root/radiance/ray/src/common/header.c
Mon Mar 10 17:13:29 2003 UTC (21 years, 6 months ago) by greg
Changes since 2.12: +1 -7 lines
Tue Feb 25 02:47:21 2003 UTC (21 years, 7 months ago) by greg
Changes since 2.11: +1 -56 lines
Sat Feb 22 02:07:22 2003 UTC (21 years, 7 months ago) by greg
Changes since 2.10: +155 -21 lines
Tue Oct 27 08:44:28 1998 UTC (25 years, 11 months ago) by gwlarson
Fri Oct 31 11:40:52 1997 UTC (26 years, 10 months ago) by gregl
took out space at the end of header id's
Sat Jul 27 07:21:38 1996 UTC (28 years, 2 months ago) by greg
eliminated final space from printargs() output
Tue Mar 12 11:29:16 1996 UTC (28 years, 6 months ago) by greg
Changes since 2.6: +11 -6 lines
fixed bug on machines that put static strings in read-only memory
Mon Oct 16 10:53:46 1995 UTC (28 years, 11 months ago) by greg
Changes since 2.5: +11 -18 lines
changed copymatch() to globmatch(), which is more generally useful
Sun Oct 15 14:07:58 1995 UTC (28 years, 11 months ago) by greg
Changes since 2.4: +11 -6 lines
made changes for new 32-bit_rle_xyze picture type
Sun Feb 27 10:16:45 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.3: +52 -16 lines
Thu Nov 12 16:20:09 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.2: +9 -5 lines
Changes for 32-bit PC port
Thu Feb 20 11:40:36 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.1: +19 -2 lines
added quoting of arguments containing spaces to printargs()
Tue Nov 12 16:54:24 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.4
Mon Apr 22 08:23:10 1991 UTC (33 years, 5 months ago) by greg
Changes since 1.3: +3 -5 lines
minor change to checkheader.c
Fri Apr 19 10:33:25 1991 UTC (33 years, 5 months ago) by greg
Changes since 1.2: +81 -6 lines
added wildcard matching for formats
Thu Apr 18 12:56:58 1991 UTC (33 years, 5 months ago) by greg
Changes since 1.1: +59 -10 lines
added format info to headers
Thu Feb 2 10:34:33 1989 UTC (35 years, 7 months ago) by greg
Diff to selected 2.1
