root/radiance/ray/src/common/header.c
Revision: 2.35
Committed: Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
2 static const char RCSid[] = "$Id: header.c,v 2.34 2019/06/09 18:22:20 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in rtio.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
19 * globmatch(pat, str) check for glob match of str against pat
20 * checkheader(i,p,o) check header format from i against p and copy to o
21 *
22 * To copy header from input to output, use getheader(fin, fputs, fout)
23 */
24
25 #include "copyright.h"
26
27 #include <ctype.h>
28
29 #include "rtio.h"
30 #include "resolu.h"
31
32 #define MAXLINE 2048
33
34 extern time_t timegm(struct tm *tm);
35
36 const char HDRSTR[] = "#?"; /* information header magic number */
37
38 const char FMTSTR[] = "FORMAT="; /* format identifier */
39
40 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
41 const char GMTSTR[] = "GMT="; /* GMT identifier */
42
43 static gethfunc mycheck;
44
45
46 void
47 newheader( /* identifying line of information header */
48 const char *s,
49 FILE *fp
50 )
51 {
52 fputs(HDRSTR, fp);
53 fputs(s, fp);
54 putc('\n', fp);
55 }
56
57
58 int
59 headidval( /* get header id (return true if is id) */
60 char *r,
61 const char *s
62 )
63 {
64 const char *cp = HDRSTR;
65
66 while (*cp) if (*cp++ != *s++) return(0);
67 if (r == NULL) return(1);
68 while (*s && !isspace(*s)) *r++ = *s++;
69 *r = '\0';
70 return(1);
71 }
72
73
74 int
75 dateval( /* convert capture date line to UTC */
76 time_t *tloc,
77 const char *s
78 )
79 {
80 struct tm tms;
81 const char *cp = TMSTR;
82
83 while (*cp) if (*cp++ != *s++) return(0);
84 while (isspace(*s)) s++;
85 if (!*s) return(0);
86 if (sscanf(s, "%d:%d:%d %d:%d:%d",
87 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
88 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
89 return(0);
90 if (tloc == NULL)
91 return(1);
92 tms.tm_mon--;
93 tms.tm_year -= 1900;
94 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
95 *tloc = mktime(&tms);
96 return(1);
97 }
98
99
100 int
101 gmtval( /* convert GMT date line to UTC */
102 time_t *tloc,
103 const char *s
104 )
105 {
106 struct tm tms;
107 const char *cp = GMTSTR;
108
109 while (*cp) if (*cp++ != *s++) return(0);
110 while (isspace(*s)) s++;
111 if (!*s) return(0);
112 if (sscanf(s, "%d:%d:%d %d:%d:%d",
113 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
114 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
115 return(0);
116 if (tloc == NULL)
117 return(1);
118 tms.tm_mon--;
119 tms.tm_year -= 1900;
120 *tloc = timegm(&tms);
121 return(1);
122 }
123
124
125 void
126 fputdate( /* write out the given time value (local & GMT) */
127 time_t tv,
128 FILE *fp
129 )
130 {
131 struct tm *tms;
132
133 tms = localtime(&tv);
134 if (tms != NULL)
135 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
136 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
137 tms->tm_hour, tms->tm_min, tms->tm_sec);
138 tms = gmtime(&tv);
139 if (tms != NULL)
140 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
141 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
142 tms->tm_hour, tms->tm_min, tms->tm_sec);
143 }
144
145
146 void
147 fputnow( /* write out the current time */
148 FILE *fp
149 )
150 {
151 time_t tv;
152 time(&tv);
153 fputdate(tv, fp);
154 }
155
156
157 void
158 printargs( /* print arguments to a file */
159 int ac,
160 char **av,
161 FILE *fp
162 )
163 {
164 while (ac-- > 0) {
165 fputword(*av++, fp);
166 fputc(ac ? ' ' : '\n', fp);
167 }
168 }
169
170
171 int
172 formatval( /* get format value (return true if format) */
173 char fmt[MAXFMTLEN],
174 const char *s
175 )
176 {
177 const char *cp = FMTSTR;
178 char *r = fmt;
179
180 while (*cp) if (*cp++ != *s++) return(0);
181 while (isspace(*s)) s++;
182 if (!*s) return(0);
183 if (r == NULL) return(1);
184 do
185 *r++ = *s++;
186 while (*s && !isspace(*s) && r-fmt < MAXFMTLEN-1);
187 *r = '\0';
188 return(1);
189 }
190
191
192 void
193 fputformat( /* put out a format value */
194 const char *s,
195 FILE *fp
196 )
197 {
198 fputs(FMTSTR, fp);
199 fputs(s, fp);
200 putc('\n', fp);
201 }
202
203
204 int
205 getheader( /* get header from file */
206 FILE *fp,
207 gethfunc *f,
208 void *p
209 )
210 {
211 int rtotal = 0;
212 char buf[MAXLINE];
213 int firstc = fgetc(fp);
214
215 if (!isprint(firstc))
216 return(-1); /* messed up */
217 ungetc(firstc, fp);
218 for ( ; ; ) {
219 int rval = 0;
220 buf[MAXLINE-2] = '\n';
221 if (fgets(buf, MAXLINE, fp) == NULL)
222 return(-1);
223 if (buf[buf[0]=='\r'] == '\n') /* end of header? */
224 return(rtotal);
225 if (buf[MAXLINE-2] != '\n') {
226 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
227 buf[MAXLINE-2] = '\0';
228 }
229 if (f != NULL && (rval = (*f)(buf, p)) < 0)
230 return(-1);
231 rtotal += rval;
232 }
233 }
234
235
236 struct check {
237 FILE *fp;
238 char fs[MAXFMTLEN];
239 };
240
241
242 static int
243 mycheck( /* check a header line for format info. */
244 char *s,
245 void *cp
246 )
247 {
248 struct check *scp = (struct check *)cp;
249
250 if (!formatval(scp->fs, s) && scp->fp != NULL)
251 fputs(s, scp->fp);
252
253 return(0);
254 }
255
256
257 int
258 globmatch( /* check for match of s against pattern p */
259 const char *p,
260 const char *s
261 )
262 {
263 int setmatch;
264
265 do {
266 switch (*p) {
267 case '?': /* match any character */
268 if (!*s++)
269 return(0);
270 break;
271 case '*': /* match any string */
272 while (p[1] == '*') p++;
273 do
274 if ( (p[1]=='?') | (p[1]==*s) &&
275 globmatch(p+1,s) )
276 return(1);
277 while (*s++);
278 return(0);
279 case '[': /* character set */
280 setmatch = *s == *++p;
281 if (!*p)
282 return(0);
283 while (*++p != ']') {
284 if (!*p)
285 return(0);
286 if (*p == '-') {
287 setmatch += (p[-1] <= *s && *s <= p[1]);
288 if (!*++p)
289 break;
290 } else
291 setmatch += (*p == *s);
292 }
293 if (!setmatch)
294 return(0);
295 s++;
296 break;
297 case '\\': /* literal next */
298 p++;
299 /* fall through */
300 default: /* normal character */
301 if (*p != *s)
302 return(0);
303 s++;
304 break;
305 }
306 } while (*p++);
307 return(1);
308 }
309
310
311 /*
312 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
313 * matches the specification in fmt, 0 if no input format was found,
314 * and -1 if the input format does not match or there is an
315 * error reading the header. If fmt is empty, then -1 is returned
316 * if any input format is found (or there is an error), and 0 otherwise.
317 * If fmt contains any '*' or '?' characters, then checkheader
318 * does wildcard expansion and copies a matching result into fmt.
319 * Be sure that fmt is big enough to hold the match in such cases,
320 * and that it is not a static, read-only string!
321 * The input header (minus any format lines) is copied to fout
322 * if fout is not NULL.
323 */
324
325 int
326 checkheader(
327 FILE *fin,
328 char fmt[MAXFMTLEN],
329 FILE *fout
330 )
331 {
332 struct check cdat;
333 char *cp;
334
335 cdat.fp = fout;
336 cdat.fs[0] = '\0';
337 if (getheader(fin, mycheck, &cdat) < 0)
338 return(-1);
339 if (!cdat.fs[0])
340 return(0);
341 for (cp = fmt; *cp; cp++) /* check for globbing */
342 if ((*cp == '?') | (*cp == '*')) {
343 if (globmatch(fmt, cdat.fs)) {
344 strcpy(fmt, cdat.fs);
345 return(1);
346 } else
347 return(-1);
348 }
349 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
350 }
