--- ray/src/common/header.c 2010/05/27 19:32:12 2.26 +++ ray/src/common/header.c 2019/06/09 18:22:20 2.34 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: header.c,v 2.26 2010/05/27 19:32:12 greg Exp $"; +static const char RCSid[] = "$Id: header.c,v 2.34 2019/06/09 18:22:20 greg Exp $"; #endif /* * header.c - routines for reading and writing information headers. @@ -43,9 +43,9 @@ const char GMTSTR[] = "GMT="; /* GMT identifier */ static gethfunc mycheck; -extern void +void newheader( /* identifying line of information header */ - char *s, + const char *s, FILE *fp ) { @@ -55,10 +55,10 @@ newheader( /* identifying line of information header } -extern int +int headidval( /* get header id (return true if is id) */ char *r, - char *s + const char *s ) { const char *cp = HDRSTR; @@ -71,10 +71,10 @@ headidval( /* get header id (return true if is id) * } -extern int +int dateval( /* convert capture date line to UTC */ time_t *tloc, - char *s + const char *s ) { struct tm tms; @@ -97,10 +97,10 @@ dateval( /* convert capture date line to UTC */ } -extern int +int gmtval( /* convert GMT date line to UTC */ time_t *tloc, - char *s + const char *s ) { struct tm tms; @@ -122,7 +122,7 @@ gmtval( /* convert GMT date line to UTC */ } -extern void +void fputdate( /* write out the given time value (local & GMT) */ time_t tv, FILE *fp @@ -143,7 +143,7 @@ fputdate( /* write out the given time value (local & } -extern void +void fputnow( /* write out the current time */ FILE *fp ) @@ -154,7 +154,7 @@ fputnow( /* write out the current time */ } -extern void +void printargs( /* print arguments to a file */ int ac, char **av, @@ -168,13 +168,14 @@ printargs( /* print arguments to a file */ } -extern int +int formatval( /* get format value (return true if format) */ - char *r, - char *s + char fmt[MAXFMTLEN], + const char *s ) { const char *cp = FMTSTR; + char *r = fmt; while (*cp) if (*cp++ != *s++) return(0); while (isspace(*s)) s++; @@ -182,15 +183,15 @@ formatval( /* get format value (return true if forma if (r == NULL) return(1); do *r++ = *s++; - while(*s && !isspace(*s)); + while (*s && !isspace(*s) && r-fmt < MAXFMTLEN-1); *r = '\0'; return(1); } -extern void +void fputformat( /* put out a format value */ - char *s, + const char *s, FILE *fp ) { @@ -200,38 +201,41 @@ fputformat( /* put out a format value */ } -extern int +int getheader( /* get header from file */ FILE *fp, gethfunc *f, void *p ) { + int rtotal = 0; char buf[MAXLINE]; + int firstc = fgetc(fp); + if (!isprint(firstc)) + return(-1); /* messed up */ + ungetc(firstc, fp); for ( ; ; ) { + int rval = 0; buf[MAXLINE-2] = '\n'; if (fgets(buf, MAXLINE, fp) == NULL) return(-1); - if (buf[0] == '\n') - return(0); -#ifdef MSDOS - if (buf[0] == '\r' && buf[1] == '\n') - return(0); -#endif + if (buf[buf[0]=='\r'] == '\n') /* end of header? */ + return(rtotal); if (buf[MAXLINE-2] != '\n') { ungetc(buf[MAXLINE-2], fp); /* prevent false end */ buf[MAXLINE-2] = '\0'; } - if (f != NULL && (*f)(buf, p) < 0) + if (f != NULL && (rval = (*f)(buf, p)) < 0) return(-1); + rtotal += rval; } } struct check { FILE *fp; - char fs[64]; + char fs[MAXFMTLEN]; }; @@ -241,18 +245,19 @@ mycheck( /* check a header line for format info. */ void *cp ) { - if (!formatval(((struct check*)cp)->fs, s) - && ((struct check*)cp)->fp != NULL) { - fputs(s, ((struct check*)cp)->fp); - } + struct check *scp = (struct check *)cp; + + if (!formatval(scp->fs, s) && scp->fp != NULL) + fputs(s, scp->fp); + return(0); } -extern int +int globmatch( /* check for match of s against pattern p */ - char *p, - char *s + const char *p, + const char *s ) { int setmatch; @@ -266,7 +271,7 @@ globmatch( /* check for match of s against pattern p case '*': /* match any string */ while (p[1] == '*') p++; do - if ( (p[1]=='?' || p[1]==*s) && + if ( (p[1]=='?') | (p[1]==*s) && globmatch(p+1,s) ) return(1); while (*s++); @@ -279,11 +284,11 @@ globmatch( /* check for match of s against pattern p if (!*p) return(0); if (*p == '-') { - setmatch += p[-1] <= *s && *s <= p[1]; + setmatch += (p[-1] <= *s && *s <= p[1]); if (!*++p) break; } else - setmatch += *p == *s; + setmatch += (*p == *s); } if (!setmatch) return(0); @@ -317,10 +322,10 @@ globmatch( /* check for match of s against pattern p * if fout is not NULL. */ -extern int +int checkheader( FILE *fin, - char *fmt, + char fmt[MAXFMTLEN], FILE *fout ) {
