--- ray/src/common/header.c 1991/04/18 12:56:58 1.2 +++ ray/src/common/header.c 2012/06/10 02:46:12 2.27 @@ -1,57 +1,198 @@ -/* Copyright (c) 1988 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: header.c,v 2.27 2012/06/10 02:46:12 greg Exp $"; #endif - /* * header.c - routines for reading and writing information headers. * - * 8/19/88 + * Externals declared in resolu.h + * + * newheader(t,fp) start new information header identified by string t + * headidval(r,s) copy header identifier value in s to r + * dateval(t,s) get capture date value as UTC + * gmtval(t,s) get GMT as UTC + * fputdate(t,fp) put out the given UTC + * fputnow(fp) put out the current date and time + * printargs(ac,av,fp) print an argument list to fp, followed by '\n' + * formatval(r,s) copy the format value in s to r + * fputformat(s,fp) write "FORMAT=%s" to fp + * getheader(fp,f,p) read header from fp, calling f(s,p) on each line + * globmatch(pat, str) check for glob match of str against pat + * checkheader(i,p,o) check header format from i against p and copy to o + * + * To copy header from input to output, use getheader(fin, fputs, fout) */ -#include +#include "copyright.h" -#define MAXLINE 512 +#include -char FMTSTR[] = "FORMAT="; -int FMTSTRL = 7; +#include "rtio.h" +#include "resolu.h" +#define MAXLINE 2048 -printargs(ac, av, fp) /* print arguments to a file */ -int ac; -char **av; -FILE *fp; +extern time_t timegm(struct tm *tm); + +const char HDRSTR[] = "#?"; /* information header magic number */ + +const char FMTSTR[] = "FORMAT="; /* format identifier */ + +const char TMSTR[] = "CAPDATE="; /* capture date identifier */ +const char GMTSTR[] = "GMT="; /* GMT identifier */ + +static gethfunc mycheck; + + +extern void +newheader( /* identifying line of information header */ + char *s, + FILE *fp +) { - while (ac-- > 0) { - fputs(*av++, fp); - putc(' ', fp); - } + fputs(HDRSTR, fp); + fputs(s, fp); putc('\n', fp); } -isformat(s) /* is line a format line? */ -char *s; +extern int +headidval( /* get header id (return true if is id) */ + char *r, + char *s +) { - return(!strncmp(s,FMTSTR,FMTSTRL)); + const char *cp = HDRSTR; + + while (*cp) if (*cp++ != *s++) return(0); + if (r == NULL) return(1); + while (*s && !isspace(*s)) *r++ = *s++; + *r = '\0'; + return(1); } -formatval(r, s) /* return format value */ -register char *r; -register char *s; +extern int +dateval( /* convert capture date line to UTC */ + time_t *tloc, + char *s +) { - s += FMTSTRL; - while (*s && *s != '\n') + struct tm tms; + const char *cp = TMSTR; + + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (sscanf(s, "%d:%d:%d %d:%d:%d", + &tms.tm_year, &tms.tm_mon, &tms.tm_mday, + &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) + return(0); + if (tloc == NULL) + return(1); + tms.tm_mon--; + tms.tm_year -= 1900; + tms.tm_isdst = -1; /* ask mktime() to figure out DST */ + *tloc = mktime(&tms); + return(1); +} + + +extern int +gmtval( /* convert GMT date line to UTC */ + time_t *tloc, + char *s +) +{ + struct tm tms; + const char *cp = GMTSTR; + + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (sscanf(s, "%d:%d:%d %d:%d:%d", + &tms.tm_year, &tms.tm_mon, &tms.tm_mday, + &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) + return(0); + if (tloc == NULL) + return(1); + tms.tm_mon--; + tms.tm_year -= 1900; + *tloc = timegm(&tms); + return(1); +} + + +extern void +fputdate( /* write out the given time value (local & GMT) */ + time_t tv, + FILE *fp +) +{ + struct tm *tms; + + tms = localtime(&tv); + if (tms != NULL) + fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR, + tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday, + tms->tm_hour, tms->tm_min, tms->tm_sec); + tms = gmtime(&tv); + if (tms != NULL) + fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR, + tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday, + tms->tm_hour, tms->tm_min, tms->tm_sec); +} + + +extern void +fputnow( /* write out the current time */ + FILE *fp +) +{ + time_t tv; + time(&tv); + fputdate(tv, fp); +} + + +extern void +printargs( /* print arguments to a file */ + int ac, + char **av, + FILE *fp +) +{ + while (ac-- > 0) { + fputword(*av++, fp); + fputc(ac ? ' ' : '\n', fp); + } +} + + +extern int +formatval( /* get format value (return true if format) */ + char *r, + char *s +) +{ + const char *cp = FMTSTR; + + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (r == NULL) return(1); + do *r++ = *s++; + while(*s && !isspace(*s)); *r = '\0'; + return(1); } -fputformat(s, fp) /* put out a format value */ -char *s; -FILE *fp; +extern void +fputformat( /* put out a format value */ + char *s, + FILE *fp +) { fputs(FMTSTR, fp); fputs(s, fp); @@ -59,16 +200,18 @@ FILE *fp; } -getheader(fp, f, p) /* get header from file */ -FILE *fp; -int (*f)(); -char *p; +extern int +getheader( /* get header from file */ + FILE *fp, + gethfunc *f, + void *p +) { char buf[MAXLINE]; for ( ; ; ) { buf[MAXLINE-2] = '\n'; - if (fgets(buf, sizeof(buf), fp) == NULL) + if (fgets(buf, MAXLINE, fp) == NULL) return(-1); if (buf[0] == '\n') return(0); @@ -76,42 +219,123 @@ char *p; ungetc(buf[MAXLINE-2], fp); /* prevent false end */ buf[MAXLINE-2] = '\0'; } - if (f != NULL) - (*f)(buf, p); + if (f != NULL && (*f)(buf, p) < 0) + return(-1); } } struct check { FILE *fp; - char fs[32]; + char fs[64]; }; -static -mycheck(s, cp) /* check a header line for format info. */ -char *s; -register struct check *cp; +static int +mycheck( /* check a header line for format info. */ + char *s, + void *cp +) { - if (!strncmp(s,FMTSTR,FMTSTRL)) - formatval(cp->fs, s); - else if (cp->fp != NULL) /* don't copy format info. */ - fputs(s, cp->fp); + if (!formatval(((struct check*)cp)->fs, s) + && ((struct check*)cp)->fp != NULL) { + fputs(s, ((struct check*)cp)->fp); + } + return(0); } -checkheader(fin, fmt, fout) /* check data format in header */ -FILE *fin; -char *fmt; -FILE *fout; +extern int +globmatch( /* check for match of s against pattern p */ + char *p, + char *s +) { + int setmatch; + + do { + switch (*p) { + case '?': /* match any character */ + if (!*s++) + return(0); + break; + case '*': /* match any string */ + while (p[1] == '*') p++; + do + if ( (p[1]=='?' || p[1]==*s) && + globmatch(p+1,s) ) + return(1); + while (*s++); + return(0); + case '[': /* character set */ + setmatch = *s == *++p; + if (!*p) + return(0); + while (*++p != ']') { + if (!*p) + return(0); + if (*p == '-') { + setmatch += p[-1] <= *s && *s <= p[1]; + if (!*++p) + break; + } else + setmatch += *p == *s; + } + if (!setmatch) + return(0); + s++; + break; + case '\\': /* literal next */ + p++; + /* fall through */ + default: /* normal character */ + if (*p != *s) + return(0); + s++; + break; + } + } while (*p++); + return(1); +} + + +/* + * Checkheader(fin,fmt,fout) returns a value of 1 if the input format + * matches the specification in fmt, 0 if no input format was found, + * and -1 if the input format does not match or there is an + * error reading the header. If fmt is empty, then -1 is returned + * if any input format is found (or there is an error), and 0 otherwise. + * If fmt contains any '*' or '?' characters, then checkheader + * does wildcard expansion and copies a matching result into fmt. + * Be sure that fmt is big enough to hold the match in such cases, + * and that it is not a static, read-only string! + * The input header (minus any format lines) is copied to fout + * if fout is not NULL. + */ + +extern int +checkheader( + FILE *fin, + char *fmt, + FILE *fout +) +{ struct check cdat; + char *cp; cdat.fp = fout; cdat.fs[0] = '\0'; if (getheader(fin, mycheck, &cdat) < 0) return(-1); - if (fmt != NULL && cdat.fs[0] != '\0') - return(strcmp(fmt, cdat.fs) ? -1 : 1); - return(0); + if (!cdat.fs[0]) + return(0); + for (cp = fmt; *cp; cp++) /* check for globbing */ + if ((*cp == '?') | (*cp == '*')) { + if (globmatch(fmt, cdat.fs)) { + strcpy(fmt, cdat.fs); + return(1); + } else + return(-1); + } + return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */ }
