root/radiance/ray/src/common/header.c
Revision: 2.18
Committed: Sat Jul 12 15:14:44 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.17: +3 -6 lines
Included rtio.h to cover fputword() declaration
2 static const char RCSid[] = "$Id: header.c,v 2.17 2003/06/30 14:59:11 schorsch Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * isheadid(s) returns true if s is a header id line
11 * headidval(r,s) copy header identifier value in s to r
12 * dateval(t,s) get capture date value
13 * isdate(s) returns true if s is a date line
14 * fputdate(t,fp) put out the given capture date and time
15 * fputnow(fp) put out the current date and time
16 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
17 * isformat(s) returns true if s is of the form "FORMAT=*"
18 * formatval(r,s) copy the format value in s to r
19 * fputformat(s,fp) write "FORMAT=%s" to fp
20 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
21 * globmatch(pat, str) check for glob match of str against pat
22 * checkheader(i,p,o) check header format from i against p and copy to o
23 *
24 * To copy header from input to output, use getheader(fin, fputs, fout)
25 */
26
27 #include "copyright.h"
28
29 #include <time.h>
30 #include <ctype.h>
31
32 #include "rtio.h"
33 #include "resolu.h"
34
35 #define MAXLINE 512
36
37 char HDRSTR[] = "#?"; /* information header magic number */
38
39 char FMTSTR[] = "FORMAT="; /* format identifier */
40
41 char TMSTR[] = "CAPDATE="; /* capture date identifier */
42
43 static int mycheck();
44
45
46 void
47 newheader(s, fp) /* identifying line of information header */
48 char *s;
49 register FILE *fp;
50 {
51 fputs(HDRSTR, fp);
52 fputs(s, fp);
53 putc('\n', fp);
54 }
55
56
57 int
58 headidval(r,s) /* get header id (return true if is id) */
59 register char *r, *s;
60 {
61 register char *cp = HDRSTR;
62
63 while (*cp) if (*cp++ != *s++) return(0);
64 if (r == NULL) return(1);
65 while (*s && !isspace(*s)) *r++ = *s++;
66 *r = '\0';
67 return(1);
68 }
69
70
71 int
72 isheadid(s) /* check to see if line is header id */
73 char *s;
74 {
75 return(headidval(NULL, s));
76 }
77
78
79 int
80 dateval(tloc, s) /* get capture date value */
81 time_t *tloc;
82 char *s;
83 {
84 struct tm tms;
85 register char *cp = TMSTR;
86
87 while (*cp) if (*cp++ != *s++) return(0);
88 while (isspace(*s)) s++;
89 if (!*s) return(0);
90 if (sscanf(s, "%d:%d:%d %d:%d:%d",
91 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
92 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
93 return(0);
94 if (tloc == NULL)
95 return(1);
96 tms.tm_mon--;
97 tms.tm_year -= 1900;
98 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
99 *tloc = mktime(&tms);
100 return(1);
101 }
102
103
104 int
105 isdate(s) /* is the given line a capture date? */
106 char *s;
107 {
108 return(dateval(NULL, s));
109 }
110
111
112 void
113 fputdate(tv, fp) /* write out the given time value */
114 time_t tv;
115 FILE *fp;
116 {
117 struct tm *tm = localtime(&tv);
118 if (tm == NULL)
119 return;
120 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
121 tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday,
122 tm->tm_hour, tm->tm_min, tm->tm_sec);
123 }
124
125
126 void
127 fputnow(fp) /* write out the current time */
128 FILE *fp;
129 {
130 time_t tv;
131 time(&tv);
132 fputdate(tv, fp);
133 }
134
135
136 void
137 printargs(ac, av, fp) /* print arguments to a file */
138 int ac;
139 char **av;
140 FILE *fp;
141 {
142 while (ac-- > 0) {
143 fputword(*av++, fp);
144 fputc(ac ? ' ' : '\n', fp);
145 }
146 }
147
148
149 int
150 formatval(r, s) /* get format value (return true if format) */
151 register char *r;
152 register char *s;
153 {
154 register char *cp = FMTSTR;
155
156 while (*cp) if (*cp++ != *s++) return(0);
157 while (isspace(*s)) s++;
158 if (!*s) return(0);
159 if (r == NULL) return(1);
160 do
161 *r++ = *s++;
162 while(*s && !isspace(*s));
163 *r = '\0';
164 return(1);
165 }
166
167
168 int
169 isformat(s) /* is line a format line? */
170 char *s;
171 {
172 return(formatval(NULL, s));
173 }
174
175
176 void
177 fputformat(s, fp) /* put out a format value */
178 char *s;
179 FILE *fp;
180 {
181 fputs(FMTSTR, fp);
182 fputs(s, fp);
183 putc('\n', fp);
184 }
185
186
187 int
188 getheader(fp, f, p) /* get header from file */
189 FILE *fp;
190 int (*f)();
191 char *p;
192 {
193 char buf[MAXLINE];
194
195 for ( ; ; ) {
196 buf[MAXLINE-2] = '\n';
197 if (fgets(buf, MAXLINE, fp) == NULL)
198 return(-1);
199 if (buf[0] == '\n')
200 return(0);
201 #ifdef MSDOS
202 if (buf[0] == '\r' && buf[1] == '\n')
203 return(0);
204 #endif
205 if (buf[MAXLINE-2] != '\n') {
206 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
207 buf[MAXLINE-2] = '\0';
208 }
209 if (f != NULL && (*f)(buf, p) < 0)
210 return(-1);
211 }
212 }
213
214
215 struct check {
216 FILE *fp;
217 char fs[64];
218 };
219
220
221 static int
222 mycheck(s, cp) /* check a header line for format info. */
223 char *s;
224 register struct check *cp;
225 {
226 if (!formatval(cp->fs, s) && cp->fp != NULL)
227 fputs(s, cp->fp);
228 return(0);
229 }
230
231
232 int
233 globmatch(p, s) /* check for match of s against pattern p */
234 register char *p, *s;
235 {
236 int setmatch;
237
238 do {
239 switch (*p) {
240 case '?': /* match any character */
241 if (!*s++)
242 return(0);
243 break;
244 case '*': /* match any string */
245 while (p[1] == '*') p++;
246 do
247 if ( (p[1]=='?' || p[1]==*s) &&
248 globmatch(p+1,s) )
249 return(1);
250 while (*s++);
251 return(0);
252 case '[': /* character set */
253 setmatch = *s == *++p;
254 if (!*p)
255 return(0);
256 while (*++p != ']') {
257 if (!*p)
258 return(0);
259 if (*p == '-') {
260 setmatch += p[-1] <= *s && *s <= p[1];
261 if (!*++p)
262 break;
263 } else
264 setmatch += *p == *s;
265 }
266 if (!setmatch)
267 return(0);
268 s++;
269 break;
270 case '\\': /* literal next */
271 p++;
272 /* fall through */
273 default: /* normal character */
274 if (*p != *s)
275 return(0);
276 s++;
277 break;
278 }
279 } while (*p++);
280 return(1);
281 }
282
283
284 /*
285 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
286 * matches the specification in fmt, 0 if no input format was found,
287 * and -1 if the input format does not match or there is an
288 * error reading the header. If fmt is empty, then -1 is returned
289 * if any input format is found (or there is an error), and 0 otherwise.
290 * If fmt contains any '*' or '?' characters, then checkheader
291 * does wildcard expansion and copies a matching result into fmt.
292 * Be sure that fmt is big enough to hold the match in such cases,
293 * and that it is not a static, read-only string!
294 * The input header (minus any format lines) is copied to fout
295 * if fout is not NULL.
296 */
297
298 int
299 checkheader(fin, fmt, fout)
300 FILE *fin;
301 char *fmt;
302 FILE *fout;
303 {
304 struct check cdat;
305 register char *cp;
306
307 cdat.fp = fout;
308 cdat.fs[0] = '\0';
309 if (getheader(fin, mycheck, (char *)&cdat) < 0)
310 return(-1);
311 if (!cdat.fs[0])
312 return(0);
313 for (cp = fmt; *cp; cp++) /* check for globbing */
314 if (*cp == '?' | *cp == '*')
315 if (globmatch(fmt, cdat.fs)) {
316 strcpy(fmt, cdat.fs);
317 return(1);
318 } else
319 return(-1);
320 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
321 }
