root/radiance/ray/src/common/header.c
Revision: 2.30
Committed: Sun May 7 16:14:19 2017 UTC (8 years, 1 month ago) by greg
Changes since 2.29: +6 -3 lines
Chagned getheader() to return total of non-negative return values from callback
2 static const char RCSid[] = "$Id: header.c,v 2.29 2014/05/30 23:43:48 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
19 * globmatch(pat, str) check for glob match of str against pat
20 * checkheader(i,p,o) check header format from i against p and copy to o
21 *
22 * To copy header from input to output, use getheader(fin, fputs, fout)
23 */
24
25 #include "copyright.h"
26
27 #include <ctype.h>
28
29 #include "rtio.h"
30 #include "resolu.h"
31
32 #define MAXLINE 2048
33
34 extern time_t timegm(struct tm *tm);
35
36 const char HDRSTR[] = "#?"; /* information header magic number */
37
38 const char FMTSTR[] = "FORMAT="; /* format identifier */
39
40 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
41 const char GMTSTR[] = "GMT="; /* GMT identifier */
42
43 static gethfunc mycheck;
44
45
46 void
47 newheader( /* identifying line of information header */
48 char *s,
49 FILE *fp
50 )
51 {
52 fputs(HDRSTR, fp);
53 fputs(s, fp);
54 putc('\n', fp);
55 }
56
57
58 int
59 headidval( /* get header id (return true if is id) */
60 char *r,
61 char *s
62 )
63 {
64 const char *cp = HDRSTR;
65
66 while (*cp) if (*cp++ != *s++) return(0);
67 if (r == NULL) return(1);
68 while (*s && !isspace(*s)) *r++ = *s++;
69 *r = '\0';
70 return(1);
71 }
72
73
74 int
75 dateval( /* convert capture date line to UTC */
76 time_t *tloc,
77 char *s
78 )
79 {
80 struct tm tms;
81 const char *cp = TMSTR;
82
83 while (*cp) if (*cp++ != *s++) return(0);
84 while (isspace(*s)) s++;
85 if (!*s) return(0);
86 if (sscanf(s, "%d:%d:%d %d:%d:%d",
87 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
88 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
89 return(0);
90 if (tloc == NULL)
91 return(1);
92 tms.tm_mon--;
93 tms.tm_year -= 1900;
94 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
95 *tloc = mktime(&tms);
96 return(1);
97 }
98
99
100 int
101 gmtval( /* convert GMT date line to UTC */
102 time_t *tloc,
103 char *s
104 )
105 {
106 struct tm tms;
107 const char *cp = GMTSTR;
108
109 while (*cp) if (*cp++ != *s++) return(0);
110 while (isspace(*s)) s++;
111 if (!*s) return(0);
112 if (sscanf(s, "%d:%d:%d %d:%d:%d",
113 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
114 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
115 return(0);
116 if (tloc == NULL)
117 return(1);
118 tms.tm_mon--;
119 tms.tm_year -= 1900;
120 *tloc = timegm(&tms);
121 return(1);
122 }
123
124
125 void
126 fputdate( /* write out the given time value (local & GMT) */
127 time_t tv,
128 FILE *fp
129 )
130 {
131 struct tm *tms;
132
133 tms = localtime(&tv);
134 if (tms != NULL)
135 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
136 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
137 tms->tm_hour, tms->tm_min, tms->tm_sec);
138 tms = gmtime(&tv);
139 if (tms != NULL)
140 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
141 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
142 tms->tm_hour, tms->tm_min, tms->tm_sec);
143 }
144
145
146 void
147 fputnow( /* write out the current time */
148 FILE *fp
149 )
150 {
151 time_t tv;
152 time(&tv);
153 fputdate(tv, fp);
154 }
155
156
157 void
158 printargs( /* print arguments to a file */
159 int ac,
160 char **av,
161 FILE *fp
162 )
163 {
164 while (ac-- > 0) {
165 fputword(*av++, fp);
166 fputc(ac ? ' ' : '\n', fp);
167 }
168 }
169
170
171 int
172 formatval( /* get format value (return true if format) */
173 char *r,
174 char *s
175 )
176 {
177 const char *cp = FMTSTR;
178
179 while (*cp) if (*cp++ != *s++) return(0);
180 while (isspace(*s)) s++;
181 if (!*s) return(0);
182 if (r == NULL) return(1);
183 do
184 *r++ = *s++;
185 while (*s && !isspace(*s));
186 *r = '\0';
187 return(1);
188 }
189
190
191 void
192 fputformat( /* put out a format value */
193 char *s,
194 FILE *fp
195 )
196 {
197 fputs(FMTSTR, fp);
198 fputs(s, fp);
199 putc('\n', fp);
200 }
201
202
203 int
204 getheader( /* get header from file */
205 FILE *fp,
206 gethfunc *f,
207 void *p
208 )
209 {
210 int rtotal = 0;
211 char buf[MAXLINE];
212
213 for ( ; ; ) {
214 int rval = 0;
215 buf[MAXLINE-2] = '\n';
216 if (fgets(buf, MAXLINE, fp) == NULL)
217 return(-1);
218 if (buf[buf[0]=='\r'] == '\n')
219 return(rtotal);
220 if (buf[MAXLINE-2] != '\n') {
221 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
222 buf[MAXLINE-2] = '\0';
223 }
224 if (f != NULL && (rval = (*f)(buf, p)) < 0)
225 return(-1);
226 rtotal += rval;
227 }
228 }
229
230
231 struct check {
232 FILE *fp;
233 char fs[64];
234 };
235
236
237 static int
238 mycheck( /* check a header line for format info. */
239 char *s,
240 void *cp
241 )
242 {
243 if (!formatval(((struct check*)cp)->fs, s)
244 && ((struct check*)cp)->fp != NULL) {
245 fputs(s, ((struct check*)cp)->fp);
246 }
247 return(0);
248 }
249
250
251 int
252 globmatch( /* check for match of s against pattern p */
253 char *p,
254 char *s
255 )
256 {
257 int setmatch;
258
259 do {
260 switch (*p) {
261 case '?': /* match any character */
262 if (!*s++)
263 return(0);
264 break;
265 case '*': /* match any string */
266 while (p[1] == '*') p++;
267 do
268 if ( (p[1]=='?') | (p[1]==*s) &&
269 globmatch(p+1,s) )
270 return(1);
271 while (*s++);
272 return(0);
273 case '[': /* character set */
274 setmatch = *s == *++p;
275 if (!*p)
276 return(0);
277 while (*++p != ']') {
278 if (!*p)
279 return(0);
280 if (*p == '-') {
281 setmatch += (p[-1] <= *s && *s <= p[1]);
282 if (!*++p)
283 break;
284 } else
285 setmatch += (*p == *s);
286 }
287 if (!setmatch)
288 return(0);
289 s++;
290 break;
291 case '\\': /* literal next */
292 p++;
293 /* fall through */
294 default: /* normal character */
295 if (*p != *s)
296 return(0);
297 s++;
298 break;
299 }
300 } while (*p++);
301 return(1);
302 }
303
304
305 /*
306 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
307 * matches the specification in fmt, 0 if no input format was found,
308 * and -1 if the input format does not match or there is an
309 * error reading the header. If fmt is empty, then -1 is returned
310 * if any input format is found (or there is an error), and 0 otherwise.
311 * If fmt contains any '*' or '?' characters, then checkheader
312 * does wildcard expansion and copies a matching result into fmt.
313 * Be sure that fmt is big enough to hold the match in such cases,
314 * and that it is not a static, read-only string!
315 * The input header (minus any format lines) is copied to fout
316 * if fout is not NULL.
317 */
318
319 int
320 checkheader(
321 FILE *fin,
322 char *fmt,
323 FILE *fout
324 )
325 {
326 struct check cdat;
327 char *cp;
328
329 cdat.fp = fout;
330 cdat.fs[0] = '\0';
331 if (getheader(fin, mycheck, &cdat) < 0)
332 return(-1);
333 if (!cdat.fs[0])
334 return(0);
335 for (cp = fmt; *cp; cp++) /* check for globbing */
336 if ((*cp == '?') | (*cp == '*')) {
337 if (globmatch(fmt, cdat.fs)) {
338 strcpy(fmt, cdat.fs);
339 return(1);
340 } else
341 return(-1);
342 }
343 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
344 }
