--- ray/src/common/header.c 1995/10/16 10:53:46 2.6 +++ ray/src/common/header.c 1996/03/12 11:29:16 2.7 @@ -218,7 +218,8 @@ char *pat, *str; * if any input format is found (or there is an error), and 0 otherwise. * If fmt contains any '*' or '?' characters, then checkheader * does wildcard expansion and copies a matching result into fmt. - * Be sure that fmt is big enough to hold the match in such cases! + * Be sure that fmt is big enough to hold the match in such cases, + * and that it is not a static, read-only string! * The input header (minus any format lines) is copied to fout * if fout is not NULL. */ @@ -230,6 +231,7 @@ char *fmt; FILE *fout; { struct check cdat; + register char *cp; cdat.fp = fout; cdat.fs[0] = '\0'; @@ -237,9 +239,12 @@ FILE *fout; return(-1); if (!cdat.fs[0]) return(0); - if (globmatch(fmt, cdat.fs)) { - strcpy(fmt, cdat.fs); - return(1); - } - return(-1); + for (cp = fmt; *cp; cp++) /* check for globbing */ + if (*cp == '?' | *cp == '*') + if (globmatch(fmt, cdat.fs)) { + strcpy(fmt, cdat.fs); + return(1); + } else + return(-1); + return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */ }
