + + +int +getheader(fp, f, p) /* get header from file */ +FILE *fp; int (*f)(); +char *p; { char buf[MAXLINE]; for ( ; ; ) { buf[MAXLINE-2] = '\n'; - if (fgets(buf, sizeof(buf), fp) == NULL) + if (fgets(buf, MAXLINE, fp) == NULL) return(-1); if (buf[0] == '\n') return(0); +#ifdef MSDOS + if (buf[0] == '\r' && buf[1] == '\n') + return(0); +#endif if (buf[MAXLINE-2] != '\n') { ungetc(buf[MAXLINE-2], fp); /* prevent false end */ buf[MAXLINE-2] = '\0'; } if (f != NULL) - (*f)(buf); + (*f)(buf, p); } } -static FILE *outfp; +struct check { + FILE *fp; + char fs[64]; +}; + static -myputs(s) +mycheck(s, cp) /* check a header line for format info. */ char *s; +register struct check *cp; { - fputs(s, outfp); + if (!formatval(cp->fs, s) && cp->fp != NULL) + fputs(s, cp->fp); } -copyheader(fin, fout) /* copy file header */ -FILE *fin, *fout; +int +globmatch(pat, str) /* check for glob match of str against pat */ +char *pat, *str; { - outfp = fout; - return(getheader(fin, myputs)); + register char *p = pat, *s = str; + + do { + switch (*p) { + case '?': /* match any character */ + if (!*s++) + return(0); + break; + case '*': /* match any string */ + while (p[1] == '*') p++; + do + if ( (p[1]=='?' || p[1]==*s) && + globmatch(p+1,s) ) + return(1); + while (*s++); + return(0); + case '\\': /* literal next */ + p++; + /* fall through */ + default: /* normal character */ + if (*p != *s) + return(0); + s++; + break; + } + } while (*p++); + return(1); +} + + +/* + * Checkheader(fin,fmt,fout) returns a value of 1 if the input format + * matches the specification in fmt, 0 if no input format was found, + * and -1 if the input format does not match or there is an + * error reading the header. If fmt is empty, then -1 is returned + * if any input format is found (or there is an error), and 0 otherwise. + * If fmt contains any '*' or '?' characters, then checkheader + * does wildcard expansion and copies a matching result into fmt. + * Be sure that fmt is big enough to hold the match in such cases, + * and that it is not a static, read-only string! + * The input header (minus any format lines) is copied to fout + * if fout is not NULL. + */ + +int +checkheader(fin, fmt, fout) +FILE *fin; +char *fmt; +FILE *fout; +{ + struct check cdat; + register char *cp; + + cdat.fp = fout; + cdat.fs[0] = '\0'; + if (getheader(fin, mycheck, &cdat) < 0) + return(-1); + if (!cdat.fs[0]) + return(0); + for (cp = fmt; *cp; cp++) /* check for globbing */ + if (*cp == '?' | *cp == '*') + if (globmatch(fmt, cdat.fs)) { + strcpy(fmt, cdat.fs); + return(1); + } else + return(-1); + return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */ }
