--- ray/src/common/header.c 1989/02/02 10:34:33 1.1 +++ ray/src/common/header.c 1991/04/19 10:33:25 1.3 @@ -8,11 +8,26 @@ static char SCCSid[] = "$SunId$ LBL"; * header.c - routines for reading and writing information headers. * * 8/19/88 + * + * printargs(ac,av,fp) print an argument list to fp, followed by '\n' + * isformat(s) returns true if s is of the form "FORMAT=*" + * formatval(r,s) copy the format value in s to r + * fputformat(s,fp) write "FORMAT=%s" to fp + * getheader(fp,f,p) read header from fp, calling f(s,p) on each line + * checkheader(i,p,o) check header format from i against p and copy to o + * + * To copy header from input to output, use getheader(fin, fputs, fout) */ #include +#include +#define MAXLINE 512 +char FMTSTR[] = "FORMAT="; +int FMTSTRL = 7; + + printargs(ac, av, fp) /* print arguments to a file */ int ac; char **av; @@ -26,11 +41,40 @@ FILE *fp; } -#define MAXLINE 512 +isformat(s) /* is line a format line? */ +char *s; +{ + return(!strncmp(s,FMTSTR,FMTSTRL)); +} -getheader(fp, f) /* get header from file */ + +formatval(r, s) /* return format value */ +register char *r; +register char *s; +{ + s += FMTSTRL; + while (isspace(*s)) s++; + if (!*s) { *r = '\0'; return; } + while(*s) *r++ = *s++; + while (isspace(r[-1])) r--; + *r = '\0'; +} + + +fputformat(s, fp) /* put out a format value */ +char *s; FILE *fp; +{ + fputs(FMTSTR, fp); + fputs(s, fp); + putc('\n', fp); +} + + +getheader(fp, f, p) /* get header from file */ +FILE *fp; int (*f)(); +char *p; { char buf[MAXLINE]; @@ -45,24 +89,104 @@ int (*f)(); buf[MAXLINE-2] = '\0'; } if (f != NULL) - (*f)(buf); + (*f)(buf, p); } } -static FILE *outfp; +struct check { + FILE *fp; + char fs[64]; +}; + static -myputs(s) +mycheck(s, cp) /* check a header line for format info. */ char *s; +register struct check *cp; { - fputs(s, outfp); + if (!strncmp(s,FMTSTR,FMTSTRL)) + formatval(cp->fs, s); + else if (cp->fp != NULL) /* don't copy format info. */ + fputs(s, cp->fp); } -copyheader(fin, fout) /* copy file header */ -FILE *fin, *fout; +/* + * Copymatch(pat,str) checks pat for wildcards, and + * copies str into pat if there is a match (returning true). + */ + +#ifdef COPYMATCH +copymatch(pat, str) +char *pat, *str; { - outfp = fout; - return(getheader(fin, myputs)); + int docopy = 0; + register char *p = pat, *s = str; + + do { + switch (*p) { + case '?': /* match any character */ + if (!*s++) + return(0); + docopy++; + break; + case '*': /* match any string */ + while (p[1] == '*') p++; + do + if ( (p[1] == '?' || p[1] == *s) + && copymatch(p+1,s) ) { + strcpy(pat, str); + return(1); + } + while (*s++); + return(0); + case '\\': /* literal next */ + p++; + /* fall through */ + default: /* normal character */ + if (*p != *s) + return(0); + s++; + break; + } + } while (*p++); + if (docopy) + strcpy(pat, str); + return(1); +} +#else +#define copymatch(pat, s) (!strcmp(pat, s)) +#endif + + +/* + * Checkheader(fin,fmt,fout) returns a value of 1 if the input format + * matches the specification in fmt, 0 if no input format was found, + * and -1 if the input format does not match or there is an + * error reading the header. If fmt is NULL, then -1 is returned + * if any input format is found (or there is an error), and 0 otherwise. + * If fmt contains any '*' or '?' characters, then checkheader + * does wildcard expansion and copies a matching result into fmt. + * Be sure that fmt is big enough to hold the match in such cases! + * The input header (minus any format lines) is copied to fout + * if fout is not NULL. + */ + +checkheader(fin, fmt, fout) +FILE *fin; +char *fmt; +FILE *fout; +{ + struct check cdat; + + cdat.fp = fout; + cdat.fs[0] = '\0'; + if (getheader(fin, mycheck, &cdat) < 0) + return(-1); + if (fmt == NULL && cdat.fs[0] != '\0') + return(-1); + if (cdat.fs[0] != '\0') + return(copymatch(fmt, cdat.fs) ? 1 : -1); + return(0); }
