root/Development/ray/src/common/header.c
Revision: 2.48
Committed: Mon Mar 21 17:03:51 2022 UTC (3 years, 8 months ago) by greg
Changes since 2.47: +11 -6 lines
feat: Support for format IDs with internal white space
2 static const char RCSid[] = "$Id: header.c,v 2.47 2022/03/14 22:57:24 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in rtio.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * nativebigendian() are we native on big-endian machine?
19 * isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant)
20 * fputendian(fp) write native endianness in BigEndian= line
21 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
22 * globmatch(pat, str) check for glob match of str against pat
23 * checkheader(i,p,o) check header format from i against p and copy to o
24 *
25 * To copy header from input to output, use getheader(fin, fputs, fout)
26 */
27
28 #include "copyright.h"
29
30 #include <ctype.h>
31
32 #include "tiff.h" /* for int32 */
33 #include "rtio.h"
34 #include "color.h"
35 #include "resolu.h"
36
37 #define MAXLINE 2048
38
39 extern time_t timegm(struct tm *tm);
40
41 const char HDRSTR[] = "#?"; /* information header magic number */
42
43 const char FMTSTR[] = "FORMAT="; /* format identifier */
44
45 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
46 const char GMTSTR[] = "GMT="; /* GMT identifier */
47
48 const char BIGEND[] = "BigEndian="; /* big-endian variable */
49
50 static gethfunc mycheck;
51
52
53 void
54 newheader( /* identifying line of information header */
55 const char *s,
56 FILE *fp
57 )
58 {
59 fputs(HDRSTR, fp);
60 fputs(s, fp);
61 fputc('\n', fp);
62 }
63
64
65 int
66 headidval( /* get header id (return true if is id) */
67 char *r,
68 const char *s
69 )
70 {
71 const char *cp = HDRSTR;
72
73 while (*cp) if (*cp++ != *s++) return(0);
74 if (r == NULL) return(1);
75 while (*s && !isspace(*s)) *r++ = *s++;
76 *r = '\0';
77 return(1);
78 }
79
80
81 int
82 dateval( /* convert capture date line to UTC */
83 time_t *tloc,
84 const char *s
85 )
86 {
87 struct tm tms;
88 const char *cp = TMSTR;
89
90 while (*cp) if (*cp++ != *s++) return(0);
91 while (isspace(*s)) s++;
92 if (!*s) return(0);
93 if (sscanf(s, "%d:%d:%d %d:%d:%d",
94 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
95 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
96 return(0);
97 if (tloc == NULL)
98 return(1);
99 tms.tm_mon--;
100 tms.tm_year -= 1900;
101 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
102 *tloc = mktime(&tms);
103 return(1);
104 }
105
106
107 int
108 gmtval( /* convert GMT date line to UTC */
109 time_t *tloc,
110 const char *s
111 )
112 {
113 struct tm tms;
114 const char *cp = GMTSTR;
115
116 while (*cp) if (*cp++ != *s++) return(0);
117 while (isspace(*s)) s++;
118 if (!*s) return(0);
119 if (sscanf(s, "%d:%d:%d %d:%d:%d",
120 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
121 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
122 return(0);
123 if (tloc == NULL)
124 return(1);
125 tms.tm_mon--;
126 tms.tm_year -= 1900;
127 *tloc = timegm(&tms);
128 return(1);
129 }
130
131
132 void
133 fputdate( /* write out the given time value (local & GMT) */
134 time_t tv,
135 FILE *fp
136 )
137 {
138 struct tm *tms;
139
140 tms = localtime(&tv);
141 if (tms != NULL)
142 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
143 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
144 tms->tm_hour, tms->tm_min, tms->tm_sec);
145 tms = gmtime(&tv);
146 if (tms != NULL)
147 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
148 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
149 tms->tm_hour, tms->tm_min, tms->tm_sec);
150 }
151
152
153 void
154 fputnow( /* write out the current time */
155 FILE *fp
156 )
157 {
158 time_t tv;
159 time(&tv);
160 fputdate(tv, fp);
161 }
162
163
164 void
165 printargs( /* print arguments to a file */
166 int ac,
167 char **av,
168 FILE *fp
169 )
170 {
171 #if defined(_WIN32) || defined(_WIN64)
172 extern char *fixargv0(char *arg0);
173 char myav0[128];
174 /* clean up Windows executable path */
175 if (ac-- <= 0) return;
176 fputs(fixargv0(strcpy(myav0, *av++)), fp);
177 fputc(ac ? ' ' : '\n', fp);
178 #endif
179 while (ac-- > 0) {
180 fputword(*av++, fp);
181 fputc(ac ? ' ' : '\n', fp);
182 }
183 }
184
185
186 int
187 formatval( /* get format value (return true if format) */
188 char fmt[MAXFMTLEN],
189 const char *s
190 )
191 {
192 const char *cp = FMTSTR;
193 char *r = fmt;
194 /* check against format string */
195 while (*cp) if (*cp++ != *s++) return(0);
196 while (isspace(*s)) s++;
197 if (!*s) return(0);
198 if (r == NULL) /* just checking if format? */
199 return(1);
200 do /* copy format ID */
201 *r++ = *s++;
202 while (*s && r-fmt < MAXFMTLEN-1);
203
204 do /* remove trailing white space */
205 *r-- = '\0';
206 while (r > fmt && isspace(*r));
207
208 return(1);
209 }
210
211
212 void
213 fputformat( /* put out a format value */
214 const char *s,
215 FILE *fp
216 )
217 {
218 int align = 0;
219
220 fputs(FMTSTR, fp);
221 fputs(s, fp);
222 /* pad to align binary type for mmap() */
223 if (globmatch(PICFMT, s))
224 align = 0; /* not needed for picture data */
225 else if (!strncmp("float", s, 5))
226 align = sizeof(float);
227 else if (!strncmp("double", s, 6))
228 align = sizeof(double);
229 else if (!strncmp("16-bit", s, 6))
230 align = 2;
231 else if (!strncmp("32-bit", s, 6))
232 align = 4;
233 else if (!strncmp("64-bit", s, 6))
234 align = 8;
235 if (align) {
236 long pos = ftell(fp);
237 if (pos >= 0) {
238 pos = (pos + 2) % align;
239 if (pos) align -= pos;
240 else align = 0;
241 } else
242 align = 0;
243 }
244 while (align-- > 0)
245 putc(' ', fp);
246 fputc('\n', fp);
247 }
248
249
250 int
251 nativebigendian() /* are we native on a big-endian machine? */
252 {
253 union { int32 i; char c[4]; } u;
254
255 u.i = 1;
256
257 return(u.c[0] == 0);
258 }
259
260
261 int
262 isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */
263 const char *s
264 )
265 {
266 const char *be = BIGEND;
267
268 while ((*s != '\0') & (*be != '=') && *s++ == *be)
269 ++be;
270 if (*be != '=')
271 return(-1); /* irrelevant */
272 while (isspace(*s))
273 s++;
274 if (*s++ != '=')
275 return(-1);
276 while (isspace(*s))
277 s++;
278 return(*s == '1');
279 }
280
281
282 void
283 fputendian( /* write native endianness in BigEndian= line */
284 FILE *fp
285 )
286 {
287 fputs(BIGEND, fp);
288 if (nativebigendian())
289 fputs("1\n", fp);
290 else
291 fputs("0\n", fp);
292 }
293
294
295 int
296 getheader( /* get header from file */
297 FILE *fp,
298 gethfunc *f,
299 void *p
300 )
301 {
302 int rtotal = 0;
303 char buf[MAXLINE];
304 int firstc = fgetc(fp);
305
306 if (!isprint(firstc))
307 return(-1); /* messed up */
308 ungetc(firstc, fp);
309 for ( ; ; ) {
310 int rval = 0;
311 buf[MAXLINE-2] = '\n';
312 if (fgets(buf, MAXLINE, fp) == NULL)
313 return(-1);
314 if (buf[buf[0]=='\r'] == '\n') /* end of header? */
315 return(rtotal);
316 if (buf[MAXLINE-2] != '\n') {
317 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
318 buf[MAXLINE-2] = '\0';
319 }
320 if (f != NULL && (rval = (*f)(buf, p)) < 0)
321 return(-1);
322 rtotal += rval;
323 }
324 }
325
326
327 struct check {
328 FILE *fp;
329 char fs[MAXFMTLEN];
330 };
331
332
333 static int
334 mycheck( /* check a header line for format info. */
335 char *s,
336 void *cp
337 )
338 {
339 struct check *scp = (struct check *)cp;
340
341 if (!formatval(scp->fs, s) && scp->fp != NULL)
342 return(fputs(s, scp->fp));
343
344 return(0);
345 }
346
347
348 int
349 globmatch( /* check for match of s against pattern p */
350 const char *p,
351 const char *s
352 )
353 {
354 int setmatch;
355
356 do {
357 switch (*p) {
358 case '?': /* match any character */
359 if (!*s++)
360 return(0);
361 break;
362 case '*': /* match any string */
363 while (p[1] == '*') p++;
364 do
365 if ( (p[1]=='?') | (p[1]==*s) &&
366 globmatch(p+1,s) )
367 return(1);
368 while (*s++);
369 return(0);
370 case '[': /* character set */
371 setmatch = (*s == *++p);
372 if (!*p)
373 return(0);
374 while (*++p != ']') {
375 if (!*p)
376 return(0);
377 if (*p == '-') {
378 setmatch += (p[-1] <= *s) & (*s <= p[1]);
379 if (!*++p)
380 break;
381 } else
382 setmatch += (*p == *s);
383 }
384 if (!setmatch)
385 return(0);
386 s++;
387 break;
388 case '\\': /* literal next */
389 if (!*++p)
390 return(0);
391 /* fall through */
392 default: /* normal character */
393 if (*p != *s)
394 return(0);
395 s++;
396 break;
397 }
398 } while (*p++);
399 return(1);
400 }
401
402
403 /*
404 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
405 * matches the specification in fmt, 0 if no input format was found,
406 * and -1 if the input format does not match or there is an
407 * error reading the header. If fmt is empty, then -1 is returned
408 * if any input format is found (or there is an error), and 0 otherwise.
409 * If fmt contains any '*' or '?' characters, then checkheader
410 * does wildcard expansion and copies a matching result into fmt.
411 * Be sure that fmt is big enough to hold the match in such cases,
412 * and that it is not a static, read-only string!
413 * The input header (minus any format lines) is copied to fout
414 * if fout is not NULL.
415 */
416
417 int
418 checkheader(
419 FILE *fin,
420 char fmt[MAXFMTLEN],
421 FILE *fout
422 )
423 {
424 struct check cdat;
425 char *cp;
426
427 cdat.fp = fout;
428 cdat.fs[0] = '\0';
429 if (getheader(fin, mycheck, &cdat) < 0)
430 return(-1);
431 if (!cdat.fs[0])
432 return(0);
433 for (cp = fmt; *cp; cp++) /* check for globbing */
434 if ((*cp == '?') | (*cp == '*')) {
435 if (globmatch(fmt, cdat.fs)) {
436 strcpy(fmt, cdat.fs);
437 return(1);
438 } else
439 return(-1);
440 }
441 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
442 }
