--- ray/src/common/header.c 1997/10/31 11:40:52 2.9
+++ ray/src/common/header.c 2003/02/22 02:07:22 2.11
@@ -1,17 +1,18 @@
-/* Copyright (c) 1996 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: header.c,v 2.11 2003/02/22 02:07:22 greg Exp $";
#endif
* header.c - routines for reading and writing information headers.
- * 8/19/88
+ * Externals declared in resolu.h
* newheader(t,fp) start new information header identified by string t
* isheadid(s) returns true if s is a header id line
* headidval(r,s) copy header identifier value in s to r
+ * dateval(t,s) get capture date value
+ * isdate(s) returns true if s is a date line
+ * fputdate(t,fp) put out the given capture date and time
+ * fputnow(fp) put out the current date and time
* printargs(ac,av,fp) print an argument list to fp, followed by '\n'
* isformat(s) returns true if s is of the form "FORMAT=*"
* formatval(r,s) copy the format value in s to r
@@ -23,7 +24,66 @@ static char SCCSid[] = "$SunId$ LBL";
* To copy header from input to output, use getheader(fin, fputs, fout)
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include
+#include
+#include
#include
#define MAXLINE 512
@@ -38,7 +98,12 @@ char HDRSTR[] = "#?"; /* information header magic nu
char FMTSTR[] = "FORMAT="; /* format identifier */
+char TMSTR[] = "CAPDATE="; /* capture date identifier */
+static int mycheck();
+void
newheader(s, fp) /* identifying line of information header */
char *s;
register FILE *fp;
@@ -71,25 +136,74 @@ char *s;
+int
+dateval(tloc, s) /* get capture date value */
+time_t *tloc;
+char *s;
+ struct tm tms;
+ register char *cp = TMSTR;
+ while (*cp) if (*cp++ != *s++) return(0);
+ while (isspace(*s)) s++;
+ if (!*s) return(0);
+ if (sscanf(s, "%d:%d:%d %d:%d:%d",
+ &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
+ &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
+ return(0);
+ if (tloc == NULL)
+ return(1);
+ tms.tm_mon--;
+ tms.tm_year -= 1900;
+ tms.tm_isdst = -1; /* ask mktime() to figure out DST */
+ *tloc = mktime(&tms);
+ return(1);
+int
+isdate(s) /* is the given line a capture date? */
+char *s;
+ return(dateval(NULL, s));
+void
+fputdate(tv, fp) /* write out the given time value */
+time_t tv;
+FILE *fp;
+ struct tm *tm = localtime(&tv);
+ if (tm == NULL)
+ return;
+ fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
+ tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday,
+ tm->tm_hour, tm->tm_min, tm->tm_sec);
+void
+fputnow(fp) /* write out the current time */
+FILE *fp;
+ time_t tv;
+ time(&tv);
+ fputdate(tv, fp);
+void
printargs(ac, av, fp) /* print arguments to a file */
int ac;
char **av;
-register FILE *fp;
+FILE *fp;
int quote;
while (ac-- > 0) {
- if (index(*av, ' ') != NULL) { /* quote it */
- if (index(*av, '\'') != NULL)
- quote = '"';
- else
- quote = '\'';
- putc(quote, fp);
- fputs(*av++, fp);
- putc(quote, fp);
- } else
- fputs(*av++, fp);
- putc(ac ? ' ' : '\n', fp);
+ fputword(*av++, fp);
+ fputc(ac ? ' ' : '\n', fp);
@@ -121,6 +235,7 @@ char *s;
+void
fputformat(s, fp) /* put out a format value */
char *s;
FILE *fp;
@@ -153,8 +268,8 @@ char *p;
ungetc(buf[MAXLINE-2], fp); /* prevent false end */
buf[MAXLINE-2] = '\0';
- if (f != NULL)
- (*f)(buf, p);
+ if (f != NULL && (*f)(buf, p) < 0)
+ return(-1);
@@ -165,21 +280,22 @@ struct check {
-static
+static int
mycheck(s, cp) /* check a header line for format info. */
char *s;
register struct check *cp;
if (!formatval(cp->fs, s) && cp->fp != NULL)
fputs(s, cp->fp);
+ return(0);
int
-globmatch(pat, str) /* check for glob match of str against pat */
-char *pat, *str;
+globmatch(p, s) /* check for match of s against pattern p */
+register char *p, *s;
- register char *p = pat, *s = str;
+ int setmatch;
do {
switch (*p) {
@@ -195,6 +311,24 @@ char *pat, *str;
return(1);
while (*s++);
return(0);
+ case '[': /* character set */
+ setmatch = *s == *++p;
+ if (!*p)
+ return(0);
+ while (*++p != ']') {
+ if (!*p)
+ return(0);
+ if (*p == '-') {
+ setmatch += p[-1] <= *s && *s <= p[1];
+ if (!*++p)
+ break;
+ } else
+ setmatch += *p == *s;
+ if (!setmatch)
+ return(0);
+ s++;
+ break;
case '\\': /* literal next */
p++;
/* fall through */
