root/radiance/ray/src/common/header.c
Revision: 2.25
Committed: Thu May 21 18:08:43 2009 UTC (16 years, 1 month ago) by greg
Changes since 2.24: +52 -49 lines
2 static const char RCSid[] = "$Id: header.c,v 2.24 2009/03/12 18:37:24 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
19 * globmatch(pat, str) check for glob match of str against pat
20 * checkheader(i,p,o) check header format from i against p and copy to o
21 *
22 * To copy header from input to output, use getheader(fin, fputs, fout)
23 */
24
25 #include "copyright.h"
26
27 #include <ctype.h>
28
29 #include "rtio.h"
30 #include "resolu.h"
31
32 #define MAXLINE 2048
33
34 const char HDRSTR[] = "#?"; /* information header magic number */
35
36 const char FMTSTR[] = "FORMAT="; /* format identifier */
37
38 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
39 const char GMTSTR[] = "GMT="; /* GMT identifier */
40
41 static gethfunc mycheck;
42
43
44 extern void
45 newheader( /* identifying line of information header */
46 char *s,
47 FILE *fp
48 )
49 {
50 fputs(HDRSTR, fp);
51 fputs(s, fp);
52 putc('\n', fp);
53 }
54
55
56 extern int
57 headidval( /* get header id (return true if is id) */
58 char *r,
59 char *s
60 )
61 {
62 const char *cp = HDRSTR;
63
64 while (*cp) if (*cp++ != *s++) return(0);
65 if (r == NULL) return(1);
66 while (*s && !isspace(*s)) *r++ = *s++;
67 *r = '\0';
68 return(1);
69 }
70
71
72 extern int
73 dateval( /* convert capture date line to UTC */
74 time_t *tloc,
75 char *s
76 )
77 {
78 struct tm tms;
79 const char *cp = TMSTR;
80
81 while (*cp) if (*cp++ != *s++) return(0);
82 while (isspace(*s)) s++;
83 if (!*s) return(0);
84 if (sscanf(s, "%d:%d:%d %d:%d:%d",
85 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
86 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
87 return(0);
88 if (tloc == NULL)
89 return(1);
90 tms.tm_mon--;
91 tms.tm_year -= 1900;
92 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
93 *tloc = mktime(&tms);
94 return(1);
95 }
96
97
98 extern int
99 gmtval( /* convert GMT date line to UTC */
100 time_t *tloc,
101 char *s
102 )
103 {
104 struct tm tms;
105 const char *cp = GMTSTR;
106
107 while (*cp) if (*cp++ != *s++) return(0);
108 while (isspace(*s)) s++;
109 if (!*s) return(0);
110 if (sscanf(s, "%d:%d:%d %d:%d:%d",
111 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
112 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
113 return(0);
114 if (tloc == NULL)
115 return(1);
116 tms.tm_mon--;
117 tms.tm_year -= 1900;
118 *tloc = timegm(&tms);
119 return(1);
120 }
121
122
123 extern void
124 fputdate( /* write out the given time value (local & GMT) */
125 time_t tv,
126 FILE *fp
127 )
128 {
129 struct tm *tms;
130
131 tms = localtime(&tv);
132 if (tms != NULL)
133 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
134 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
135 tms->tm_hour, tms->tm_min, tms->tm_sec);
136 tms = gmtime(&tv);
137 if (tms != NULL)
138 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
139 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
140 tms->tm_hour, tms->tm_min, tms->tm_sec);
141 }
142
143
144 extern void
145 fputnow( /* write out the current time */
146 FILE *fp
147 )
148 {
149 time_t tv;
150 time(&tv);
151 fputdate(tv, fp);
152 }
153
154
155 extern void
156 printargs( /* print arguments to a file */
157 int ac,
158 char **av,
159 FILE *fp
160 )
161 {
162 while (ac-- > 0) {
163 fputword(*av++, fp);
164 fputc(ac ? ' ' : '\n', fp);
165 }
166 }
167
168
169 extern int
170 formatval( /* get format value (return true if format) */
171 char *r,
172 char *s
173 )
174 {
175 const char *cp = FMTSTR;
176
177 while (*cp) if (*cp++ != *s++) return(0);
178 while (isspace(*s)) s++;
179 if (!*s) return(0);
180 if (r == NULL) return(1);
181 do
182 *r++ = *s++;
183 while(*s && !isspace(*s));
184 *r = '\0';
185 return(1);
186 }
187
188
189 extern void
190 fputformat( /* put out a format value */
191 char *s,
192 FILE *fp
193 )
194 {
195 fputs(FMTSTR, fp);
196 fputs(s, fp);
197 putc('\n', fp);
198 }
199
200
201 extern int
202 getheader( /* get header from file */
203 FILE *fp,
204 gethfunc *f,
205 void *p
206 )
207 {
208 char buf[MAXLINE];
209
210 for ( ; ; ) {
211 buf[MAXLINE-2] = '\n';
212 if (fgets(buf, MAXLINE, fp) == NULL)
213 return(-1);
214 if (buf[0] == '\n')
215 return(0);
216 #ifdef MSDOS
217 if (buf[0] == '\r' && buf[1] == '\n')
218 return(0);
219 #endif
220 if (buf[MAXLINE-2] != '\n') {
221 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
222 buf[MAXLINE-2] = '\0';
223 }
224 if (f != NULL && (*f)(buf, p) < 0)
225 return(-1);
226 }
227 }
228
229
230 struct check {
231 FILE *fp;
232 char fs[64];
233 };
234
235
236 static int
237 mycheck( /* check a header line for format info. */
238 char *s,
239 void *cp
240 )
241 {
242 if (!formatval(((struct check*)cp)->fs, s)
243 && ((struct check*)cp)->fp != NULL) {
244 fputs(s, ((struct check*)cp)->fp);
245 }
246 return(0);
247 }
248
249
250 extern int
251 globmatch( /* check for match of s against pattern p */
252 char *p,
253 char *s
254 )
255 {
256 int setmatch;
257
258 do {
259 switch (*p) {
260 case '?': /* match any character */
261 if (!*s++)
262 return(0);
263 break;
264 case '*': /* match any string */
265 while (p[1] == '*') p++;
266 do
267 if ( (p[1]=='?' || p[1]==*s) &&
268 globmatch(p+1,s) )
269 return(1);
270 while (*s++);
271 return(0);
272 case '[': /* character set */
273 setmatch = *s == *++p;
274 if (!*p)
275 return(0);
276 while (*++p != ']') {
277 if (!*p)
278 return(0);
279 if (*p == '-') {
280 setmatch += p[-1] <= *s && *s <= p[1];
281 if (!*++p)
282 break;
283 } else
284 setmatch += *p == *s;
285 }
286 if (!setmatch)
287 return(0);
288 s++;
289 break;
290 case '\\': /* literal next */
291 p++;
292 /* fall through */
293 default: /* normal character */
294 if (*p != *s)
295 return(0);
296 s++;
297 break;
298 }
299 } while (*p++);
300 return(1);
301 }
302
303
304 /*
305 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
306 * matches the specification in fmt, 0 if no input format was found,
307 * and -1 if the input format does not match or there is an
308 * error reading the header. If fmt is empty, then -1 is returned
309 * if any input format is found (or there is an error), and 0 otherwise.
310 * If fmt contains any '*' or '?' characters, then checkheader
311 * does wildcard expansion and copies a matching result into fmt.
312 * Be sure that fmt is big enough to hold the match in such cases,
313 * and that it is not a static, read-only string!
314 * The input header (minus any format lines) is copied to fout
315 * if fout is not NULL.
316 */
317
318 extern int
319 checkheader(
320 FILE *fin,
321 char *fmt,
322 FILE *fout
323 )
324 {
325 struct check cdat;
326 char *cp;
327
328 cdat.fp = fout;
329 cdat.fs[0] = '\0';
330 if (getheader(fin, mycheck, &cdat) < 0)
331 return(-1);
332 if (!cdat.fs[0])
333 return(0);
334 for (cp = fmt; *cp; cp++) /* check for globbing */
335 if ((*cp == '?') | (*cp == '*')) {
336 if (globmatch(fmt, cdat.fs)) {
337 strcpy(fmt, cdat.fs);
338 return(1);
339 } else
340 return(-1);
341 }
342 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
343 }
