root/radiance/ray/src/common/header.c
Revision: 2.22
Committed: Fri Jan 2 11:35:17 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.21: +81 -62 lines
2 static const char RCSid[] = "$Id: header.c,v 2.21 2003/07/30 10:11:06 schorsch Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * isheadid(s) returns true if s is a header id line
11 * headidval(r,s) copy header identifier value in s to r
12 * dateval(t,s) get capture date value
13 * isdate(s) returns true if s is a date line
14 * fputdate(t,fp) put out the given capture date and time
15 * fputnow(fp) put out the current date and time
16 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
17 * isformat(s) returns true if s is of the form "FORMAT=*"
18 * formatval(r,s) copy the format value in s to r
19 * fputformat(s,fp) write "FORMAT=%s" to fp
20 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
21 * globmatch(pat, str) check for glob match of str against pat
22 * checkheader(i,p,o) check header format from i against p and copy to o
23 *
24 * To copy header from input to output, use getheader(fin, fputs, fout)
25 */
26
27 #include "copyright.h"
28
29 #include <time.h>
30 #include <ctype.h>
31
32 #include "rtio.h"
33 #include "resolu.h"
34
35 #define MAXLINE 512
36
37 char HDRSTR[] = "#?"; /* information header magic number */
38
39 char FMTSTR[] = "FORMAT="; /* format identifier */
40
41 char TMSTR[] = "CAPDATE="; /* capture date identifier */
42
43 static gethfunc mycheck;
44
45
46 extern void
47 newheader( /* identifying line of information header */
48 char *s,
49 register FILE *fp
50 )
51 {
52 fputs(HDRSTR, fp);
53 fputs(s, fp);
54 putc('\n', fp);
55 }
56
57
58 extern int
59 headidval( /* get header id (return true if is id) */
60 register char *r,
61 register char *s
62 )
63 {
64 register char *cp = HDRSTR;
65
66 while (*cp) if (*cp++ != *s++) return(0);
67 if (r == NULL) return(1);
68 while (*s && !isspace(*s)) *r++ = *s++;
69 *r = '\0';
70 return(1);
71 }
72
73
74 extern int
75 isheadid( /* check to see if line is header id */
76 char *s
77 )
78 {
79 return(headidval(NULL, s));
80 }
81
82
83 extern int
84 dateval( /* get capture date value */
85 time_t *tloc,
86 char *s
87 )
88 {
89 struct tm tms;
90 register char *cp = TMSTR;
91
92 while (*cp) if (*cp++ != *s++) return(0);
93 while (isspace(*s)) s++;
94 if (!*s) return(0);
95 if (sscanf(s, "%d:%d:%d %d:%d:%d",
96 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
97 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
98 return(0);
99 if (tloc == NULL)
100 return(1);
101 tms.tm_mon--;
102 tms.tm_year -= 1900;
103 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
104 *tloc = mktime(&tms);
105 return(1);
106 }
107
108
109 extern int
110 isdate( /* is the given line a capture date? */
111 char *s
112 )
113 {
114 return(dateval(NULL, s));
115 }
116
117
118 extern void
119 fputdate( /* write out the given time value */
120 time_t tv,
121 FILE *fp
122 )
123 {
124 struct tm *tm = localtime(&tv);
125 if (tm == NULL)
126 return;
127 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
128 tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday,
129 tm->tm_hour, tm->tm_min, tm->tm_sec);
130 }
131
132
133 extern void
134 fputnow( /* write out the current time */
135 FILE *fp
136 )
137 {
138 time_t tv;
139 time(&tv);
140 fputdate(tv, fp);
141 }
142
143
144 extern void
145 printargs( /* print arguments to a file */
146 int ac,
147 char **av,
148 FILE *fp
149 )
150 {
151 while (ac-- > 0) {
152 fputword(*av++, fp);
153 fputc(ac ? ' ' : '\n', fp);
154 }
155 }
156
157
158 extern int
159 formatval( /* get format value (return true if format) */
160 register char *r,
161 register char *s
162 )
163 {
164 register char *cp = FMTSTR;
165
166 while (*cp) if (*cp++ != *s++) return(0);
167 while (isspace(*s)) s++;
168 if (!*s) return(0);
169 if (r == NULL) return(1);
170 do
171 *r++ = *s++;
172 while(*s && !isspace(*s));
173 *r = '\0';
174 return(1);
175 }
176
177
178 extern int
179 isformat( /* is line a format line? */
180 char *s
181 )
182 {
183 return(formatval(NULL, s));
184 }
185
186
187 extern void
188 fputformat( /* put out a format value */
189 char *s,
190 FILE *fp
191 )
192 {
193 fputs(FMTSTR, fp);
194 fputs(s, fp);
195 putc('\n', fp);
196 }
197
198
199 extern int
200 getheader( /* get header from file */
201 FILE *fp,
202 gethfunc *f,
203 void *p
204 )
205 {
206 char buf[MAXLINE];
207
208 for ( ; ; ) {
209 buf[MAXLINE-2] = '\n';
210 if (fgets(buf, MAXLINE, fp) == NULL)
211 return(-1);
212 if (buf[0] == '\n')
213 return(0);
214 #ifdef MSDOS
215 if (buf[0] == '\r' && buf[1] == '\n')
216 return(0);
217 #endif
218 if (buf[MAXLINE-2] != '\n') {
219 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
220 buf[MAXLINE-2] = '\0';
221 }
222 if (f != NULL && (*f)(buf, p) < 0)
223 return(-1);
224 }
225 }
226
227
228 struct check {
229 FILE *fp;
230 char fs[64];
231 };
232
233
234 static int
235 mycheck( /* check a header line for format info. */
236 char *s,
237 void *cp
238 )
239 {
240 if (!formatval(((struct check*)cp)->fs, s)
241 && ((struct check*)cp)->fp != NULL) {
242 fputs(s, ((struct check*)cp)->fp);
243 }
244 return(0);
245 }
246
247
248 extern int
249 globmatch( /* check for match of s against pattern p */
250 register char *p,
251 register char *s
252 )
253 {
254 int setmatch;
255
256 do {
257 switch (*p) {
258 case '?': /* match any character */
259 if (!*s++)
260 return(0);
261 break;
262 case '*': /* match any string */
263 while (p[1] == '*') p++;
264 do
265 if ( (p[1]=='?' || p[1]==*s) &&
266 globmatch(p+1,s) )
267 return(1);
268 while (*s++);
269 return(0);
270 case '[': /* character set */
271 setmatch = *s == *++p;
272 if (!*p)
273 return(0);
274 while (*++p != ']') {
275 if (!*p)
276 return(0);
277 if (*p == '-') {
278 setmatch += p[-1] <= *s && *s <= p[1];
279 if (!*++p)
280 break;
281 } else
282 setmatch += *p == *s;
283 }
284 if (!setmatch)
285 return(0);
286 s++;
287 break;
288 case '\\': /* literal next */
289 p++;
290 /* fall through */
291 default: /* normal character */
292 if (*p != *s)
293 return(0);
294 s++;
295 break;
296 }
297 } while (*p++);
298 return(1);
299 }
300
301
302 /*
303 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
304 * matches the specification in fmt, 0 if no input format was found,
305 * and -1 if the input format does not match or there is an
306 * error reading the header. If fmt is empty, then -1 is returned
307 * if any input format is found (or there is an error), and 0 otherwise.
308 * If fmt contains any '*' or '?' characters, then checkheader
309 * does wildcard expansion and copies a matching result into fmt.
310 * Be sure that fmt is big enough to hold the match in such cases,
311 * and that it is not a static, read-only string!
312 * The input header (minus any format lines) is copied to fout
313 * if fout is not NULL.
314 */
315
316 extern int
317 checkheader(
318 FILE *fin,
319 char *fmt,
320 FILE *fout
321 )
322 {
323 struct check cdat;
324 register char *cp;
325
326 cdat.fp = fout;
327 cdat.fs[0] = '\0';
328 if (getheader(fin, mycheck, &cdat) < 0)
329 return(-1);
330 if (!cdat.fs[0])
331 return(0);
332 for (cp = fmt; *cp; cp++) /* check for globbing */
333 if ((*cp == '?') | (*cp == '*')) {
334 if (globmatch(fmt, cdat.fs)) {
335 strcpy(fmt, cdat.fs);
336 return(1);
337 } else
338 return(-1);
339 }
340 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
341 }
