root/radiance/ray/src/common/header.c
Revision: 2.8
Committed: Sat Jul 27 07:21:38 1996 UTC (28 years, 11 months ago) by greg
eliminated final space from printargs() output
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * header.c - routines for reading and writing information headers.
9 *
10 * 8/19/88
11 *
12 * newheader(t,fp) start new information header identified by string t
13 * isheadid(s) returns true if s is a header id line
14 * headidval(r,s) copy header identifier value in s to r
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * isformat(s) returns true if s is of the form "FORMAT=*"
17 * formatval(r,s) copy the format value in s to r
18 * fputformat(s,fp) write "FORMAT=%s" to fp
19 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
20 * globmatch(pat, str) check for glob match of str against pat
21 * checkheader(i,p,o) check header format from i against p and copy to o
22 *
23 * To copy header from input to output, use getheader(fin, fputs, fout)
24 */
25
26 #include <stdio.h>
27 #include <ctype.h>
28
29 #define MAXLINE 512
30
31 #ifndef BSD
32 #define index strchr
33 #endif
34
35 extern char *index();
36
37 char HDRSTR[] = "#?"; /* information header magic number */
38
39 char FMTSTR[] = "FORMAT="; /* format identifier */
40
41
42 newheader(s, fp) /* identifying line of information header */
43 char *s;
44 register FILE *fp;
45 {
46 fputs(HDRSTR, fp);
47 fputs(s, fp);
48 putc('\n', fp);
49 }
50
51
52 int
53 headidval(r,s) /* get header id (return true if is id) */
54 register char *r, *s;
55 {
56 register char *cp = HDRSTR;
57
58 while (*cp) if (*cp++ != *s++) return(0);
59 if (r == NULL) return(1);
60 while (*s) *r++ = *s++;
61 *r = '\0';
62 return(1);
63 }
64
65
66 int
67 isheadid(s) /* check to see if line is header id */
68 char *s;
69 {
70 return(headidval(NULL, s));
71 }
72
73
74 printargs(ac, av, fp) /* print arguments to a file */
75 int ac;
76 char **av;
77 register FILE *fp;
78 {
79 int quote;
80
81 while (ac-- > 0) {
82 if (index(*av, ' ') != NULL) { /* quote it */
83 if (index(*av, '\'') != NULL)
84 quote = '"';
85 else
86 quote = '\'';
87 putc(quote, fp);
88 fputs(*av++, fp);
89 putc(quote, fp);
90 } else
91 fputs(*av++, fp);
92 putc(ac ? ' ' : '\n', fp);
93 }
94 }
95
96
97 int
98 formatval(r, s) /* get format value (return true if format) */
99 register char *r;
100 register char *s;
101 {
102 register char *cp = FMTSTR;
103
104 while (*cp) if (*cp++ != *s++) return(0);
105 while (isspace(*s)) s++;
106 if (!*s) return(0);
107 if (r == NULL) return(1);
108 do
109 *r++ = *s++;
110 while(*s && !isspace(*s));
111 *r = '\0';
112 return(1);
113 }
114
115
116 int
117 isformat(s) /* is line a format line? */
118 char *s;
119 {
120 return(formatval(NULL, s));
121 }
122
123
124 fputformat(s, fp) /* put out a format value */
125 char *s;
126 FILE *fp;
127 {
128 fputs(FMTSTR, fp);
129 fputs(s, fp);
130 putc('\n', fp);
131 }
132
133
134 int
135 getheader(fp, f, p) /* get header from file */
136 FILE *fp;
137 int (*f)();
138 char *p;
139 {
140 char buf[MAXLINE];
141
142 for ( ; ; ) {
143 buf[MAXLINE-2] = '\n';
144 if (fgets(buf, MAXLINE, fp) == NULL)
145 return(-1);
146 if (buf[0] == '\n')
147 return(0);
148 #ifdef MSDOS
149 if (buf[0] == '\r' && buf[1] == '\n')
150 return(0);
151 #endif
152 if (buf[MAXLINE-2] != '\n') {
153 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
154 buf[MAXLINE-2] = '\0';
155 }
156 if (f != NULL)
157 (*f)(buf, p);
158 }
159 }
160
161
162 struct check {
163 FILE *fp;
164 char fs[64];
165 };
166
167
168 static
169 mycheck(s, cp) /* check a header line for format info. */
170 char *s;
171 register struct check *cp;
172 {
173 if (!formatval(cp->fs, s) && cp->fp != NULL)
174 fputs(s, cp->fp);
175 }
176
177
178 int
179 globmatch(pat, str) /* check for glob match of str against pat */
180 char *pat, *str;
181 {
182 register char *p = pat, *s = str;
183
184 do {
185 switch (*p) {
186 case '?': /* match any character */
187 if (!*s++)
188 return(0);
189 break;
190 case '*': /* match any string */
191 while (p[1] == '*') p++;
192 do
193 if ( (p[1]=='?' || p[1]==*s) &&
194 globmatch(p+1,s) )
195 return(1);
196 while (*s++);
197 return(0);
198 case '\\': /* literal next */
199 p++;
200 /* fall through */
201 default: /* normal character */
202 if (*p != *s)
203 return(0);
204 s++;
205 break;
206 }
207 } while (*p++);
208 return(1);
209 }
210
211
212 /*
213 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
214 * matches the specification in fmt, 0 if no input format was found,
215 * and -1 if the input format does not match or there is an
216 * error reading the header. If fmt is empty, then -1 is returned
217 * if any input format is found (or there is an error), and 0 otherwise.
218 * If fmt contains any '*' or '?' characters, then checkheader
219 * does wildcard expansion and copies a matching result into fmt.
220 * Be sure that fmt is big enough to hold the match in such cases,
221 * and that it is not a static, read-only string!
222 * The input header (minus any format lines) is copied to fout
223 * if fout is not NULL.
224 */
225
226 int
227 checkheader(fin, fmt, fout)
228 FILE *fin;
229 char *fmt;
230 FILE *fout;
231 {
232 struct check cdat;
233 register char *cp;
234
235 cdat.fp = fout;
236 cdat.fs[0] = '\0';
237 if (getheader(fin, mycheck, &cdat) < 0)
238 return(-1);
239 if (!cdat.fs[0])
240 return(0);
241 for (cp = fmt; *cp; cp++) /* check for globbing */
242 if (*cp == '?' | *cp == '*')
243 if (globmatch(fmt, cdat.fs)) {
244 strcpy(fmt, cdat.fs);
245 return(1);
246 } else
247 return(-1);
248 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
249 }
