--- ray/src/common/header.c 1992/11/12 16:20:09 2.3 +++ ray/src/common/header.c 2017/05/07 16:14:19 2.30 @@ -1,86 +1,198 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: header.c,v 2.30 2017/05/07 16:14:19 greg Exp $"; #endif - /* * header.c - routines for reading and writing information headers. * - * 8/19/88 + * Externals declared in resolu.h * + * newheader(t,fp) start new information header identified by string t + * headidval(r,s) copy header identifier value in s to r + * dateval(t,s) get capture date value as UTC + * gmtval(t,s) get GMT as UTC + * fputdate(t,fp) put out the given UTC + * fputnow(fp) put out the current date and time * printargs(ac,av,fp) print an argument list to fp, followed by '\n' - * isformat(s) returns true if s is of the form "FORMAT=*" * formatval(r,s) copy the format value in s to r * fputformat(s,fp) write "FORMAT=%s" to fp * getheader(fp,f,p) read header from fp, calling f(s,p) on each line + * globmatch(pat, str) check for glob match of str against pat * checkheader(i,p,o) check header format from i against p and copy to o * * To copy header from input to output, use getheader(fin, fputs, fout) */ -#include +#include "copyright.h" + #include -#define MAXLINE 512 +#include "rtio.h" +#include "resolu.h" -#ifndef BSD -#define index strchr -#endif +#define MAXLINE 2048 -extern char *index(); +extern time_t timegm(struct tm *tm); -char FMTSTR[] = "FORMAT="; -int FMTSTRL = 7; +const char HDRSTR[] = "#?"; /* information header magic number */ +const char FMTSTR[] = "FORMAT="; /* format identifier */ -printargs(ac, av, fp) /* print arguments to a file */ -int ac; -char **av; -register FILE *fp; -{ - int quote; +const char TMSTR[] = "CAPDATE="; /* capture date identifier */ +const char GMTSTR[] = "GMT="; /* GMT identifier */ - while (ac-- > 0) { - if (index(*av, ' ') != NULL) { /* quote it */ - if (index(*av, '\'') != NULL) - quote = '"'; - else - quote = '\''; - putc(quote, fp); - fputs(*av++, fp); - putc(quote, fp); - } else - fputs(*av++, fp); - putc(' ', fp); - } +static gethfunc mycheck; + + +void +newheader( /* identifying line of information header */ + char *s, + FILE *fp +) +{ + fputs(HDRSTR, fp); + fputs(s, fp); putc('\n', fp); } -isformat(s) /* is line a format line? */ -char *s; +int +headidval( /* get header id (return true if is id) */ + char *r, + char *s +) { - return(!strncmp(s,FMTSTR,FMTSTRL)); + const char *cp = HDRSTR; + + while (*cp) if (*cp++ != *s++) return(0); + if (r == NULL) return(1); + while (*s && !isspace(*s)) *r++ = *s++; + *r = '\0'; + return(1); } -formatval(r, s) /* return format value */ -register char *r; -register char *s; +int +dateval( /* convert capture date line to UTC */ + time_t *tloc, + char *s +) { - s += FMTSTRL; + struct tm tms; + const char *cp = TMSTR; + + while (*cp) if (*cp++ != *s++) return(0); while (isspace(*s)) s++; - if (!*s) { *r = '\0'; return; } - while(*s) *r++ = *s++; - while (isspace(r[-1])) r--; + if (!*s) return(0); + if (sscanf(s, "%d:%d:%d %d:%d:%d", + &tms.tm_year, &tms.tm_mon, &tms.tm_mday, + &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) + return(0); + if (tloc == NULL) + return(1); + tms.tm_mon--; + tms.tm_year -= 1900; + tms.tm_isdst = -1; /* ask mktime() to figure out DST */ + *tloc = mktime(&tms); + return(1); +} + + +int +gmtval( /* convert GMT date line to UTC */ + time_t *tloc, + char *s +) +{ + struct tm tms; + const char *cp = GMTSTR; + + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (sscanf(s, "%d:%d:%d %d:%d:%d", + &tms.tm_year, &tms.tm_mon, &tms.tm_mday, + &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) + return(0); + if (tloc == NULL) + return(1); + tms.tm_mon--; + tms.tm_year -= 1900; + *tloc = timegm(&tms); + return(1); +} + + +void +fputdate( /* write out the given time value (local & GMT) */ + time_t tv, + FILE *fp +) +{ + struct tm *tms; + + tms = localtime(&tv); + if (tms != NULL) + fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR, + tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday, + tms->tm_hour, tms->tm_min, tms->tm_sec); + tms = gmtime(&tv); + if (tms != NULL) + fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR, + tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday, + tms->tm_hour, tms->tm_min, tms->tm_sec); +} + + +void +fputnow( /* write out the current time */ + FILE *fp +) +{ + time_t tv; + time(&tv); + fputdate(tv, fp); +} + + +void +printargs( /* print arguments to a file */ + int ac, + char **av, + FILE *fp +) +{ + while (ac-- > 0) { + fputword(*av++, fp); + fputc(ac ? ' ' : '\n', fp); + } +} + + +int +formatval( /* get format value (return true if format) */ + char *r, + char *s +) +{ + const char *cp = FMTSTR; + + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (r == NULL) return(1); + do + *r++ = *s++; + while (*s && !isspace(*s)); *r = '\0'; + return(1); } -fputformat(s, fp) /* put out a format value */ -char *s; -FILE *fp; +void +fputformat( /* put out a format value */ + char *s, + FILE *fp +) { fputs(FMTSTR, fp); fputs(s, fp); @@ -88,29 +200,30 @@ FILE *fp; } -getheader(fp, f, p) /* get header from file */ -FILE *fp; -int (*f)(); -char *p; +int +getheader( /* get header from file */ + FILE *fp, + gethfunc *f, + void *p +) { + int rtotal = 0; char buf[MAXLINE]; for ( ; ; ) { + int rval = 0; buf[MAXLINE-2] = '\n'; if (fgets(buf, MAXLINE, fp) == NULL) return(-1); - if (buf[0] == '\n') - return(0); -#ifdef MSDOS - if (buf[0] == '\r' && buf[1] == '\n') - return(0); -#endif + if (buf[buf[0]=='\r'] == '\n') + return(rtotal); if (buf[MAXLINE-2] != '\n') { ungetc(buf[MAXLINE-2], fp); /* prevent false end */ buf[MAXLINE-2] = '\0'; } - if (f != NULL) - (*f)(buf, p); + if (f != NULL && (rval = (*f)(buf, p)) < 0) + return(-1); + rtotal += rval; } } @@ -121,47 +234,60 @@ struct check { }; -static -mycheck(s, cp) /* check a header line for format info. */ -char *s; -register struct check *cp; +static int +mycheck( /* check a header line for format info. */ + char *s, + void *cp +) { - if (!strncmp(s,FMTSTR,FMTSTRL)) - formatval(cp->fs, s); - else if (cp->fp != NULL) /* don't copy format info. */ - fputs(s, cp->fp); + if (!formatval(((struct check*)cp)->fs, s) + && ((struct check*)cp)->fp != NULL) { + fputs(s, ((struct check*)cp)->fp); + } + return(0); } -/* - * Copymatch(pat,str) checks pat for wildcards, and - * copies str into pat if there is a match (returning true). - */ - -#ifdef COPYMATCH -copymatch(pat, str) -char *pat, *str; +int +globmatch( /* check for match of s against pattern p */ + char *p, + char *s +) { - int docopy = 0; - register char *p = pat, *s = str; + int setmatch; do { switch (*p) { case '?': /* match any character */ if (!*s++) return(0); - docopy++; break; case '*': /* match any string */ while (p[1] == '*') p++; do - if ( (p[1]=='?' || p[1]==*s) - && copymatch(p+1,s) ) { - strcpy(pat, str); + if ( (p[1]=='?') | (p[1]==*s) && + globmatch(p+1,s) ) return(1); - } while (*s++); return(0); + case '[': /* character set */ + setmatch = *s == *++p; + if (!*p) + return(0); + while (*++p != ']') { + if (!*p) + return(0); + if (*p == '-') { + setmatch += (p[-1] <= *s && *s <= p[1]); + if (!*++p) + break; + } else + setmatch += (*p == *s); + } + if (!setmatch) + return(0); + s++; + break; case '\\': /* literal next */ p++; /* fall through */ @@ -172,13 +298,8 @@ char *pat, *str; break; } } while (*p++); - if (docopy) - strcpy(pat, str); return(1); } -#else -#define copymatch(pat, s) (!strcmp(pat, s)) -#endif /* @@ -189,23 +310,35 @@ char *pat, *str; * if any input format is found (or there is an error), and 0 otherwise. * If fmt contains any '*' or '?' characters, then checkheader * does wildcard expansion and copies a matching result into fmt. - * Be sure that fmt is big enough to hold the match in such cases! + * Be sure that fmt is big enough to hold the match in such cases, + * and that it is not a static, read-only string! * The input header (minus any format lines) is copied to fout * if fout is not NULL. */ -checkheader(fin, fmt, fout) -FILE *fin; -char *fmt; -FILE *fout; +int +checkheader( + FILE *fin, + char *fmt, + FILE *fout +) { struct check cdat; + char *cp; cdat.fp = fout; cdat.fs[0] = '\0'; if (getheader(fin, mycheck, &cdat) < 0) return(-1); - if (cdat.fs[0] != '\0') - return(copymatch(fmt, cdat.fs) ? 1 : -1); - return(0); + if (!cdat.fs[0]) + return(0); + for (cp = fmt; *cp; cp++) /* check for globbing */ + if ((*cp == '?') | (*cp == '*')) { + if (globmatch(fmt, cdat.fs)) { + strcpy(fmt, cdat.fs); + return(1); + } else + return(-1); + } + return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */ }
