root/radiance/ray/src/common/header.c
Mon Mar 21 17:03:51 2022 UTC (2 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.47: +11 -6 lines
Diff to previous 2.47 , to selected 2.43
feat: Support for format IDs with internal white space
Mon Mar 14 22:57:24 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.46: +4 -3 lines
Diff to previous 2.46 , to selected 2.43
fix: repair in last change, which broke globmatch()
Mon Mar 14 19:25:56 2022 UTC (2 years, 2 months ago) by greg
Diff to previous 2.45 , to selected 2.43
fix: Dealt with minor corner case in globmatch()
Sun Mar 6 16:33:44 2022 UTC (2 years, 3 months ago) by greg
Diff to previous 2.44 , to selected 2.43
perf: truly minor optimization
Sun Mar 6 16:27:55 2022 UTC (2 years, 3 months ago) by greg
Changes since 2.43: +9 -6 lines
Diff to previous 2.43
perf: Turned off alignment for Radiance picture files (not needed)
Revision 2.43 - (view) (download) (annotate) - [selected]
Fri Mar 4 17:16:12 2022 UTC (2 years, 3 months ago) by greg
Changes since 2.42: +8 -4 lines
Diff to previous 2.42
refactor: made fputformat() more accurate wrt types
Thu Mar 3 15:43:04 2022 UTC (2 years, 3 months ago) by greg
Changes since 2.41: +5 -3 lines
Diff to previous 2.41 , to selected 2.43
feat: Added alignment times to fputformat()
Thu Mar 3 03:55:12 2022 UTC (2 years, 3 months ago) by greg
Changes since 2.40: +21 -3 lines
Diff to previous 2.40 , to selected 2.43
feat: Added float and double alignment to i/o routines for future mmap() use
Sat Jul 25 01:10:38 2020 UTC (3 years, 10 months ago) by greg
Diff to previous 2.39 , to selected 2.43
fix: added missing file pointer to fputc() call
Fri Jul 24 16:58:16 2020 UTC (3 years, 10 months ago) by greg
Changes since 2.38: +9 -1 lines
Diff to previous 2.38 , to selected 2.43
Hopeful fix to Windows test issues
Tue Sep 24 21:25:59 2019 UTC (4 years, 8 months ago) by greg
Diff to previous 2.37 , to selected 2.43
Return fputs() value to test for error
Wed Aug 14 19:52:39 2019 UTC (4 years, 9 months ago) by greg
Diff to previous 2.36 , to selected 2.43
Fixed issue in isbigendian(s)
Wed Aug 14 18:20:02 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.35: +52 -1 lines
Diff to previous 2.35 , to selected 2.43
Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
Diff to previous 2.34 , to selected 2.43
Sun Jun 9 18:22:20 2019 UTC (4 years, 11 months ago) by greg
Changes since 2.33: +6 -2 lines
Diff to previous 2.33 , to selected 2.43
Added error checking for non-ASCII headers
Sat May 25 04:00:54 2019 UTC (5 years ago) by greg
Changes since 2.32: +6 -5 lines
Diff to previous 2.32 , to selected 2.43
Cleaned up code -- should not affect behavior
Thu Aug 2 18:33:42 2018 UTC (5 years, 10 months ago) by greg
Changes since 2.31: +6 -5 lines
Diff to previous 2.31 , to selected 2.43
Wed May 10 18:02:08 2017 UTC (7 years ago) by greg
Changes since 2.30: +9 -9 lines
Diff to previous 2.30 , to selected 2.43
Added const modifiers to a number of char * parameters
Sun May 7 16:14:19 2017 UTC (7 years, 1 month ago) by greg
Changes since 2.29: +6 -3 lines
Diff to previous 2.29 , to selected 2.43
Chagned getheader() to return total of non-negative return values from callback
Fri May 30 23:43:48 2014 UTC (10 years ago) by greg
Changes since 2.28: +13 -13 lines
Diff to previous 2.28 , to selected 2.43
Removed unnecessary "extern" modifiers on functions
Thu Aug 9 23:15:38 2012 UTC (11 years, 9 months ago) by greg
Changes since 2.27: +6 -6 lines
Diff to previous 2.27 , to selected 2.43
Hopeful fix for Windoze and ASCII input files read in binary mode
Sun Jun 10 02:46:12 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.26: +1 -5 lines
Diff to previous 2.26 , to selected 2.43
Removed unused code fragment
Thu May 27 19:32:12 2010 UTC (14 years ago) by greg
Changes since 2.25: +3 -1 lines
Diff to previous 2.25 , to selected 2.43
Thu May 21 18:08:43 2009 UTC (15 years ago) by greg
Changes since 2.24: +52 -49 lines
Diff to previous 2.24 , to selected 2.43
Thu Mar 12 18:37:24 2009 UTC (15 years, 2 months ago) by greg
Diff to previous 2.23 , to selected 2.43
Increased MAXLINE value to avoid hiccups in headers
Tue Feb 1 01:28:16 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.22: +1 -2 lines
Diff to previous 2.22 , to selected 2.43
Eliminated redundant include files.
Fri Jan 2 11:35:17 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.21: +81 -62 lines
Diff to previous 2.21 , to selected 2.43
Wed Jul 30 10:11:06 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.20 , to selected 2.43
Diff to previous 2.19 , to selected 2.43
Mon Jul 21 22:30:17 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.18 , to selected 2.43
Sat Jul 12 15:14:44 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.17: +3 -6 lines
Diff to previous 2.17 , to selected 2.43
Included rtio.h to cover fputword() declaration
Changes since 2.16: +3 -2 lines
Diff to previous 2.16 , to selected 2.43
Changes since 2.15: +5 -2 lines
Diff to previous 2.15 , to selected 2.43
Changes since 2.14: +1 -3 lines
Diff to previous 2.14 , to selected 2.43
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Diff to previous 2.13 , to selected 2.43
Mon Mar 10 17:13:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.12: +1 -7 lines
Diff to previous 2.12 , to selected 2.43
Changes since 2.11: +1 -56 lines
Diff to previous 2.11 , to selected 2.43
Changes since 2.10: +155 -21 lines
Diff to previous 2.10 , to selected 2.43
Tue Oct 27 08:44:28 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 2.9 , to selected 2.43
Fri Oct 31 11:40:52 1997 UTC (26 years, 7 months ago) by gregl
Diff to previous 2.8 , to selected 2.43
took out space at the end of header id's
Sat Jul 27 07:21:38 1996 UTC (27 years, 10 months ago) by greg
Diff to previous 2.7 , to selected 2.43
eliminated final space from printargs() output
Tue Mar 12 11:29:16 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.6: +11 -6 lines
Diff to previous 2.6 , to selected 2.43
fixed bug on machines that put static strings in read-only memory
Mon Oct 16 10:53:46 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.5: +11 -18 lines
Diff to previous 2.5 , to selected 2.43
changed copymatch() to globmatch(), which is more generally useful
Sun Oct 15 14:07:58 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.4: +11 -6 lines
Diff to previous 2.4 , to selected 2.43
made changes for new 32-bit_rle_xyze picture type
Sun Feb 27 10:16:45 1994 UTC (30 years, 3 months ago) by greg
Changes since 2.3: +52 -16 lines
Diff to previous 2.3 , to selected 2.43
Thu Nov 12 16:20:09 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.2: +9 -5 lines
Diff to previous 2.2 , to selected 2.43
Changes for 32-bit PC port
Thu Feb 20 11:40:36 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.1: +19 -2 lines
Diff to previous 2.1 , to selected 2.43
added quoting of arguments containing spaces to printargs()
Tue Nov 12 16:54:24 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 2.43
Mon Apr 22 08:23:10 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.3: +3 -5 lines
Diff to previous 1.3 , to selected 2.43
minor change to checkheader.c
Fri Apr 19 10:33:25 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.2: +81 -6 lines
Diff to previous 1.2 , to selected 2.43
added wildcard matching for formats
Thu Apr 18 12:56:58 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.1: +59 -10 lines
Diff to previous 1.1 , to selected 2.43
added format info to headers
Thu Feb 2 10:34:33 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.43
