root/radiance/ray/src/common/header.c
Revision: 2.27
Committed: Sun Jun 10 02:46:12 2012 UTC (13 years ago) by greg
Changes since 2.26: +1 -5 lines
Removed unused code fragment
2 static const char RCSid[] = "$Id: header.c,v 2.26 2010/05/27 19:32:12 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
19 * globmatch(pat, str) check for glob match of str against pat
20 * checkheader(i,p,o) check header format from i against p and copy to o
21 *
22 * To copy header from input to output, use getheader(fin, fputs, fout)
23 */
24
25 #include "copyright.h"
26
27 #include <ctype.h>
28
29 #include "rtio.h"
30 #include "resolu.h"
31
32 #define MAXLINE 2048
33
34 extern time_t timegm(struct tm *tm);
35
36 const char HDRSTR[] = "#?"; /* information header magic number */
37
38 const char FMTSTR[] = "FORMAT="; /* format identifier */
39
40 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
41 const char GMTSTR[] = "GMT="; /* GMT identifier */
42
43 static gethfunc mycheck;
44
45
46 extern void
47 newheader( /* identifying line of information header */
48 char *s,
49 FILE *fp
50 )
51 {
52 fputs(HDRSTR, fp);
53 fputs(s, fp);
54 putc('\n', fp);
55 }
56
57
58 extern int
59 headidval( /* get header id (return true if is id) */
60 char *r,
61 char *s
62 )
63 {
64 const char *cp = HDRSTR;
65
66 while (*cp) if (*cp++ != *s++) return(0);
67 if (r == NULL) return(1);
68 while (*s && !isspace(*s)) *r++ = *s++;
69 *r = '\0';
70 return(1);
71 }
72
73
74 extern int
75 dateval( /* convert capture date line to UTC */
76 time_t *tloc,
77 char *s
78 )
79 {
80 struct tm tms;
81 const char *cp = TMSTR;
82
83 while (*cp) if (*cp++ != *s++) return(0);
84 while (isspace(*s)) s++;
85 if (!*s) return(0);
86 if (sscanf(s, "%d:%d:%d %d:%d:%d",
87 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
88 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
89 return(0);
90 if (tloc == NULL)
91 return(1);
92 tms.tm_mon--;
93 tms.tm_year -= 1900;
94 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
95 *tloc = mktime(&tms);
96 return(1);
97 }
98
99
100 extern int
101 gmtval( /* convert GMT date line to UTC */
102 time_t *tloc,
103 char *s
104 )
105 {
106 struct tm tms;
107 const char *cp = GMTSTR;
108
109 while (*cp) if (*cp++ != *s++) return(0);
110 while (isspace(*s)) s++;
111 if (!*s) return(0);
112 if (sscanf(s, "%d:%d:%d %d:%d:%d",
113 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
114 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
115 return(0);
116 if (tloc == NULL)
117 return(1);
118 tms.tm_mon--;
119 tms.tm_year -= 1900;
120 *tloc = timegm(&tms);
121 return(1);
122 }
123
124
125 extern void
126 fputdate( /* write out the given time value (local & GMT) */
127 time_t tv,
128 FILE *fp
129 )
130 {
131 struct tm *tms;
132
133 tms = localtime(&tv);
134 if (tms != NULL)
135 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
136 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
137 tms->tm_hour, tms->tm_min, tms->tm_sec);
138 tms = gmtime(&tv);
139 if (tms != NULL)
140 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
141 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
142 tms->tm_hour, tms->tm_min, tms->tm_sec);
143 }
144
145
146 extern void
147 fputnow( /* write out the current time */
148 FILE *fp
149 )
150 {
151 time_t tv;
152 time(&tv);
153 fputdate(tv, fp);
154 }
155
156
157 extern void
158 printargs( /* print arguments to a file */
159 int ac,
160 char **av,
161 FILE *fp
162 )
163 {
164 while (ac-- > 0) {
165 fputword(*av++, fp);
166 fputc(ac ? ' ' : '\n', fp);
167 }
168 }
169
170
171 extern int
172 formatval( /* get format value (return true if format) */
173 char *r,
174 char *s
175 )
176 {
177 const char *cp = FMTSTR;
178
179 while (*cp) if (*cp++ != *s++) return(0);
180 while (isspace(*s)) s++;
181 if (!*s) return(0);
182 if (r == NULL) return(1);
183 do
184 *r++ = *s++;
185 while(*s && !isspace(*s));
186 *r = '\0';
187 return(1);
188 }
189
190
191 extern void
192 fputformat( /* put out a format value */
193 char *s,
194 FILE *fp
195 )
196 {
197 fputs(FMTSTR, fp);
198 fputs(s, fp);
199 putc('\n', fp);
200 }
201
202
203 extern int
204 getheader( /* get header from file */
205 FILE *fp,
206 gethfunc *f,
207 void *p
208 )
209 {
210 char buf[MAXLINE];
211
212 for ( ; ; ) {
213 buf[MAXLINE-2] = '\n';
214 if (fgets(buf, MAXLINE, fp) == NULL)
215 return(-1);
216 if (buf[0] == '\n')
217 return(0);
218 if (buf[MAXLINE-2] != '\n') {
219 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
220 buf[MAXLINE-2] = '\0';
221 }
222 if (f != NULL && (*f)(buf, p) < 0)
223 return(-1);
224 }
225 }
226
227
228 struct check {
229 FILE *fp;
230 char fs[64];
231 };
232
233
234 static int
235 mycheck( /* check a header line for format info. */
236 char *s,
237 void *cp
238 )
239 {
240 if (!formatval(((struct check*)cp)->fs, s)
241 && ((struct check*)cp)->fp != NULL) {
242 fputs(s, ((struct check*)cp)->fp);
243 }
244 return(0);
245 }
246
247
248 extern int
249 globmatch( /* check for match of s against pattern p */
250 char *p,
251 char *s
252 )
253 {
254 int setmatch;
255
256 do {
257 switch (*p) {
258 case '?': /* match any character */
259 if (!*s++)
260 return(0);
261 break;
262 case '*': /* match any string */
263 while (p[1] == '*') p++;
264 do
265 if ( (p[1]=='?' || p[1]==*s) &&
266 globmatch(p+1,s) )
267 return(1);
268 while (*s++);
269 return(0);
270 case '[': /* character set */
271 setmatch = *s == *++p;
272 if (!*p)
273 return(0);
274 while (*++p != ']') {
275 if (!*p)
276 return(0);
277 if (*p == '-') {
278 setmatch += p[-1] <= *s && *s <= p[1];
279 if (!*++p)
280 break;
281 } else
282 setmatch += *p == *s;
283 }
284 if (!setmatch)
285 return(0);
286 s++;
287 break;
288 case '\\': /* literal next */
289 p++;
290 /* fall through */
291 default: /* normal character */
292 if (*p != *s)
293 return(0);
294 s++;
295 break;
296 }
297 } while (*p++);
298 return(1);
299 }
300
301
302 /*
303 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
304 * matches the specification in fmt, 0 if no input format was found,
305 * and -1 if the input format does not match or there is an
306 * error reading the header. If fmt is empty, then -1 is returned
307 * if any input format is found (or there is an error), and 0 otherwise.
308 * If fmt contains any '*' or '?' characters, then checkheader
309 * does wildcard expansion and copies a matching result into fmt.
310 * Be sure that fmt is big enough to hold the match in such cases,
311 * and that it is not a static, read-only string!
312 * The input header (minus any format lines) is copied to fout
313 * if fout is not NULL.
314 */
315
316 extern int
317 checkheader(
318 FILE *fin,
319 char *fmt,
320 FILE *fout
321 )
322 {
323 struct check cdat;
324 char *cp;
325
326 cdat.fp = fout;
327 cdat.fs[0] = '\0';
328 if (getheader(fin, mycheck, &cdat) < 0)
329 return(-1);
330 if (!cdat.fs[0])
331 return(0);
332 for (cp = fmt; *cp; cp++) /* check for globbing */
333 if ((*cp == '?') | (*cp == '*')) {
334 if (globmatch(fmt, cdat.fs)) {
335 strcpy(fmt, cdat.fs);
336 return(1);
337 } else
338 return(-1);
339 }
340 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
341 }
