root/radiance/ray/src/common/header.c
Revision: 2.40
Committed: Sat Jul 25 01:10:38 2020 UTC (5 years ago) by greg
fix: added missing file pointer to fputc() call
2 static const char RCSid[] = "$Id: header.c,v 2.39 2020/07/24 16:58:16 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in rtio.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * nativebigendian() are we native on big-endian machine?
19 * isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant)
20 * fputendian(fp) write native endianness in BigEndian= line
21 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
22 * globmatch(pat, str) check for glob match of str against pat
23 * checkheader(i,p,o) check header format from i against p and copy to o
24 *
25 * To copy header from input to output, use getheader(fin, fputs, fout)
26 */
27
28 #include "copyright.h"
29
30 #include <ctype.h>
31
32 #include "tiff.h" /* for int32 */
33 #include "rtio.h"
34 #include "resolu.h"
35
36 #define MAXLINE 2048
37
38 extern time_t timegm(struct tm *tm);
39
40 const char HDRSTR[] = "#?"; /* information header magic number */
41
42 const char FMTSTR[] = "FORMAT="; /* format identifier */
43
44 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
45 const char GMTSTR[] = "GMT="; /* GMT identifier */
46
47 const char BIGEND[] = "BigEndian="; /* big-endian variable */
48
49 static gethfunc mycheck;
50
51
52 void
53 newheader( /* identifying line of information header */
54 const char *s,
55 FILE *fp
56 )
57 {
58 fputs(HDRSTR, fp);
59 fputs(s, fp);
60 putc('\n', fp);
61 }
62
63
64 int
65 headidval( /* get header id (return true if is id) */
66 char *r,
67 const char *s
68 )
69 {
70 const char *cp = HDRSTR;
71
72 while (*cp) if (*cp++ != *s++) return(0);
73 if (r == NULL) return(1);
74 while (*s && !isspace(*s)) *r++ = *s++;
75 *r = '\0';
76 return(1);
77 }
78
79
80 int
81 dateval( /* convert capture date line to UTC */
82 time_t *tloc,
83 const char *s
84 )
85 {
86 struct tm tms;
87 const char *cp = TMSTR;
88
89 while (*cp) if (*cp++ != *s++) return(0);
90 while (isspace(*s)) s++;
91 if (!*s) return(0);
92 if (sscanf(s, "%d:%d:%d %d:%d:%d",
93 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
94 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
95 return(0);
96 if (tloc == NULL)
97 return(1);
98 tms.tm_mon--;
99 tms.tm_year -= 1900;
100 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
101 *tloc = mktime(&tms);
102 return(1);
103 }
104
105
106 int
107 gmtval( /* convert GMT date line to UTC */
108 time_t *tloc,
109 const char *s
110 )
111 {
112 struct tm tms;
113 const char *cp = GMTSTR;
114
115 while (*cp) if (*cp++ != *s++) return(0);
116 while (isspace(*s)) s++;
117 if (!*s) return(0);
118 if (sscanf(s, "%d:%d:%d %d:%d:%d",
119 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
120 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
121 return(0);
122 if (tloc == NULL)
123 return(1);
124 tms.tm_mon--;
125 tms.tm_year -= 1900;
126 *tloc = timegm(&tms);
127 return(1);
128 }
129
130
131 void
132 fputdate( /* write out the given time value (local & GMT) */
133 time_t tv,
134 FILE *fp
135 )
136 {
137 struct tm *tms;
138
139 tms = localtime(&tv);
140 if (tms != NULL)
141 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
142 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
143 tms->tm_hour, tms->tm_min, tms->tm_sec);
144 tms = gmtime(&tv);
145 if (tms != NULL)
146 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
147 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
148 tms->tm_hour, tms->tm_min, tms->tm_sec);
149 }
150
151
152 void
153 fputnow( /* write out the current time */
154 FILE *fp
155 )
156 {
157 time_t tv;
158 time(&tv);
159 fputdate(tv, fp);
160 }
161
162
163 void
164 printargs( /* print arguments to a file */
165 int ac,
166 char **av,
167 FILE *fp
168 )
169 {
170 #if defined(_WIN32) || defined(_WIN64)
171 extern char *fixargv0(char *arg0);
172 char myav0[128];
173 /* clean up Windows executable path */
174 if (ac-- <= 0) return;
175 fputs(fixargv0(strcpy(myav0, *av++)), fp);
176 fputc(ac ? ' ' : '\n', fp);
177 #endif
178 while (ac-- > 0) {
179 fputword(*av++, fp);
180 fputc(ac ? ' ' : '\n', fp);
181 }
182 }
183
184
185 int
186 formatval( /* get format value (return true if format) */
187 char fmt[MAXFMTLEN],
188 const char *s
189 )
190 {
191 const char *cp = FMTSTR;
192 char *r = fmt;
193
194 while (*cp) if (*cp++ != *s++) return(0);
195 while (isspace(*s)) s++;
196 if (!*s) return(0);
197 if (r == NULL) return(1);
198 do
199 *r++ = *s++;
200 while (*s && !isspace(*s) && r-fmt < MAXFMTLEN-1);
201 *r = '\0';
202 return(1);
203 }
204
205
206 void
207 fputformat( /* put out a format value */
208 const char *s,
209 FILE *fp
210 )
211 {
212 fputs(FMTSTR, fp);
213 fputs(s, fp);
214 putc('\n', fp);
215 }
216
217
218 int
219 nativebigendian() /* are we native on a big-endian machine? */
220 {
221 union { int32 i; char c[4]; } u;
222
223 u.i = 1;
224
225 return(u.c[0] == 0);
226 }
227
228
229 int
230 isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */
231 const char *s
232 )
233 {
234 const char *be = BIGEND;
235
236 while ((*s != '\0') & (*be != '=') && *s++ == *be)
237 ++be;
238 if (*be != '=')
239 return(-1); /* irrelevant */
240 while (isspace(*s))
241 s++;
242 if (*s++ != '=')
243 return(-1);
244 while (isspace(*s))
245 s++;
246 return(*s == '1');
247 }
248
249
250 void
251 fputendian( /* write native endianness in BigEndian= line */
252 FILE *fp
253 )
254 {
255 fputs(BIGEND, fp);
256 if (nativebigendian())
257 fputs("1\n", fp);
258 else
259 fputs("0\n", fp);
260 }
261
262
263 int
264 getheader( /* get header from file */
265 FILE *fp,
266 gethfunc *f,
267 void *p
268 )
269 {
270 int rtotal = 0;
271 char buf[MAXLINE];
272 int firstc = fgetc(fp);
273
274 if (!isprint(firstc))
275 return(-1); /* messed up */
276 ungetc(firstc, fp);
277 for ( ; ; ) {
278 int rval = 0;
279 buf[MAXLINE-2] = '\n';
280 if (fgets(buf, MAXLINE, fp) == NULL)
281 return(-1);
282 if (buf[buf[0]=='\r'] == '\n') /* end of header? */
283 return(rtotal);
284 if (buf[MAXLINE-2] != '\n') {
285 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
286 buf[MAXLINE-2] = '\0';
287 }
288 if (f != NULL && (rval = (*f)(buf, p)) < 0)
289 return(-1);
290 rtotal += rval;
291 }
292 }
293
294
295 struct check {
296 FILE *fp;
297 char fs[MAXFMTLEN];
298 };
299
300
301 static int
302 mycheck( /* check a header line for format info. */
303 char *s,
304 void *cp
305 )
306 {
307 struct check *scp = (struct check *)cp;
308
309 if (!formatval(scp->fs, s) && scp->fp != NULL)
310 return(fputs(s, scp->fp));
311
312 return(0);
313 }
314
315
316 int
317 globmatch( /* check for match of s against pattern p */
318 const char *p,
319 const char *s
320 )
321 {
322 int setmatch;
323
324 do {
325 switch (*p) {
326 case '?': /* match any character */
327 if (!*s++)
328 return(0);
329 break;
330 case '*': /* match any string */
331 while (p[1] == '*') p++;
332 do
333 if ( (p[1]=='?') | (p[1]==*s) &&
334 globmatch(p+1,s) )
335 return(1);
336 while (*s++);
337 return(0);
338 case '[': /* character set */
339 setmatch = *s == *++p;
340 if (!*p)
341 return(0);
342 while (*++p != ']') {
343 if (!*p)
344 return(0);
345 if (*p == '-') {
346 setmatch += (p[-1] <= *s && *s <= p[1]);
347 if (!*++p)
348 break;
349 } else
350 setmatch += (*p == *s);
351 }
352 if (!setmatch)
353 return(0);
354 s++;
355 break;
356 case '\\': /* literal next */
357 p++;
358 /* fall through */
359 default: /* normal character */
360 if (*p != *s)
361 return(0);
362 s++;
363 break;
364 }
365 } while (*p++);
366 return(1);
367 }
368
369
370 /*
371 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
372 * matches the specification in fmt, 0 if no input format was found,
373 * and -1 if the input format does not match or there is an
374 * error reading the header. If fmt is empty, then -1 is returned
375 * if any input format is found (or there is an error), and 0 otherwise.
376 * If fmt contains any '*' or '?' characters, then checkheader
377 * does wildcard expansion and copies a matching result into fmt.
378 * Be sure that fmt is big enough to hold the match in such cases,
379 * and that it is not a static, read-only string!
380 * The input header (minus any format lines) is copied to fout
381 * if fout is not NULL.
382 */
383
384 int
385 checkheader(
386 FILE *fin,
387 char fmt[MAXFMTLEN],
388 FILE *fout
389 )
390 {
391 struct check cdat;
392 char *cp;
393
394 cdat.fp = fout;
395 cdat.fs[0] = '\0';
396 if (getheader(fin, mycheck, &cdat) < 0)
397 return(-1);
398 if (!cdat.fs[0])
399 return(0);
400 for (cp = fmt; *cp; cp++) /* check for globbing */
401 if ((*cp == '?') | (*cp == '*')) {
402 if (globmatch(fmt, cdat.fs)) {
403 strcpy(fmt, cdat.fs);
404 return(1);
405 } else
406 return(-1);
407 }
408 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
409 }
