root/Development/ray/src/common/header.c
Revision: 2.48
Committed: Mon Mar 21 17:03:51 2022 UTC (3 years, 9 months ago) by greg
Changes since 2.47: +11 -6 lines
feat: Support for format IDs with internal white space
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.48 static const char RCSid[] = "$Id: header.c,v 2.47 2022/03/14 22:57:24 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * header.c - routines for reading and writing information headers.
6     *
7 greg 2.35 * Externals declared in rtio.h
8 greg 1.3 *
9 greg 2.4 * newheader(t,fp) start new information header identified by string t
10     * headidval(r,s) copy header identifier value in s to r
11 greg 2.25 * dateval(t,s) get capture date value as UTC
12     * gmtval(t,s) get GMT as UTC
13     * fputdate(t,fp) put out the given UTC
14 greg 2.11 * fputnow(fp) put out the current date and time
15 greg 2.3 * printargs(ac,av,fp) print an argument list to fp, followed by '\n'
16 greg 1.3 * formatval(r,s) copy the format value in s to r
17     * fputformat(s,fp) write "FORMAT=%s" to fp
18 greg 2.36 * nativebigendian() are we native on big-endian machine?
19     * isbigendian(s) header line matches "BigEndian=1" (-1 if irrelevant)
20     * fputendian(fp) write native endianness in BigEndian= line
21 greg 1.3 * getheader(fp,f,p) read header from fp, calling f(s,p) on each line
22 greg 2.6 * globmatch(pat, str) check for glob match of str against pat
23 greg 1.3 * checkheader(i,p,o) check header format from i against p and copy to o
24     *
25     * To copy header from input to output, use getheader(fin, fputs, fout)
26 greg 1.1 */
27
28 greg 2.12 #include "copyright.h"
29 greg 2.11
30 greg 1.3 #include <ctype.h>
31 schorsch 2.17
32 greg 2.36 #include "tiff.h" /* for int32 */
33 greg 2.18 #include "rtio.h"
34 greg 2.44 #include "color.h"
35 greg 2.18 #include "resolu.h"
36 schorsch 2.14
37 greg 2.24 #define MAXLINE 2048
38 greg 2.2
39 greg 2.26 extern time_t timegm(struct tm *tm);
40
41 greg 2.25 const char HDRSTR[] = "#?"; /* information header magic number */
42 greg 1.2
43 greg 2.25 const char FMTSTR[] = "FORMAT="; /* format identifier */
44 greg 1.2
45 greg 2.25 const char TMSTR[] = "CAPDATE="; /* capture date identifier */
46     const char GMTSTR[] = "GMT="; /* GMT identifier */
47 greg 2.16
48 greg 2.36 const char BIGEND[] = "BigEndian="; /* big-endian variable */
49
50 schorsch 2.22 static gethfunc mycheck;
51 greg 2.4
52 greg 2.11
53 greg 2.29 void
54 schorsch 2.22 newheader( /* identifying line of information header */
55 greg 2.31 const char *s,
56 greg 2.25 FILE *fp
57 schorsch 2.22 )
58 greg 2.4 {
59     fputs(HDRSTR, fp);
60     fputs(s, fp);
61 greg 2.41 fputc('\n', fp);
62 greg 2.4 }
63
64
65 greg 2.29 int
66 schorsch 2.22 headidval( /* get header id (return true if is id) */
67 greg 2.25 char *r,
68 greg 2.31 const char *s
69 schorsch 2.22 )
70 greg 2.4 {
71 greg 2.25 const char *cp = HDRSTR;
72 greg 2.4
73     while (*cp) if (*cp++ != *s++) return(0);
74     if (r == NULL) return(1);
75 gregl 2.9 while (*s && !isspace(*s)) *r++ = *s++;
76 greg 2.4 *r = '\0';
77     return(1);
78     }
79
80
81 greg 2.29 int
82 greg 2.25 dateval( /* convert capture date line to UTC */
83 schorsch 2.22 time_t *tloc,
84 greg 2.31 const char *s
85 schorsch 2.22 )
86 greg 2.11 {
87     struct tm tms;
88 greg 2.25 const char *cp = TMSTR;
89 greg 2.11
90     while (*cp) if (*cp++ != *s++) return(0);
91     while (isspace(*s)) s++;
92     if (!*s) return(0);
93     if (sscanf(s, "%d:%d:%d %d:%d:%d",
94     &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
95     &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
96     return(0);
97     if (tloc == NULL)
98     return(1);
99     tms.tm_mon--;
100     tms.tm_year -= 1900;
101     tms.tm_isdst = -1; /* ask mktime() to figure out DST */
102     *tloc = mktime(&tms);
103     return(1);
104     }
105
106
107 greg 2.29 int
108 greg 2.25 gmtval( /* convert GMT date line to UTC */
109     time_t *tloc,
110 greg 2.31 const char *s
111 schorsch 2.22 )
112 greg 2.11 {
113 greg 2.25 struct tm tms;
114     const char *cp = GMTSTR;
115
116     while (*cp) if (*cp++ != *s++) return(0);
117     while (isspace(*s)) s++;
118     if (!*s) return(0);
119     if (sscanf(s, "%d:%d:%d %d:%d:%d",
120     &tms.tm_year, &tms.tm_mon, &tms.tm_mday,
121     &tms.tm_hour, &tms.tm_min, &tms.tm_sec) != 6)
122     return(0);
123     if (tloc == NULL)
124     return(1);
125     tms.tm_mon--;
126     tms.tm_year -= 1900;
127     *tloc = timegm(&tms);
128     return(1);
129 greg 2.11 }
130
131
132 greg 2.29 void
133 greg 2.25 fputdate( /* write out the given time value (local & GMT) */
134 schorsch 2.22 time_t tv,
135     FILE *fp
136     )
137 greg 2.11 {
138 greg 2.25 struct tm *tms;
139
140     tms = localtime(&tv);
141     if (tms != NULL)
142     fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", TMSTR,
143     tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
144     tms->tm_hour, tms->tm_min, tms->tm_sec);
145     tms = gmtime(&tv);
146     if (tms != NULL)
147     fprintf(fp, "%s %04d:%02d:%02d %02d:%02d:%02d\n", GMTSTR,
148     tms->tm_year+1900, tms->tm_mon+1, tms->tm_mday,
149     tms->tm_hour, tms->tm_min, tms->tm_sec);
150 greg 2.11 }
151
152
153 greg 2.29 void
154 schorsch 2.22 fputnow( /* write out the current time */
155     FILE *fp
156     )
157 greg 2.11 {
158     time_t tv;
159     time(&tv);
160     fputdate(tv, fp);
161     }
162
163
164 greg 2.29 void
165 schorsch 2.22 printargs( /* print arguments to a file */
166     int ac,
167     char **av,
168     FILE *fp
169     )
170 greg 1.1 {
171 greg 2.39 #if defined(_WIN32) || defined(_WIN64)
172     extern char *fixargv0(char *arg0);
173     char myav0[128];
174     /* clean up Windows executable path */
175 greg 2.40 if (ac-- <= 0) return;
176 greg 2.39 fputs(fixargv0(strcpy(myav0, *av++)), fp);
177 greg 2.40 fputc(ac ? ' ' : '\n', fp);
178 greg 2.39 #endif
179 greg 1.1 while (ac-- > 0) {
180 greg 2.11 fputword(*av++, fp);
181     fputc(ac ? ' ' : '\n', fp);
182 greg 1.1 }
183     }
184
185
186 greg 2.29 int
187 schorsch 2.22 formatval( /* get format value (return true if format) */
188 greg 2.32 char fmt[MAXFMTLEN],
189 greg 2.31 const char *s
190 schorsch 2.22 )
191 greg 1.2 {
192 greg 2.25 const char *cp = FMTSTR;
193 greg 2.32 char *r = fmt;
194 greg 2.48 /* check against format string */
195 greg 2.4 while (*cp) if (*cp++ != *s++) return(0);
196 greg 1.3 while (isspace(*s)) s++;
197 greg 2.4 if (!*s) return(0);
198 greg 2.48 if (r == NULL) /* just checking if format? */
199     return(1);
200     do /* copy format ID */
201 greg 2.5 *r++ = *s++;
202 greg 2.48 while (*s && r-fmt < MAXFMTLEN-1);
203
204     do /* remove trailing white space */
205     *r-- = '\0';
206     while (r > fmt && isspace(*r));
207
208 greg 2.4 return(1);
209 greg 1.2 }
210
211
212 greg 2.29 void
213 schorsch 2.22 fputformat( /* put out a format value */
214 greg 2.31 const char *s,
215 schorsch 2.22 FILE *fp
216     )
217 greg 1.2 {
218 greg 2.41 int align = 0;
219
220 greg 1.2 fputs(FMTSTR, fp);
221     fputs(s, fp);
222 greg 2.41 /* pad to align binary type for mmap() */
223 greg 2.44 if (globmatch(PICFMT, s))
224     align = 0; /* not needed for picture data */
225     else if (!strncmp("float", s, 5))
226 greg 2.43 align = sizeof(float);
227 greg 2.44 else if (!strncmp("double", s, 6))
228 greg 2.43 align = sizeof(double);
229 greg 2.44 else if (!strncmp("16-bit", s, 6))
230 greg 2.42 align = 2;
231 greg 2.44 else if (!strncmp("32-bit", s, 6))
232 greg 2.41 align = 4;
233 greg 2.44 else if (!strncmp("64-bit", s, 6))
234 greg 2.41 align = 8;
235     if (align) {
236     long pos = ftell(fp);
237     if (pos >= 0) {
238     pos = (pos + 2) % align;
239     if (pos) align -= pos;
240     else align = 0;
241     } else
242     align = 0;
243     }
244     while (align-- > 0)
245     putc(' ', fp);
246     fputc('\n', fp);
247 greg 1.2 }
248
249
250 greg 2.29 int
251 greg 2.36 nativebigendian() /* are we native on a big-endian machine? */
252     {
253     union { int32 i; char c[4]; } u;
254
255     u.i = 1;
256
257     return(u.c[0] == 0);
258     }
259
260
261     int
262     isbigendian( /* header line says "BigEndian=1" (-1 if irrelevant) */
263     const char *s
264     )
265     {
266     const char *be = BIGEND;
267
268 greg 2.37 while ((*s != '\0') & (*be != '=') && *s++ == *be)
269 greg 2.36 ++be;
270     if (*be != '=')
271     return(-1); /* irrelevant */
272     while (isspace(*s))
273     s++;
274     if (*s++ != '=')
275     return(-1);
276     while (isspace(*s))
277     s++;
278     return(*s == '1');
279     }
280
281
282     void
283     fputendian( /* write native endianness in BigEndian= line */
284     FILE *fp
285     )
286     {
287     fputs(BIGEND, fp);
288     if (nativebigendian())
289     fputs("1\n", fp);
290     else
291     fputs("0\n", fp);
292     }
293
294
295     int
296 schorsch 2.22 getheader( /* get header from file */
297     FILE *fp,
298     gethfunc *f,
299     void *p
300     )
301 greg 1.1 {
302 greg 2.30 int rtotal = 0;
303 greg 1.1 char buf[MAXLINE];
304 greg 2.34 int firstc = fgetc(fp);
305 greg 1.1
306 greg 2.34 if (!isprint(firstc))
307     return(-1); /* messed up */
308     ungetc(firstc, fp);
309 greg 1.1 for ( ; ; ) {
310 greg 2.30 int rval = 0;
311 greg 1.1 buf[MAXLINE-2] = '\n';
312 greg 2.3 if (fgets(buf, MAXLINE, fp) == NULL)
313 greg 1.1 return(-1);
314 greg 2.34 if (buf[buf[0]=='\r'] == '\n') /* end of header? */
315 greg 2.30 return(rtotal);
316 greg 1.1 if (buf[MAXLINE-2] != '\n') {
317     ungetc(buf[MAXLINE-2], fp); /* prevent false end */
318     buf[MAXLINE-2] = '\0';
319     }
320 greg 2.30 if (f != NULL && (rval = (*f)(buf, p)) < 0)
321 gwlarson 2.10 return(-1);
322 greg 2.30 rtotal += rval;
323 greg 1.1 }
324     }
325
326
327 greg 1.2 struct check {
328     FILE *fp;
329 greg 2.32 char fs[MAXFMTLEN];
330 greg 1.2 };
331 greg 1.1
332 greg 1.2
333 greg 2.11 static int
334 schorsch 2.22 mycheck( /* check a header line for format info. */
335     char *s,
336     void *cp
337     )
338     {
339 greg 2.33 struct check *scp = (struct check *)cp;
340
341     if (!formatval(scp->fs, s) && scp->fp != NULL)
342 greg 2.38 return(fputs(s, scp->fp));
343 greg 2.33
344 greg 2.11 return(0);
345 greg 1.1 }
346
347
348 greg 2.29 int
349 schorsch 2.22 globmatch( /* check for match of s against pattern p */
350 greg 2.31 const char *p,
351     const char *s
352 schorsch 2.22 )
353 greg 1.3 {
354 greg 2.11 int setmatch;
355 greg 1.3
356     do {
357     switch (*p) {
358     case '?': /* match any character */
359     if (!*s++)
360     return(0);
361     break;
362     case '*': /* match any string */
363     while (p[1] == '*') p++;
364     do
365 greg 2.28 if ( (p[1]=='?') | (p[1]==*s) &&
366 greg 2.6 globmatch(p+1,s) )
367 greg 1.3 return(1);
368     while (*s++);
369     return(0);
370 greg 2.11 case '[': /* character set */
371 greg 2.46 setmatch = (*s == *++p);
372 greg 2.11 if (!*p)
373     return(0);
374     while (*++p != ']') {
375     if (!*p)
376     return(0);
377     if (*p == '-') {
378 greg 2.45 setmatch += (p[-1] <= *s) & (*s <= p[1]);
379 greg 2.11 if (!*++p)
380     break;
381     } else
382 greg 2.28 setmatch += (*p == *s);
383 greg 2.11 }
384     if (!setmatch)
385     return(0);
386     s++;
387     break;
388 greg 1.3 case '\\': /* literal next */
389 greg 2.47 if (!*++p)
390     return(0);
391 greg 1.3 /* fall through */
392     default: /* normal character */
393 greg 2.47 if (*p != *s)
394 greg 1.3 return(0);
395     s++;
396     break;
397     }
398     } while (*p++);
399     return(1);
400     }
401
402
403     /*
404     * Checkheader(fin,fmt,fout) returns a value of 1 if the input format
405     * matches the specification in fmt, 0 if no input format was found,
406     * and -1 if the input format does not match or there is an
407 greg 1.4 * error reading the header. If fmt is empty, then -1 is returned
408 greg 1.3 * if any input format is found (or there is an error), and 0 otherwise.
409     * If fmt contains any '*' or '?' characters, then checkheader
410     * does wildcard expansion and copies a matching result into fmt.
411 greg 2.7 * Be sure that fmt is big enough to hold the match in such cases,
412     * and that it is not a static, read-only string!
413 greg 1.3 * The input header (minus any format lines) is copied to fout
414     * if fout is not NULL.
415     */
416
417 greg 2.29 int
418 schorsch 2.22 checkheader(
419     FILE *fin,
420 greg 2.32 char fmt[MAXFMTLEN],
421 schorsch 2.22 FILE *fout
422     )
423 greg 1.1 {
424 greg 1.2 struct check cdat;
425 greg 2.25 char *cp;
426 greg 1.2
427     cdat.fp = fout;
428     cdat.fs[0] = '\0';
429 schorsch 2.22 if (getheader(fin, mycheck, &cdat) < 0)
430 greg 1.3 return(-1);
431 greg 2.6 if (!cdat.fs[0])
432     return(0);
433 greg 2.7 for (cp = fmt; *cp; cp++) /* check for globbing */
434 schorsch 2.20 if ((*cp == '?') | (*cp == '*')) {
435 greg 2.7 if (globmatch(fmt, cdat.fs)) {
436     strcpy(fmt, cdat.fs);
437     return(1);
438     } else
439     return(-1);
440 schorsch 2.19 }
441 greg 2.7 return(strcmp(fmt, cdat.fs) ? -1 : 1); /* literal match */
442 greg 1.1 }
