root/radiance/ray/src/common/header.c
Revision: 2.41
Committed: Thu Mar 3 03:55:12 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.40: +21 -3 lines
feat: Added float and double alignment to i/o routines for future mmap() use
2 static const char RCSid[] = "$Id: header.c,v 2.40 2020/07/25 01:10:38 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in rtio.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * nativebigendian() are we native on big-endian machine?
19 * isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant)
20 * fputendian(fp) write native endianness in BigEndian= line
21 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
22 * globmatch(pat, str) check for glob match of str against pat
23 * checkheader(i,p,o) check header format from i against p and copy to o
24 *
25 * To copy header from input to output, use getheader(fin, fputs, fout)
26 */
27
28 #include "copyright.h"
29
30 #include <ctype.h>
31
32 #include "tiff.h" /* for int32 */
33 #include "rtio.h"
34 #include "resolu.h"
35
36 #define MAXLINE 2048
37
38 extern time_t timegm(struct tm *tm);
39
40 const char HDRSTR[] = "#?"; /* information header magic number */
41
42 const char FMTSTR[] = "FORMAT="; /* format identifier */
43
44 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
45 const char GMTSTR[] = "GMT="; /* GMT identifier */
46
47 const char BIGEND[] = "BigEndian="; /* big-endian variable */
48
49 static gethfunc mycheck;
50
51
52 void
53 newheader( /* identifying line of information header */
54 const char *s,
55 FILE *fp
56 )
57 {
58 fputs(HDRSTR, fp);
59 fputs(s, fp);
60 fputc('\n', fp);
61 }
62
63
64 int
65 headidval( /* get header id (return true if is id) */
66 char *r,
67 const char *s
68 )
69 {
70 const char *cp = HDRSTR;
71
72 while (*cp) if (*cp++ != *s++) return(0);
73 if (r == NULL) return(1);
74 while (*s && !isspace(*s)) *r++ = *s++;
75 *r = '\0';
76 return(1);
77 }
78
79
80 int
81 dateval( /* convert capture date line to UTC */
82 time_t *tloc,
83 const char *s
84 )
85 {
86 struct tm tms;
87 const char *cp = TMSTR;
88
89 while (*cp) if (*cp++ != *s++) return(0);
90 while (isspace(*s)) s++;
91 if (!*s) return(0);
92 if (sscanf(s, "%d:%d:%d %d:%d:%d",
93 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
94 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
95 return(0);
96 if (tloc == NULL)
97 return(1);
98 tms.tm_mon--;
99 tms.tm_year -= 1900;
100 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
101 *tloc = mktime(&tms);
102 return(1);
103 }
104
105
106 int
107 gmtval( /* convert GMT date line to UTC */
108 time_t *tloc,
109 const char *s
110 )
111 {
112 struct tm tms;
113 const char *cp = GMTSTR;
114
115 while (*cp) if (*cp++ != *s++) return(0);
116 while (isspace(*s)) s++;
117 if (!*s) return(0);
118 if (sscanf(s, "%d:%d:%d %d:%d:%d",
119 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
120 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
121 return(0);
122 if (tloc == NULL)
123 return(1);
124 tms.tm_mon--;
125 tms.tm_year -= 1900;
126 *tloc = timegm(&tms);
127 return(1);
128 }
129
130
131 void
132 fputdate( /* write out the given time value (local & GMT) */
133 time_t tv,
134 FILE *fp
135 )
136 {
137 struct tm *tms;
138
139 tms = localtime(&tv);
140 if (tms != NULL)
141 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
142 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
143 tms->tm_hour, tms->tm_min, tms->tm_sec);
144 tms = gmtime(&tv);
145 if (tms != NULL)
146 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
147 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
148 tms->tm_hour, tms->tm_min, tms->tm_sec);
149 }
150
151
152 void
153 fputnow( /* write out the current time */
154 FILE *fp
155 )
156 {
157 time_t tv;
158 time(&tv);
159 fputdate(tv, fp);
160 }
161
162
163 void
164 printargs( /* print arguments to a file */
165 int ac,
166 char **av,
167 FILE *fp
168 )
169 {
170 #if defined(_WIN32) || defined(_WIN64)
171 extern char *fixargv0(char *arg0);
172 char myav0[128];
173 /* clean up Windows executable path */
174 if (ac-- <= 0) return;
175 fputs(fixargv0(strcpy(myav0, *av++)), fp);
176 fputc(ac ? ' ' : '\n', fp);
177 #endif
178 while (ac-- > 0) {
179 fputword(*av++, fp);
180 fputc(ac ? ' ' : '\n', fp);
181 }
182 }
183
184
185 int
186 formatval( /* get format value (return true if format) */
187 char fmt[MAXFMTLEN],
188 const char *s
189 )
190 {
191 const char *cp = FMTSTR;
192 char *r = fmt;
193
194 while (*cp) if (*cp++ != *s++) return(0);
195 while (isspace(*s)) s++;
196 if (!*s) return(0);
197 if (r == NULL) return(1);
198 do
199 *r++ = *s++;
200 while (*s && !isspace(*s) && r-fmt < MAXFMTLEN-1);
201 *r = '\0';
202 return(1);
203 }
204
205
206 void
207 fputformat( /* put out a format value */
208 const char *s,
209 FILE *fp
210 )
211 {
212 int align = 0;
213
214 fputs(FMTSTR, fp);
215 fputs(s, fp);
216 /* pad to align binary type for mmap() */
217 if (!strcmp(s, "float"))
218 align = 4;
219 else if (!strcmp(s, "double"))
220 align = 8;
221 if (align) {
222 long pos = ftell(fp);
223 if (pos >= 0) {
224 pos = (pos + 2) % align;
225 if (pos) align -= pos;
226 else align = 0;
227 } else
228 align = 0;
229 }
230 while (align-- > 0)
231 putc(' ', fp);
232 fputc('\n', fp);
233 }
234
235
236 int
237 nativebigendian() /* are we native on a big-endian machine? */
238 {
239 union { int32 i; char c[4]; } u;
240
241 u.i = 1;
242
243 return(u.c[0] == 0);
244 }
245
246
247 int
248 isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */
249 const char *s
250 )
251 {
252 const char *be = BIGEND;
253
254 while ((*s != '\0') & (*be != '=') && *s++ == *be)
255 ++be;
256 if (*be != '=')
257 return(-1); /* irrelevant */
258 while (isspace(*s))
259 s++;
260 if (*s++ != '=')
261 return(-1);
262 while (isspace(*s))
263 s++;
264 return(*s == '1');
265 }
266
267
268 void
269 fputendian( /* write native endianness in BigEndian= line */
270 FILE *fp
271 )
272 {
273 fputs(BIGEND, fp);
274 if (nativebigendian())
275 fputs("1\n", fp);
276 else
277 fputs("0\n", fp);
278 }
279
280
281 int
282 getheader( /* get header from file */
283 FILE *fp,
284 gethfunc *f,
285 void *p
286 )
287 {
288 int rtotal = 0;
289 char buf[MAXLINE];
290 int firstc = fgetc(fp);
291
292 if (!isprint(firstc))
293 return(-1); /* messed up */
294 ungetc(firstc, fp);
295 for ( ; ; ) {
296 int rval = 0;
297 buf[MAXLINE-2] = '\n';
298 if (fgets(buf, MAXLINE, fp) == NULL)
299 return(-1);
300 if (buf[buf[0]=='\r'] == '\n') /* end of header? */
301 return(rtotal);
302 if (buf[MAXLINE-2] != '\n') {
303 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
304 buf[MAXLINE-2] = '\0';
305 }
306 if (f != NULL && (rval = (*f)(buf, p)) < 0)
307 return(-1);
308 rtotal += rval;
309 }
310 }
311
312
313 struct check {
314 FILE *fp;
315 char fs[MAXFMTLEN];
316 };
317
318
319 static int
320 mycheck( /* check a header line for format info. */
321 char *s,
322 void *cp
323 )
324 {
325 struct check *scp = (struct check *)cp;
326
327 if (!formatval(scp->fs, s) && scp->fp != NULL)
328 return(fputs(s, scp->fp));
329
330 return(0);
331 }
332
333
334 int
335 globmatch( /* check for match of s against pattern p */
336 const char *p,
337 const char *s
338 )
339 {
340 int setmatch;
341
342 do {
343 switch (*p) {
344 case '?': /* match any character */
345 if (!*s++)
346 return(0);
347 break;
348 case '*': /* match any string */
349 while (p[1] == '*') p++;
350 do
351 if ( (p[1]=='?') | (p[1]==*s) &&
352 globmatch(p+1,s) )
353 return(1);
354 while (*s++);
355 return(0);
356 case '[': /* character set */
357 setmatch = *s == *++p;
358 if (!*p)
359 return(0);
360 while (*++p != ']') {
361 if (!*p)
362 return(0);
363 if (*p == '-') {
364 setmatch += (p[-1] <= *s && *s <= p[1]);
365 if (!*++p)
366 break;
367 } else
368 setmatch += (*p == *s);
369 }
370 if (!setmatch)
371 return(0);
372 s++;
373 break;
374 case '\\': /* literal next */
375 p++;
376 /* fall through */
377 default: /* normal character */
378 if (*p != *s)
379 return(0);
380 s++;
381 break;
382 }
383 } while (*p++);
384 return(1);
385 }
386
387
388 /*
389 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
390 * matches the specification in fmt, 0 if no input format was found,
391 * and -1 if the input format does not match or there is an
392 * error reading the header. If fmt is empty, then -1 is returned
393 * if any input format is found (or there is an error), and 0 otherwise.
394 * If fmt contains any '*' or '?' characters, then checkheader
395 * does wildcard expansion and copies a matching result into fmt.
396 * Be sure that fmt is big enough to hold the match in such cases,
397 * and that it is not a static, read-only string!
398 * The input header (minus any format lines) is copied to fout
399 * if fout is not NULL.
400 */
401
402 int
403 checkheader(
404 FILE *fin,
405 char fmt[MAXFMTLEN],
406 FILE *fout
407 )
408 {
409 struct check cdat;
410 char *cp;
411
412 cdat.fp = fout;
413 cdat.fs[0] = '\0';
414 if (getheader(fin, mycheck, &cdat) < 0)
415 return(-1);
416 if (!cdat.fs[0])
417 return(0);
418 for (cp = fmt; *cp; cp++) /* check for globbing */
419 if ((*cp == '?') | (*cp == '*')) {
420 if (globmatch(fmt, cdat.fs)) {
421 strcpy(fmt, cdat.fs);
422 return(1);
423 } else
424 return(-1);
425 }
426 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
427 }
