--- ray/src/common/header.c 1998/10/27 08:44:28 2.10 +++ ray/src/common/header.c 2022/03/04 17:16:12 2.43 @@ -1,21 +1,23 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: header.c,v 2.43 2022/03/04 17:16:12 greg Exp $"; #endif - /* * header.c - routines for reading and writing information headers. * - * 8/19/88 + * Externals declared in rtio.h * * newheader(t,fp) start new information header identified by string t - * isheadid(s) returns true if s is a header id line * headidval(r,s) copy header identifier value in s to r + * dateval(t,s) get capture date value as UTC + * gmtval(t,s) get GMT as UTC + * fputdate(t,fp) put out the given UTC + * fputnow(fp) put out the current date and time * printargs(ac,av,fp) print an argument list to fp, followed by '\n' - * isformat(s) returns true if s is of the form "FORMAT=*" * formatval(r,s) copy the format value in s to r * fputformat(s,fp) write "FORMAT=%s" to fp + * nativebigendian() are we native on big-endian machine? + * isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant) + * fputendian(fp) write native endianness in BigEndian= line * getheader(fp,f,p) read header from fp, calling f(s,p) on each line * globmatch(pat, str) check for glob match of str against pat * checkheader(i,p,o) check header format from i against p and copy to o @@ -23,37 +25,49 @@ static char SCCSid[] = "$SunId$ LBL"; * To copy header from input to output, use getheader(fin, fputs, fout) */ -#include +#include "copyright.h" + #include -#define MAXLINE 512 +#include "tiff.h" /* for int32 */ +#include "rtio.h" +#include "resolu.h" -#ifndef BSD -#define index strchr -#endif +#define MAXLINE 2048 -extern char *index(); +extern time_t timegm(struct tm *tm); -char HDRSTR[] = "#?"; /* information header magic number */ +const char HDRSTR[] = "#?"; /* information header magic number */ -char FMTSTR[] = "FORMAT="; /* format identifier */ +const char FMTSTR[] = "FORMAT="; /* format identifier */ +const char TMSTR[] = "CAPDATE="; /* capture date identifier */ +const char GMTSTR[] = "GMT="; /* GMT identifier */ -newheader(s, fp) /* identifying line of information header */ -char *s; -register FILE *fp; +const char BIGEND[] = "BigEndian="; /* big-endian variable */ + +static gethfunc mycheck; + + +void +newheader( /* identifying line of information header */ + const char *s, + FILE *fp +) { fputs(HDRSTR, fp); fputs(s, fp); - putc('\n', fp); + fputc('\n', fp); } int -headidval(r,s) /* get header id (return true if is id) */ -register char *r, *s; +headidval( /* get header id (return true if is id) */ + char *r, + const char *s +) { - register char *cp = HDRSTR; + const char *cp = HDRSTR; while (*cp) if (*cp++ != *s++) return(0); if (r == NULL) return(1); @@ -64,42 +78,118 @@ register char *r, *s; int -isheadid(s) /* check to see if line is header id */ -char *s; +dateval( /* convert capture date line to UTC */ + time_t *tloc, + const char *s +) { - return(headidval(NULL, s)); + struct tm tms; + const char *cp = TMSTR; + + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (sscanf(s, "%d:%d:%d %d:%d:%d", + &tms.tm_year, &tms.tm_mon, &tms.tm_mday, + &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) + return(0); + if (tloc == NULL) + return(1); + tms.tm_mon--; + tms.tm_year -= 1900; + tms.tm_isdst = -1; /* ask mktime() to figure out DST */ + *tloc = mktime(&tms); + return(1); } -printargs(ac, av, fp) /* print arguments to a file */ -int ac; -char **av; -register FILE *fp; +int +gmtval( /* convert GMT date line to UTC */ + time_t *tloc, + const char *s +) { - int quote; + struct tm tms; + const char *cp = GMTSTR; + while (*cp) if (*cp++ != *s++) return(0); + while (isspace(*s)) s++; + if (!*s) return(0); + if (sscanf(s, "%d:%d:%d %d:%d:%d", + &tms.tm_year, &tms.tm_mon, &tms.tm_mday, + &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6) + return(0); + if (tloc == NULL) + return(1); + tms.tm_mon--; + tms.tm_year -= 1900; + *tloc = timegm(&tms); + return(1); +} + + +void +fputdate( /* write out the given time value (local & GMT) */ + time_t tv, + FILE *fp +) +{ + struct tm *tms; + + tms = localtime(&tv); + if (tms != NULL) + fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR, + tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday, + tms->tm_hour, tms->tm_min, tms->tm_sec); + tms = gmtime(&tv); + if (tms != NULL) + fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR, + tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday, + tms->tm_hour, tms->tm_min, tms->tm_sec); +} + + +void +fputnow( /* write out the current time */ + FILE *fp +) +{ + time_t tv; + time(&tv); + fputdate(tv, fp); +} + + +void +printargs( /* print arguments to a file */ + int ac, + char **av, + FILE *fp +) +{ +#if defined(_WIN32) || defined(_WIN64) + extern char *fixargv0(char *arg0); + char myav0[128]; + /* clean up Windows executable path */ + if (ac-- <= 0) return; + fputs(fixargv0(strcpy(myav0, *av++)), fp); + fputc(ac ? ' ' : '\n', fp); +#endif while (ac-- > 0) { - if (index(*av, ' ') != NULL) { /* quote it */ - if (index(*av, '\'') != NULL) - quote = '"'; - else - quote = '\''; - putc(quote, fp); - fputs(*av++, fp); - putc(quote, fp); - } else - fputs(*av++, fp); - putc(ac ? ' ' : '\n', fp); + fputword(*av++, fp); + fputc(ac ? ' ' : '\n', fp); } } int -formatval(r, s) /* get format value (return true if format) */ -register char *r; -register char *s; +formatval( /* get format value (return true if format) */ + char fmt[MAXFMTLEN], + const char *s +) { - register char *cp = FMTSTR; + const char *cp = FMTSTR; + char *r = fmt; while (*cp) if (*cp++ != *s++) return(0); while (isspace(*s)) s++; @@ -107,79 +197,153 @@ register char *s; if (r == NULL) return(1); do *r++ = *s++; - while(*s && !isspace(*s)); + while (*s && !isspace(*s) && r-fmt < MAXFMTLEN-1); *r = '\0'; return(1); } +void +fputformat( /* put out a format value */ + const char *s, + FILE *fp +) +{ + int align = 0; + + fputs(FMTSTR, fp); + fputs(s, fp); + /* pad to align binary type for mmap() */ + if (!strncmp(s, "float", 5)) + align = sizeof(float); + else if (!strncmp(s, "double", 6)) + align = sizeof(double); + else if (!strncmp(s, "16-bit", 6)) + align = 2; + else if (!strncmp(s, "32-bit", 6)) + align = 4; + else if (!strncmp(s, "64-bit", 6)) + align = 8; + if (align) { + long pos = ftell(fp); + if (pos >= 0) { + pos = (pos + 2) % align; + if (pos) align -= pos; + else align = 0; + } else + align = 0; + } + while (align-- > 0) + putc(' ', fp); + fputc('\n', fp); +} + + int -isformat(s) /* is line a format line? */ -char *s; +nativebigendian() /* are we native on a big-endian machine? */ { - return(formatval(NULL, s)); + union { int32 i; char c[4]; } u; + + u.i = 1; + + return(u.c[0] == 0); } -fputformat(s, fp) /* put out a format value */ -char *s; -FILE *fp; +int +isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */ + const char *s +) { - fputs(FMTSTR, fp); - fputs(s, fp); - putc('\n', fp); + const char *be = BIGEND; + + while ((*s != '\0') & (*be != '=') && *s++ == *be) + ++be; + if (*be != '=') + return(-1); /* irrelevant */ + while (isspace(*s)) + s++; + if (*s++ != '=') + return(-1); + while (isspace(*s)) + s++; + return(*s == '1'); } +void +fputendian( /* write native endianness in BigEndian= line */ + FILE *fp +) +{ + fputs(BIGEND, fp); + if (nativebigendian()) + fputs("1\n", fp); + else + fputs("0\n", fp); +} + + int -getheader(fp, f, p) /* get header from file */ -FILE *fp; -int (*f)(); -char *p; +getheader( /* get header from file */ + FILE *fp, + gethfunc *f, + void *p +) { + int rtotal = 0; char buf[MAXLINE]; + int firstc = fgetc(fp); + if (!isprint(firstc)) + return(-1); /* messed up */ + ungetc(firstc, fp); for ( ; ; ) { + int rval = 0; buf[MAXLINE-2] = '\n'; if (fgets(buf, MAXLINE, fp) == NULL) return(-1); - if (buf[0] == '\n') - return(0); -#ifdef MSDOS - if (buf[0] == '\r' && buf[1] == '\n') - return(0); -#endif + if (buf[buf[0]=='\r'] == '\n') /* end of header? */ + return(rtotal); if (buf[MAXLINE-2] != '\n') { ungetc(buf[MAXLINE-2], fp); /* prevent false end */ buf[MAXLINE-2] = '\0'; } - if (f != NULL && (*f)(buf, p) < 0) + if (f != NULL && (rval = (*f)(buf, p)) < 0) return(-1); + rtotal += rval; } } struct check { FILE *fp; - char fs[64]; + char fs[MAXFMTLEN]; }; -static -mycheck(s, cp) /* check a header line for format info. */ -char *s; -register struct check *cp; +static int +mycheck( /* check a header line for format info. */ + char *s, + void *cp +) { - if (!formatval(cp->fs, s) && cp->fp != NULL) - fputs(s, cp->fp); + struct check *scp = (struct check *)cp; + + if (!formatval(scp->fs, s) && scp->fp != NULL) + return(fputs(s, scp->fp)); + + return(0); } int -globmatch(pat, str) /* check for glob match of str against pat */ -char *pat, *str; +globmatch( /* check for match of s against pattern p */ + const char *p, + const char *s +) { - register char *p = pat, *s = str; + int setmatch; do { switch (*p) { @@ -190,11 +354,29 @@ char *pat, *str; case '*': /* match any string */ while (p[1] == '*') p++; do - if ( (p[1]=='?' || p[1]==*s) && + if ( (p[1]=='?') | (p[1]==*s) && globmatch(p+1,s) ) return(1); while (*s++); return(0); + case '[': /* character set */ + setmatch = *s == *++p; + if (!*p) + return(0); + while (*++p != ']') { + if (!*p) + return(0); + if (*p == '-') { + setmatch += (p[-1] <= *s && *s <= p[1]); + if (!*++p) + break; + } else + setmatch += (*p == *s); + } + if (!setmatch) + return(0); + s++; + break; case '\\': /* literal next */ p++; /* fall through */ @@ -224,13 +406,14 @@ char *pat, *str; */ int -checkheader(fin, fmt, fout) -FILE *fin; -char *fmt; -FILE *fout; +checkheader( + FILE *fin, + char fmt[MAXFMTLEN], + FILE *fout +) { struct check cdat; - register char *cp; + char *cp; cdat.fp = fout; cdat.fs[0] = '\0'; @@ -239,11 +422,12 @@ FILE *fout; if (!cdat.fs[0]) return(0); for (cp = fmt; *cp; cp++) /* check for globbing */ - if (*cp == '?' | *cp == '*') + if ((*cp == '?') | (*cp == '*')) { if (globmatch(fmt, cdat.fs)) { strcpy(fmt, cdat.fs); return(1); } else return(-1); + } return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */ }
