Eliminated redundant include files.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Included rtio.h to cover fputword() declaration
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
took out space at the end of header id's
eliminated final space from printargs() output
fixed bug on machines that put static strings in read-only memory
changed copymatch() to globmatch(), which is more generally useful
made changes for new 32-bit_rle_xyze picture type
Changes for 32-bit PC port
added quoting of arguments containing spaces to printargs()
minor change to checkheader.c
added wildcard matching for formats
added format info to headers
