--- ray/src/common/header.c 1991/04/18 12:56:58 1.2 +++ ray/src/common/header.c 1991/04/22 08:23:10 1.4 @@ -1,4 +1,4 @@ -/* Copyright (c) 1988 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -8,9 +8,19 @@ static char SCCSid[] = "$SunId$ LBL"; * header.c - routines for reading and writing information headers. * * 8/19/88 + * + * printargs(ac,av,fp) print an argument list to fp, followed by '\n' + * isformat(s) returns true if s is of the form "FORMAT=*" + * formatval(r,s) copy the format value in s to r + * fputformat(s,fp) write "FORMAT=%s" to fp + * getheader(fp,f,p) read header from fp, calling f(s,p) on each line + * checkheader(i,p,o) check header format from i against p and copy to o + * + * To copy header from input to output, use getheader(fin, fputs, fout) */ #include +#include #define MAXLINE 512 @@ -43,8 +53,10 @@ register char *r; register char *s; { s += FMTSTRL; - while (*s && *s != '\n') - *r++ = *s++; + while (isspace(*s)) s++; + if (!*s) { *r = '\0'; return; } + while(*s) *r++ = *s++; + while (isspace(r[-1])) r--; *r = '\0'; } @@ -84,7 +96,7 @@ char *p; struct check { FILE *fp; - char fs[32]; + char fs[64]; }; @@ -100,7 +112,68 @@ register struct check *cp; } -checkheader(fin, fmt, fout) /* check data format in header */ +/* + * Copymatch(pat,str) checks pat for wildcards, and + * copies str into pat if there is a match (returning true). + */ + +#ifdef COPYMATCH +copymatch(pat, str) +char *pat, *str; +{ + int docopy = 0; + register char *p = pat, *s = str; + + do { + switch (*p) { + case '?': /* match any character */ + if (!*s++) + return(0); + docopy++; + break; + case '*': /* match any string */ + while (p[1] == '*') p++; + do + if ( (p[1]=='?' || p[1]==*s) + && copymatch(p+1,s) ) { + strcpy(pat, str); + return(1); + } + while (*s++); + return(0); + case '\\': /* literal next */ + p++; + /* fall through */ + default: /* normal character */ + if (*p != *s) + return(0); + s++; + break; + } + } while (*p++); + if (docopy) + strcpy(pat, str); + return(1); +} +#else +#define copymatch(pat, s) (!strcmp(pat, s)) +#endif + + +/* + * Checkheader(fin,fmt,fout) returns a value of 1 if the input format + * matches the specification in fmt, 0 if no input format was found, + * and -1 if the input format does not match or there is an + * error reading the header. If fmt is empty, then -1 is returned + * if any input format is found (or there is an error), and 0 otherwise. + * If fmt contains any '*' or '?' characters, then checkheader + * does wildcard expansion and copies a matching result into fmt. + * Be sure that fmt is big enough to hold the match in such cases! + * The input header (minus any format lines) is copied to fout + * if fout is not NULL. + */ + +checkheader(fin, fmt, fout) FILE *fin; char *fmt; FILE *fout; @@ -111,7 +184,7 @@ FILE *fout; cdat.fs[0] = '\0'; if (getheader(fin, mycheck, &cdat) < 0) return(-1); - if (fmt != NULL && cdat.fs[0] != '\0') - return(strcmp(fmt, cdat.fs) ? -1 : 1); + if (cdat.fs[0] != '\0') + return(copymatch(fmt, cdat.fs) ? 1 : -1); return(0); }
