root/Development/ray/src/common/header.c
Revision: 1.4
Committed: Mon Apr 22 08:23:10 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.3: +3 -5 lines
minor change to checkheader.c
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * header.c - routines for reading and writing information headers.
9 *
10 * 8/19/88
11 *
12 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
13 * isformat(s) returns true if s is of the form "FORMAT=*"
14 * formatval(r,s) copy the format value in s to r
15 * fputformat(s,fp) write "FORMAT=%s" to fp
16 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
17 * checkheader(i,p,o) check header format from i against p and copy to o
18 *
19 * To copy header from input to output, use getheader(fin, fputs, fout)
20 */
21
22 #include <stdio.h>
23 #include <ctype.h>
24
25 #define MAXLINE 512
26
27 char FMTSTR[] = "FORMAT=";
28 int FMTSTRL = 7;
29
30
31 printargs(ac, av, fp) /* print arguments to a file */
32 int ac;
33 char **av;
34 FILE *fp;
35 {
36 while (ac-- > 0) {
37 fputs(*av++, fp);
38 putc(' ', fp);
39 }
40 putc('\n', fp);
41 }
42
43
44 isformat(s) /* is line a format line? */
45 char *s;
46 {
47 return(!strncmp(s,FMTSTR,FMTSTRL));
48 }
49
50
51 formatval(r, s) /* return format value */
52 register char *r;
53 register char *s;
54 {
55 s += FMTSTRL;
56 while (isspace(*s)) s++;
57 if (!*s) { *r = '\0'; return; }
58 while(*s) *r++ = *s++;
59 while (isspace(r[-1])) r--;
60 *r = '\0';
61 }
62
63
64 fputformat(s, fp) /* put out a format value */
65 char *s;
66 FILE *fp;
67 {
68 fputs(FMTSTR, fp);
69 fputs(s, fp);
70 putc('\n', fp);
71 }
72
73
74 getheader(fp, f, p) /* get header from file */
75 FILE *fp;
76 int (*f)();
77 char *p;
78 {
79 char buf[MAXLINE];
80
81 for ( ; ; ) {
82 buf[MAXLINE-2] = '\n';
83 if (fgets(buf, sizeof(buf), fp) == NULL)
84 return(-1);
85 if (buf[0] == '\n')
86 return(0);
87 if (buf[MAXLINE-2] != '\n') {
88 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
89 buf[MAXLINE-2] = '\0';
90 }
91 if (f != NULL)
92 (*f)(buf, p);
93 }
94 }
95
96
97 struct check {
98 FILE *fp;
99 char fs[64];
100 };
101
102
103 static
104 mycheck(s, cp) /* check a header line for format info. */
105 char *s;
106 register struct check *cp;
107 {
108 if (!strncmp(s,FMTSTR,FMTSTRL))
109 formatval(cp->fs, s);
110 else if (cp->fp != NULL) /* don't copy format info. */
111 fputs(s, cp->fp);
112 }
113
114
115 /*
116 * Copymatch(pat,str) checks pat for wildcards, and
117 * copies str into pat if there is a match (returning true).
118 */
119
120 #ifdef COPYMATCH
121 copymatch(pat, str)
122 char *pat, *str;
123 {
124 int docopy = 0;
125 register char *p = pat, *s = str;
126
127 do {
128 switch (*p) {
129 case '?': /* match any character */
130 if (!*s++)
131 return(0);
132 docopy++;
133 break;
134 case '*': /* match any string */
135 while (p[1] == '*') p++;
136 do
137 if ( (p[1]=='?' || p[1]==*s)
138 && copymatch(p+1,s) ) {
139 strcpy(pat, str);
140 return(1);
141 }
142 while (*s++);
143 return(0);
144 case '\\': /* literal next */
145 p++;
146 /* fall through */
147 default: /* normal character */
148 if (*p != *s)
149 return(0);
150 s++;
151 break;
152 }
153 } while (*p++);
154 if (docopy)
155 strcpy(pat, str);
156 return(1);
157 }
158 #else
159 #define copymatch(pat, s) (!strcmp(pat, s))
160 #endif
161
162
163 /*
164 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
165 * matches the specification in fmt, 0 if no input format was found,
166 * and -1 if the input format does not match or there is an
167 * error reading the header. If fmt is empty, then -1 is returned
168 * if any input format is found (or there is an error), and 0 otherwise.
169 * If fmt contains any '*' or '?' characters, then checkheader
170 * does wildcard expansion and copies a matching result into fmt.
171 * Be sure that fmt is big enough to hold the match in such cases!
172 * The input header (minus any format lines) is copied to fout
173 * if fout is not NULL.
174 */
175
176 checkheader(fin, fmt, fout)
177 FILE *fin;
178 char *fmt;
179 FILE *fout;
180 {
181 struct check cdat;
182
183 cdat.fp = fout;
184 cdat.fs[0] = '\0';
185 if (getheader(fin, mycheck, &cdat) < 0)
186 return(-1);
187 if (cdat.fs[0] != '\0')
188 return(copymatch(fmt, cdat.fs) ? 1 : -1);
189 return(0);
190 }
