root/radiance/ray/src/common/header.c
Revision: 2.23
Committed: Tue Feb 1 01:28:16 2005 UTC (20 years, 3 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
Changes since 2.22: +1 -2 lines
Eliminated redundant include files.
2 static const char RCSid[] = "$Id: header.c,v 2.22 2004/01/02 11:35:17 schorsch Exp $";
5 * header.c - routines for reading and writing information headers.
6 *
7 * Externals declared in resolu.h
8 *
9 * newheader(t,fp) start new information header identified by string t
10 * isheadid(s) returns true if s is a header id line
11 * headidval(r,s) copy header identifier value in s to r
12 * dateval(t,s) get capture date value
13 * isdate(s) returns true if s is a date line
14 * fputdate(t,fp) put out the given capture date and time
15 * fputnow(fp) put out the current date and time
16 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
17 * isformat(s) returns true if s is of the form "FORMAT=*"
18 * formatval(r,s) copy the format value in s to r
19 * fputformat(s,fp) write "FORMAT=%s" to fp
20 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
21 * globmatch(pat, str) check for glob match of str against pat
22 * checkheader(i,p,o) check header format from i against p and copy to o
23 *
24 * To copy header from input to output, use getheader(fin, fputs, fout)
25 */
26
27 #include "copyright.h"
28
29 #include <ctype.h>
30
31 #include "rtio.h"
32 #include "resolu.h"
33
34 #define MAXLINE 512
35
36 char HDRSTR[] = "#?"; /* information header magic number */
37
38 char FMTSTR[] = "FORMAT="; /* format identifier */
39
40 char TMSTR[] = "CAPDATE="; /* capture date identifier */
41
42 static gethfunc mycheck;
43
44
45 extern void
46 newheader( /* identifying line of information header */
47 char *s,
48 register FILE *fp
49 )
50 {
51 fputs(HDRSTR, fp);
52 fputs(s, fp);
53 putc('\n', fp);
54 }
55
56
57 extern int
58 headidval( /* get header id (return true if is id) */
59 register char *r,
60 register char *s
61 )
62 {
63 register char *cp = HDRSTR;
64
65 while (*cp) if (*cp++ != *s++) return(0);
66 if (r == NULL) return(1);
67 while (*s && !isspace(*s)) *r++ = *s++;
68 *r = '\0';
69 return(1);
70 }
71
72
73 extern int
74 isheadid( /* check to see if line is header id */
75 char *s
76 )
77 {
78 return(headidval(NULL, s));
79 }
80
81
82 extern int
83 dateval( /* get capture date value */
84 time_t *tloc,
85 char *s
86 )
87 {
88 struct tm tms;
89 register char *cp = TMSTR;
90
91 while (*cp) if (*cp++ != *s++) return(0);
92 while (isspace(*s)) s++;
93 if (!*s) return(0);
94 if (sscanf(s, "%d:%d:%d %d:%d:%d",
95 &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
96 &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
97 return(0);
98 if (tloc == NULL)
99 return(1);
100 tms.tm_mon--;
101 tms.tm_year -= 1900;
102 tms.tm_isdst = -1; /* ask mktime() to figure out DST */
103 *tloc = mktime(&tms);
104 return(1);
105 }
106
107
108 extern int
109 isdate( /* is the given line a capture date? */
110 char *s
111 )
112 {
113 return(dateval(NULL, s));
114 }
115
116
117 extern void
118 fputdate( /* write out the given time value */
119 time_t tv,
120 FILE *fp
121 )
122 {
123 struct tm *tm = localtime(&tv);
124 if (tm == NULL)
125 return;
126 fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
127 tm->tm_year+1900, tm->tm_mon+1, tm->tm_mday,
128 tm->tm_hour, tm->tm_min, tm->tm_sec);
129 }
130
131
132 extern void
133 fputnow( /* write out the current time */
134 FILE *fp
135 )
136 {
137 time_t tv;
138 time(&tv);
139 fputdate(tv, fp);
140 }
141
142
143 extern void
144 printargs( /* print arguments to a file */
145 int ac,
146 char **av,
147 FILE *fp
148 )
149 {
150 while (ac-- > 0) {
151 fputword(*av++, fp);
152 fputc(ac ? ' ' : '\n', fp);
153 }
154 }
155
156
157 extern int
158 formatval( /* get format value (return true if format) */
159 register char *r,
160 register char *s
161 )
162 {
163 register char *cp = FMTSTR;
164
165 while (*cp) if (*cp++ != *s++) return(0);
166 while (isspace(*s)) s++;
167 if (!*s) return(0);
168 if (r == NULL) return(1);
169 do
170 *r++ = *s++;
171 while(*s && !isspace(*s));
172 *r = '\0';
173 return(1);
174 }
175
176
177 extern int
178 isformat( /* is line a format line? */
179 char *s
180 )
181 {
182 return(formatval(NULL, s));
183 }
184
185
186 extern void
187 fputformat( /* put out a format value */
188 char *s,
189 FILE *fp
190 )
191 {
192 fputs(FMTSTR, fp);
193 fputs(s, fp);
194 putc('\n', fp);
195 }
196
197
198 extern int
199 getheader( /* get header from file */
200 FILE *fp,
201 gethfunc *f,
202 void *p
203 )
204 {
205 char buf[MAXLINE];
206
207 for ( ; ; ) {
208 buf[MAXLINE-2] = '\n';
209 if (fgets(buf, MAXLINE, fp) == NULL)
210 return(-1);
211 if (buf[0] == '\n')
212 return(0);
213 #ifdef MSDOS
214 if (buf[0] == '\r' && buf[1] == '\n')
215 return(0);
216 #endif
217 if (buf[MAXLINE-2] != '\n') {
218 ungetc(buf[MAXLINE-2], fp); /* prevent false end */
219 buf[MAXLINE-2] = '\0';
220 }
221 if (f != NULL && (*f)(buf, p) < 0)
222 return(-1);
223 }
224 }
225
226
227 struct check {
228 FILE *fp;
229 char fs[64];
230 };
231
232
233 static int
234 mycheck( /* check a header line for format info. */
235 char *s,
236 void *cp
237 )
238 {
239 if (!formatval(((struct check*)cp)->fs, s)
240 && ((struct check*)cp)->fp != NULL) {
241 fputs(s, ((struct check*)cp)->fp);
242 }
243 return(0);
244 }
245
246
247 extern int
248 globmatch( /* check for match of s against pattern p */
249 register char *p,
250 register char *s
251 )
252 {
253 int setmatch;
254
255 do {
256 switch (*p) {
257 case '?': /* match any character */
258 if (!*s++)
259 return(0);
260 break;
261 case '*': /* match any string */
262 while (p[1] == '*') p++;
263 do
264 if ( (p[1]=='?' || p[1]==*s) &&
265 globmatch(p+1,s) )
266 return(1);
267 while (*s++);
268 return(0);
269 case '[': /* character set */
270 setmatch = *s == *++p;
271 if (!*p)
272 return(0);
273 while (*++p != ']') {
274 if (!*p)
275 return(0);
276 if (*p == '-') {
277 setmatch += p[-1] <= *s && *s <= p[1];
278 if (!*++p)
279 break;
280 } else
281 setmatch += *p == *s;
282 }
283 if (!setmatch)
284 return(0);
285 s++;
286 break;
287 case '\\': /* literal next */
288 p++;
289 /* fall through */
290 default: /* normal character */
291 if (*p != *s)
292 return(0);
293 s++;
294 break;
295 }
296 } while (*p++);
297 return(1);
298 }
299
300
301 /*
302 * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
303 * matches the specification in fmt, 0 if no input format was found,
304 * and -1 if the input format does not match or there is an
305 * error reading the header. If fmt is empty, then -1 is returned
306 * if any input format is found (or there is an error), and 0 otherwise.
307 * If fmt contains any '*' or '?' characters, then checkheader
308 * does wildcard expansion and copies a matching result into fmt.
309 * Be sure that fmt is big enough to hold the match in such cases,
310 * and that it is not a static, read-only string!
311 * The input header (minus any format lines) is copied to fout
312 * if fout is not NULL.
313 */
314
315 extern int
316 checkheader(
317 FILE *fin,
318 char *fmt,
319 FILE *fout
320 )
321 {
322 struct check cdat;
323 register char *cp;
324
325 cdat.fp = fout;
326 cdat.fs[0] = '\0';
327 if (getheader(fin, mycheck, &cdat) < 0)
328 return(-1);
329 if (!cdat.fs[0])
330 return(0);
331 for (cp = fmt; *cp; cp++) /* check for globbing */
332 if ((*cp == '?') | (*cp == '*')) {
333 if (globmatch(fmt, cdat.fs)) {
334 strcpy(fmt, cdat.fs);
335 return(1);
336 } else
337 return(-1);
338 }
339 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
340 }
