root/radiance/ray/src/common/header.c
Revision: 2.23
Committed: Tue Feb 1 01:28:16 2005 UTC (20 years, 4 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
Changes since 2.22: +1 -2 lines
Eliminated redundant include files.
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.23 static const char RCSid[] = "$Id: header.c,v 2.22 2004/01/02 11:35:17 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * header.c - routines for reading and writing information headers.
6     *
7 greg 2.11 * Externals declared in resolu.h
8 greg 1.3 *
9 greg 2.4 * newheader(t,fp) start new information header identified by string t
10     * isheadid(s) returns true if s is a header id line
11     * headidval(r,s) copy header identifier value in s to r
12 greg 2.11 * dateval(t,s) get capture date value
13     * isdate(s) returns true if s is a date line
14     * fputdate(t,fp) put out the given capture date and time
15     * fputnow(fp) put out the current date and time
16 greg 2.3 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
17 greg 1.3 * isformat(s) returns true if s is of the form "FORMAT=*"
18     * formatval(r,s) copy the format value in s to r
19     * fputformat(s,fp) write "FORMAT=%s" to fp
20     * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
21 greg 2.6 * globmatch(pat, str) check for glob match of str against pat
22 greg 1.3 * checkheader(i,p,o) check header format from i against p and copy to o
23     *
24     * To copy header from input to output, use getheader(fin, fputs, fout)
25 greg 1.1 */
26
27 greg 2.12 #include "copyright.h"
28 greg 2.11
29 greg 1.3 #include <ctype.h>
30 schorsch 2.17
31 greg 2.18 #include "rtio.h"
32     #include "resolu.h"
33 schorsch 2.14
34 greg 2.3 #define MAXLINE 512
35 greg 2.2
36 greg 2.4 char HDRSTR[] = "#?"; /* information header magic number */
37 greg 1.2
38 greg 2.4 char FMTSTR[] = "FORMAT="; /* format identifier */
39 greg 1.2
40 greg 2.11 char TMSTR[] = "CAPDATE="; /* capture date identifier */
41 greg 2.16
42 schorsch 2.22 static gethfunc mycheck;
43 greg 2.4
44 greg 2.11
45 schorsch 2.22 extern void
46     newheader( /* identifying line of information header */
47     char *s,
48     register FILE *fp
49     )
50 greg 2.4 {
51     fputs(HDRSTR, fp);
52     fputs(s, fp);
53     putc('\n', fp);
54     }
55
56
57 schorsch 2.22 extern int
58     headidval( /* get header id (return true if is id) */
59     register char *r,
60     register char *s
61     )
62 greg 2.4 {
63     register char *cp = HDRSTR;
64
65     while (*cp) if (*cp++ != *s++) return(0);
66     if (r == NULL) return(1);
67 gregl 2.9 while (*s && !isspace(*s)) *r++ = *s++;
68 greg 2.4 *r = '\0';
69     return(1);
70     }
71
72
73 schorsch 2.22 extern int
74     isheadid( /* check to see if line is header id */
75     char *s
76     )
77 greg 2.4 {
78     return(headidval(NULL, s));
79     }
80
81
82 schorsch 2.22 extern int
83     dateval( /* get capture date value */
84     time_t *tloc,
85     char *s
86     )
87 greg 2.11 {
88     struct tm tms;
89     register char *cp = TMSTR;
90
91     while (*cp) if (*cp++ != *s++) return(0);
92     while (isspace(*s)) s++;
93     if (!*s) return(0);
94     if (sscanf(s, "%d:%d:%d %d:%d:%d",
95     &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
96     &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
97     return(0);
98     if (tloc == NULL)
99     return(1);
100     tms.tm_mon--;
101     tms.tm_year -= 1900;
102     tms.tm_isdst = -1; /* ask mktime() to figure out DST */
103     *tloc = mktime(&tms);
104     return(1);
105     }
106
107
108 schorsch 2.22 extern int
109     isdate( /* is the given line a capture date? */
110     char *s
111     )
112 greg 2.11 {
113     return(dateval(NULL, s));
114     }
115
116
117 schorsch 2.22 extern void
118     fputdate( /* write out the given time value */
119     time_t tv,
120     FILE *fp
121     )
122 greg 2.11 {
123     struct tm *tm = localtime(&tv);
124     if (tm == NULL)
125     return;
126     fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
127     tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday,
128     tm->tm_hour, tm->tm_min, tm->tm_sec);
129     }
130
131
132 schorsch 2.22 extern void
133     fputnow( /* write out the current time */
134     FILE *fp
135     )
136 greg 2.11 {
137     time_t tv;
138     time(&tv);
139     fputdate(tv, fp);
140     }
141
142
143 schorsch 2.22 extern void
144     printargs( /* print arguments to a file */
145     int ac,
146     char **av,
147     FILE *fp
148     )
149 greg 1.1 {
150     while (ac-- > 0) {
151 greg 2.11 fputword(*av++, fp);
152     fputc(ac ? ' ' : '\n', fp);
153 greg 1.1 }
154     }
155
156
157 schorsch 2.22 extern int
158     formatval( /* get format value (return true if format) */
159     register char *r,
160     register char *s
161     )
162 greg 1.2 {
163 greg 2.4 register char *cp = FMTSTR;
164
165     while (*cp) if (*cp++ != *s++) return(0);
166 greg 1.3 while (isspace(*s)) s++;
167 greg 2.4 if (!*s) return(0);
168     if (r == NULL) return(1);
169 greg 2.5 do
170     *r++ = *s++;
171     while(*s && !isspace(*s));
172 greg 1.2 *r = '\0';
173 greg 2.4 return(1);
174 greg 1.2 }
175
176
177 schorsch 2.22 extern int
178     isformat( /* is line a format line? */
179     char *s
180     )
181 greg 2.4 {
182     return(formatval(NULL, s));
183     }
184
185
186 schorsch 2.22 extern void
187     fputformat( /* put out a format value */
188     char *s,
189     FILE *fp
190     )
191 greg 1.2 {
192     fputs(FMTSTR, fp);
193     fputs(s, fp);
194     putc('\n', fp);
195     }
196
197
198 schorsch 2.22 extern int
199     getheader( /* get header from file */
200     FILE *fp,
201     gethfunc *f,
202     void *p
203     )
204 greg 1.1 {
205     char buf[MAXLINE];
206
207     for ( ; ; ) {
208     buf[MAXLINE-2] = '\n';
209 greg 2.3 if (fgets(buf, MAXLINE, fp) == NULL)
210 greg 1.1 return(-1);
211     if (buf[0] == '\n')
212     return(0);
213 greg 2.3 #ifdef MSDOS
214     if (buf[0] == '\r' && buf[1] == '\n')
215     return(0);
216     #endif
217 greg 1.1 if (buf[MAXLINE-2] != '\n') {
218     ungetc(buf[MAXLINE-2], fp); /* prevent false end */
219     buf[MAXLINE-2] = '\0';
220     }
221 gwlarson 2.10 if (f != NULL && (*f)(buf, p) < 0)
222     return(-1);
223 greg 1.1 }
224     }
225
226
227 greg 1.2 struct check {
228     FILE *fp;
229 greg 1.3 char fs[64];
230 greg 1.2 };
231 greg 1.1
232 greg 1.2
233 greg 2.11 static int
234 schorsch 2.22 mycheck( /* check a header line for format info. */
235     char *s,
236     void *cp
237     )
238     {
239     if (!formatval(((struct check*)cp)->fs, s)
240     && ((struct check*)cp)->fp != NULL) {
241     fputs(s, ((struct check*)cp)->fp);
242     }
243 greg 2.11 return(0);
244 greg 1.1 }
245
246
247 schorsch 2.22 extern int
248     globmatch( /* check for match of s against pattern p */
249     register char *p,
250     register char *s
251     )
252 greg 1.3 {
253 greg 2.11 int setmatch;
254 greg 1.3
255     do {
256     switch (*p) {
257     case '?': /* match any character */
258     if (!*s++)
259     return(0);
260     break;
261     case '*': /* match any string */
262     while (p[1] == '*') p++;
263     do
264 greg 2.6 if ( (p[1]=='?' || p[1]==*s) &&
265     globmatch(p+1,s) )
266 greg 1.3 return(1);
267     while (*s++);
268     return(0);
269 greg 2.11 case '[': /* character set */
270     setmatch = *s == *++p;
271     if (!*p)
272     return(0);
273     while (*++p != ']') {
274     if (!*p)
275     return(0);
276     if (*p == '-') {
277     setmatch += p[-1] <= *s && *s <= p[1];
278     if (!*++p)
279     break;
280     } else
281     setmatch += *p == *s;
282     }
283     if (!setmatch)
284     return(0);
285     s++;
286     break;
287 greg 1.3 case '\\': /* literal next */
288     p++;
289     /* fall through */
290     default: /* normal character */
291     if (*p != *s)
292     return(0);
293     s++;
294     break;
295     }
296     } while (*p++);
297     return(1);
298     }
299
300
301     /*
302     * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
303     * matches the specification in fmt, 0 if no input format was found,
304     * and -1 if the input format does not match or there is an
305 greg 1.4 * error reading the header. If fmt is empty, then -1 is returned
306 greg 1.3 * if any input format is found (or there is an error), and 0 otherwise.
307     * If fmt contains any '*' or '?' characters, then checkheader
308     * does wildcard expansion and copies a matching result into fmt.
309 greg 2.7 * Be sure that fmt is big enough to hold the match in such cases,
310     * and that it is not a static, read-only string!
311 greg 1.3 * The input header (minus any format lines) is copied to fout
312     * if fout is not NULL.
313     */
314
315 schorsch 2.22 extern int
316     checkheader(
317     FILE *fin,
318     char *fmt,
319     FILE *fout
320     )
321 greg 1.1 {
322 greg 1.2 struct check cdat;
323 greg 2.7 register char *cp;
324 greg 1.2
325     cdat.fp = fout;
326     cdat.fs[0] = '\0';
327 schorsch 2.22 if (getheader(fin, mycheck, &cdat) < 0)
328 greg 1.3 return(-1);
329 greg 2.6 if (!cdat.fs[0])
330     return(0);
331 greg 2.7 for (cp = fmt; *cp; cp++) /* check for globbing */
332 schorsch 2.20 if ((*cp == '?') | (*cp == '*')) {
333 greg 2.7 if (globmatch(fmt, cdat.fs)) {
334     strcpy(fmt, cdat.fs);
335     return(1);
336     } else
337     return(-1);
338 schorsch 2.19 }
339 greg 2.7 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
340 greg 1.1 }
