--- ray/src/common/header.c 1994/02/27 10:16:45 2.4 +++ ray/src/common/header.c 1995/10/15 14:07:58 2.5 @@ -17,6 +17,7 @@ static char SCCSid[] = "$SunId$ LBL"; * formatval(r,s) copy the format value in s to r * fputformat(s,fp) write "FORMAT=%s" to fp * getheader(fp,f,p) read header from fp, calling f(s,p) on each line + * copymatch(pat, str) copy str into pat if glob match * checkheader(i,p,o) check header format from i against p and copy to o * * To copy header from input to output, use getheader(fin, fputs, fout) @@ -48,6 +49,7 @@ register FILE *fp; } +int headidval(r,s) /* get header id (return true if is id) */ register char *r, *s; { @@ -61,6 +63,7 @@ register char *r, *s; } +int isheadid(s) /* check to see if line is header id */ char *s; { @@ -92,6 +95,7 @@ register FILE *fp; } +int formatval(r, s) /* get format value (return true if format) */ register char *r; register char *s; @@ -102,13 +106,15 @@ register char *s; while (isspace(*s)) s++; if (!*s) return(0); if (r == NULL) return(1); - while(*s) *r++ = *s++; - while (isspace(r[-1])) r--; + do + *r++ = *s++; + while(*s && !isspace(*s)); *r = '\0'; return(1); } +int isformat(s) /* is line a format line? */ char *s; { @@ -126,6 +132,7 @@ FILE *fp; } +int getheader(fp, f, p) /* get header from file */ FILE *fp; int (*f)(); @@ -174,7 +181,7 @@ register struct check *cp; * copies str into pat if there is a match (returning true). */ -#ifdef COPYMATCH +int copymatch(pat, str) char *pat, *str; { @@ -212,9 +219,6 @@ char *pat, *str; strcpy(pat, str); return(1); } -#else -#define copymatch(pat, s) (!strcmp(pat, s)) -#endif /* @@ -230,6 +234,7 @@ char *pat, *str; * if fout is not NULL. */ +int checkheader(fin, fmt, fout) FILE *fin; char *fmt;
