root/radiance/ray/src/common/header.c
Revision: 2.13
Committed: Mon Mar 10 17:13:29 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.12: +1 -7 lines
2 static const char RCSid[] = "$Id: header.c,v 2.12 2003/02/25 02:47:21 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * isheadid(s) returns true if s is a header id line
11 * headidval(r,s) copy header identifier value in s to r
12 * dateval(t,s) get capture date value
13 * isdate(s) returns true if s is a date line
14 * fputdate(t,fp) put out the given capture date and time
15 * fputnow(fp) put out the current date and time
16 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
17 * isformat(s) returns true if s is of the form "FORMAT=*"
18 * formatval(r,s) copy the format value in s to r
19 * fputformat(s,fp) write "FORMAT=%s" to fp
20 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
21 * globmatch(pat, str) check for glob match of str against pat
22 * checkheader(i,p,o) check header format from i against p and copy to o
23 *
24 * To copy header from input to output, use getheader(fin, fputs, fout)
25 */
26
27 #include "copyright.h"
28
29 #include <stdio.h>
30 #include <string.h>
31 #include <time.h>
32 #include <ctype.h>
33
34 #define MAXLINE 512
35
36 char HDRSTR[] = "#?"; /* information header magic number */
37
38 char FMTSTR[] = "FORMAT="; /* format identifier */
39
40 char TMSTR[] = "CAPDATE="; /* capture date identifier */
41
42 static int mycheck();
43
44
45 void
46 newheader(s, fp) /* identifying line of information header */
47 char *s;
48 register FILE *fp;
49 {
50 fputs(HDRSTR, fp);
51 fputs(s, fp);
52 putc('\n', fp);
53 }
54
55
56 int
57 headidval(r,s) /* get header id (return true if is id) */
58 register char *r, *s;
59 {
60 register char *cp = HDRSTR;
61
62 while (*cp) if (*cp++ != *s++) return(0);
63 if (r == NULL) return(1);
64 while (*s && !isspace(*s)) *r++ = *s++;
65 *r = '\0';
66 return(1);
67 }
68
69
70 int
71 isheadid(s) /* check to see if line is header id */
72 char *s;
73 {
74 return(headidval(NULL, s));
75 }
76
77
78 int
79 dateval(tloc, s) /* get capture date value */
80 time_t *tloc;
81 char *s;
82 {
83 struct tm tms;
84 register char *cp = TMSTR;
85
86 while (*cp) if (*cp++ != *s++) return(0);
87 while (isspace(*s)) s++;
88 if (!*s) return(0);
89 if (sscanf(s, "%d:%d:%d %d:%d:%d",
90 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
91 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
92 return(0);
93 if (tloc == NULL)
94 return(1);
95 tms.tm_mon--;
96 tms.tm_year -= 1900;
97 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
98 *tloc = mktime(&tms);
99 return(1);
100 }
101
102
103 int
104 isdate(s) /* is the given line a capture date? */
105 char *s;
106 {
107 return(dateval(NULL, s));
108 }
109
110
111 void
112 fputdate(tv, fp) /* write out the given time value */
113 time_t tv;
114 FILE *fp;
115 {
116 struct tm *tm = localtime(&tv);
117 if (tm == NULL)
118 return;
119 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
120 tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday,
121 tm->tm_hour, tm->tm_min, tm->tm_sec);
122 }
123
124
125 void
126 fputnow(fp) /* write out the current time */
127 FILE *fp;
128 {
129 time_t tv;
130 time(&tv);
131 fputdate(tv, fp);
132 }
133
134
135 void
136 printargs(ac, av, fp) /* print arguments to a file */
137 int ac;
138 char **av;
139 FILE *fp;
140 {
141 int quote;
142
143 while (ac-- > 0) {
144 fputword(*av++, fp);
145 fputc(ac ? ' ' : '\n', fp);
146 }
147 }
148
149
150 int
151 formatval(r, s) /* get format value (return true if format) */
152 register char *r;
153 register char *s;
154 {
155 register char *cp = FMTSTR;
156
157 while (*cp) if (*cp++ != *s++) return(0);
158 while (isspace(*s)) s++;
159 if (!*s) return(0);
160 if (r == NULL) return(1);
161 do
162 *r++ = *s++;
163 while(*s && !isspace(*s));
164 *r = '\0';
165 return(1);
166 }
167
168
169 int
170 isformat(s) /* is line a format line? */
171 char *s;
172 {
173 return(formatval(NULL, s));
174 }
175
176
177 void
178 fputformat(s, fp) /* put out a format value */
179 char *s;
180 FILE *fp;
181 {
182 fputs(FMTSTR, fp);
183 fputs(s, fp);
184 putc('\n', fp);
185 }
186
187
188 int
189 getheader(fp, f, p) /* get header from file */
190 FILE *fp;
191 int (*f)();
192 char *p;
193 {
194 char buf[MAXLINE];
195
196 for ( ; ; ) {
197 buf[MAXLINE-2] = '\n';
198 if (fgets(buf, MAXLINE, fp) == NULL)
199 return(-1);
200 if (buf[0] == '\n')
201 return(0);
202 #ifdef MSDOS
203 if (buf[0] == '\r' && buf[1] == '\n')
204 return(0);
205 #endif
206 if (buf[MAXLINE-2] != '\n') {
207 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
208 buf[MAXLINE-2] = '\0';
209 }
210 if (f != NULL && (*f)(buf, p) < 0)
211 return(-1);
212 }
213 }
214
215
216 struct check {
217 FILE *fp;
218 char fs[64];
219 };
220
221
222 static int
223 mycheck(s, cp) /* check a header line for format info. */
224 char *s;
225 register struct check *cp;
226 {
227 if (!formatval(cp->fs, s) && cp->fp != NULL)
228 fputs(s, cp->fp);
229 return(0);
230 }
231
232
233 int
234 globmatch(p, s) /* check for match of s against pattern p */
235 register char *p, *s;
236 {
237 int setmatch;
238
239 do {
240 switch (*p) {
241 case '?': /* match any character */
242 if (!*s++)
243 return(0);
244 break;
245 case '*': /* match any string */
246 while (p[1] == '*') p++;
247 do
248 if ( (p[1]=='?' || p[1]==*s) &&
249 globmatch(p+1,s) )
250 return(1);
251 while (*s++);
252 return(0);
253 case '[': /* character set */
254 setmatch = *s == *++p;
255 if (!*p)
256 return(0);
257 while (*++p != ']') {
258 if (!*p)
259 return(0);
260 if (*p == '-') {
261 setmatch += p[-1] <= *s && *s <= p[1];
262 if (!*++p)
263 break;
264 } else
265 setmatch += *p == *s;
266 }
267 if (!setmatch)
268 return(0);
269 s++;
270 break;
271 case '\\': /* literal next */
272 p++;
273 /* fall through */
274 default: /* normal character */
275 if (*p != *s)
276 return(0);
277 s++;
278 break;
279 }
280 } while (*p++);
281 return(1);
282 }
283
284
285 /*
286 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
287 * matches the specification in fmt, 0 if no input format was found,
288 * and -1 if the input format does not match or there is an
289 * error reading the header. If fmt is empty, then -1 is returned
290 * if any input format is found (or there is an error), and 0 otherwise.
291 * If fmt contains any '*' or '?' characters, then checkheader
292 * does wildcard expansion and copies a matching result into fmt.
293 * Be sure that fmt is big enough to hold the match in such cases,
294 * and that it is not a static, read-only string!
295 * The input header (minus any format lines) is copied to fout
296 * if fout is not NULL.
297 */
298
299 int
300 checkheader(fin, fmt, fout)
301 FILE *fin;
302 char *fmt;
303 FILE *fout;
304 {
305 struct check cdat;
306 register char *cp;
307
308 cdat.fp = fout;
309 cdat.fs[0] = '\0';
310 if (getheader(fin, mycheck, &cdat) < 0)
311 return(-1);
312 if (!cdat.fs[0])
313 return(0);
314 for (cp = fmt; *cp; cp++) /* check for globbing */
315 if (*cp == '?' | *cp == '*')
316 if (globmatch(fmt, cdat.fs)) {
317 strcpy(fmt, cdat.fs);
318 return(1);
319 } else
320 return(-1);
321 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
322 }
