root/radiance/ray/src/common/header.c
Revision: 2.49
Committed: Wed Jun 4 22:34:27 2025 UTC (7 weeks, 4 days ago) by greg
Changes since 2.48: +1 -9 lines
fix: Fixed reference to fixargv0()
2 static const char RCSid[] = "$Id: header.c,v 2.48 2022/03/21 17:03:51 greg Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in rtio.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * headidval(r,s) copy header identifier value in s to r
11 * dateval(t,s) get capture date value as UTC
12 * gmtval(t,s) get GMT as UTC
13 * fputdate(t,fp) put out the given UTC
14 * fputnow(fp) put out the current date and time
15 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 * formatval(r,s) copy the format value in s to r
17 * fputformat(s,fp) write "FORMAT=%s" to fp
18 * nativebigendian() are we native on big-endian machine?
19 * isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant)
20 * fputendian(fp) write native endianness in BigEndian= line
21 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
22 * globmatch(pat, str) check for glob match of str against pat
23 * checkheader(i,p,o) check header format from i against p and copy to o
24 *
25 * To copy header from input to output, use getheader(fin, fputs, fout)
26 */
27
28 #include "copyright.h"
29
30 #include <ctype.h>
31
32 #include "tiff.h" /* for int32 */
33 #include "rtio.h"
34 #include "color.h"
35 #include "resolu.h"
36
37 #define MAXLINE 2048
38
39 extern time_t timegm(struct tm *tm);
40
41 const char HDRSTR[] = "#?"; /* information header magic number */
42
43 const char FMTSTR[] = "FORMAT="; /* format identifier */
44
45 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
46 const char GMTSTR[] = "GMT="; /* GMT identifier */
47
48 const char BIGEND[] = "BigEndian="; /* big-endian variable */
49
50 static gethfunc mycheck;
51
52
53 void
54 newheader( /* identifying line of information header */
55 const char *s,
56 FILE *fp
57 )
58 {
59 fputs(HDRSTR, fp);
60 fputs(s, fp);
61 fputc('\n', fp);
62 }
63
64
65 int
66 headidval( /* get header id (return true if is id) */
67 char *r,
68 const char *s
69 )
70 {
71 const char *cp = HDRSTR;
72
73 while (*cp) if (*cp++ != *s++) return(0);
74 if (r == NULL) return(1);
75 while (*s && !isspace(*s)) *r++ = *s++;
76 *r = '\0';
77 return(1);
78 }
79
80
81 int
82 dateval( /* convert capture date line to UTC */
83 time_t *tloc,
84 const char *s
85 )
86 {
87 struct tm tms;
88 const char *cp = TMSTR;
89
90 while (*cp) if (*cp++ != *s++) return(0);
91 while (isspace(*s)) s++;
92 if (!*s) return(0);
93 if (sscanf(s, "%d:%d:%d %d:%d:%d",
94 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
95 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
96 return(0);
97 if (tloc == NULL)
98 return(1);
99 tms.tm_mon--;
100 tms.tm_year -= 1900;
101 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
102 *tloc = mktime(&tms);
103 return(1);
104 }
105
106
107 int
108 gmtval( /* convert GMT date line to UTC */
109 time_t *tloc,
110 const char *s
111 )
112 {
113 struct tm tms;
114 const char *cp = GMTSTR;
115
116 while (*cp) if (*cp++ != *s++) return(0);
117 while (isspace(*s)) s++;
118 if (!*s) return(0);
119 if (sscanf(s, "%d:%d:%d %d:%d:%d",
120 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
121 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
122 return(0);
123 if (tloc == NULL)
124 return(1);
125 tms.tm_mon--;
126 tms.tm_year -= 1900;
127 *tloc = timegm(&tms);
128 return(1);
129 }
130
131
132 void
133 fputdate( /* write out the given time value (local & GMT) */
134 time_t tv,
135 FILE *fp
136 )
137 {
138 struct tm *tms;
139
140 tms = localtime(&tv);
141 if (tms != NULL)
142 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
143 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
144 tms->tm_hour, tms->tm_min, tms->tm_sec);
145 tms = gmtime(&tv);
146 if (tms != NULL)
147 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
148 tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
149 tms->tm_hour, tms->tm_min, tms->tm_sec);
150 }
151
152
153 void
154 fputnow( /* write out the current time */
155 FILE *fp
156 )
157 {
158 time_t tv;
159 time(&tv);
160 fputdate(tv, fp);
161 }
162
163
164 void
165 printargs( /* print arguments to a file */
166 int ac,
167 char **av,
168 FILE *fp
169 )
170 {
171 while (ac-- > 0) {
172 fputword(*av++, fp);
173 fputc(ac ? ' ' : '\n', fp);
174 }
175 }
176
177
178 int
179 formatval( /* get format value (return true if format) */
180 char fmt[MAXFMTLEN],
181 const char *s
182 )
183 {
184 const char *cp = FMTSTR;
185 char *r = fmt;
186 /* check against format string */
187 while (*cp) if (*cp++ != *s++) return(0);
188 while (isspace(*s)) s++;
189 if (!*s) return(0);
190 if (r == NULL) /* just checking if format? */
191 return(1);
192 do /* copy format ID */
193 *r++ = *s++;
194 while (*s && r-fmt < MAXFMTLEN-1);
195
196 do /* remove trailing white space */
197 *r-- = '\0';
198 while (r > fmt && isspace(*r));
199
200 return(1);
201 }
202
203
204 void
205 fputformat( /* put out a format value */
206 const char *s,
207 FILE *fp
208 )
209 {
210 int align = 0;
211
212 fputs(FMTSTR, fp);
213 fputs(s, fp);
214 /* pad to align binary type for mmap() */
215 if (globmatch(PICFMT, s))
216 align = 0; /* not needed for picture data */
217 else if (!strncmp("float", s, 5))
218 align = sizeof(float);
219 else if (!strncmp("double", s, 6))
220 align = sizeof(double);
221 else if (!strncmp("16-bit", s, 6))
222 align = 2;
223 else if (!strncmp("32-bit", s, 6))
224 align = 4;
225 else if (!strncmp("64-bit", s, 6))
226 align = 8;
227 if (align) {
228 long pos = ftell(fp);
229 if (pos >= 0) {
230 pos = (pos + 2) % align;
231 if (pos) align -= pos;
232 else align = 0;
233 } else
234 align = 0;
235 }
236 while (align-- > 0)
237 putc(' ', fp);
238 fputc('\n', fp);
239 }
240
241
242 int
243 nativebigendian() /* are we native on a big-endian machine? */
244 {
245 union { int32 i; char c[4]; } u;
246
247 u.i = 1;
248
249 return(u.c[0] == 0);
250 }
251
252
253 int
254 isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */
255 const char *s
256 )
257 {
258 const char *be = BIGEND;
259
260 while ((*s != '\0') & (*be != '=') && *s++ == *be)
261 ++be;
262 if (*be != '=')
263 return(-1); /* irrelevant */
264 while (isspace(*s))
265 s++;
266 if (*s++ != '=')
267 return(-1);
268 while (isspace(*s))
269 s++;
270 return(*s == '1');
271 }
272
273
274 void
275 fputendian( /* write native endianness in BigEndian= line */
276 FILE *fp
277 )
278 {
279 fputs(BIGEND, fp);
280 if (nativebigendian())
281 fputs("1\n", fp);
282 else
283 fputs("0\n", fp);
284 }
285
286
287 int
288 getheader( /* get header from file */
289 FILE *fp,
290 gethfunc *f,
291 void *p
292 )
293 {
294 int rtotal = 0;
295 char buf[MAXLINE];
296 int firstc = fgetc(fp);
297
298 if (!isprint(firstc))
299 return(-1); /* messed up */
300 ungetc(firstc, fp);
301 for ( ; ; ) {
302 int rval = 0;
303 buf[MAXLINE-2] = '\n';
304 if (fgets(buf, MAXLINE, fp) == NULL)
305 return(-1);
306 if (buf[buf[0]=='\r'] == '\n') /* end of header? */
307 return(rtotal);
308 if (buf[MAXLINE-2] != '\n') {
309 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
310 buf[MAXLINE-2] = '\0';
311 }
312 if (f != NULL && (rval = (*f)(buf, p)) < 0)
313 return(-1);
314 rtotal += rval;
315 }
316 }
317
318
319 struct check {
320 FILE *fp;
321 char fs[MAXFMTLEN];
322 };
323
324
325 static int
326 mycheck( /* check a header line for format info. */
327 char *s,
328 void *cp
329 )
330 {
331 struct check *scp = (struct check *)cp;
332
333 if (!formatval(scp->fs, s) && scp->fp != NULL)
334 return(fputs(s, scp->fp));
335
336 return(0);
337 }
338
339
340 int
341 globmatch( /* check for match of s against pattern p */
342 const char *p,
343 const char *s
344 )
345 {
346 int setmatch;
347
348 do {
349 switch (*p) {
350 case '?': /* match any character */
351 if (!*s++)
352 return(0);
353 break;
354 case '*': /* match any string */
355 while (p[1] == '*') p++;
356 do
357 if ( (p[1]=='?') | (p[1]==*s) &&
358 globmatch(p+1,s) )
359 return(1);
360 while (*s++);
361 return(0);
362 case '[': /* character set */
363 setmatch = (*s == *++p);
364 if (!*p)
365 return(0);
366 while (*++p != ']') {
367 if (!*p)
368 return(0);
369 if (*p == '-') {
370 setmatch += (p[-1] <= *s) & (*s <= p[1]);
371 if (!*++p)
372 break;
373 } else
374 setmatch += (*p == *s);
375 }
376 if (!setmatch)
377 return(0);
378 s++;
379 break;
380 case '\\': /* literal next */
381 if (!*++p)
382 return(0);
383 /* fall through */
384 default: /* normal character */
385 if (*p != *s)
386 return(0);
387 s++;
388 break;
389 }
390 } while (*p++);
391 return(1);
392 }
393
394
395 /*
396 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
397 * matches the specification in fmt, 0 if no input format was found,
398 * and -1 if the input format does not match or there is an
399 * error reading the header. If fmt is empty, then -1 is returned
400 * if any input format is found (or there is an error), and 0 otherwise.
401 * If fmt contains any '*' or '?' characters, then checkheader
402 * does wildcard expansion and copies a matching result into fmt.
403 * Be sure that fmt is big enough to hold the match in such cases,
404 * and that it is not a static, read-only string!
405 * The input header (minus any format lines) is copied to fout
406 * if fout is not NULL.
407 */
408
409 int
410 checkheader(
411 FILE *fin,
412 char fmt[MAXFMTLEN],
413 FILE *fout
414 )
415 {
416 struct check cdat;
417 char *cp;
418
419 cdat.fp = fout;
420 cdat.fs[0] = '\0';
421 if (getheader(fin, mycheck, &cdat) < 0)
422 return(-1);
423 if (!cdat.fs[0])
424 return(0);
425 for (cp = fmt; *cp; cp++) /* check for globbing */
426 if ((*cp == '?') | (*cp == '*')) {
427 if (globmatch(fmt, cdat.fs)) {
428 strcpy(fmt, cdat.fs);
429 return(1);
430 } else
431 return(-1);
432 }
433 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
434 }
