1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: getpath.c,v 2.17 2004/02/12 18:55:50 greg Exp $"; |
3 |
#endif |
4 |
5 |
* getpath.c - function to search for file in a list of directories |
6 |
7 |
* External symbols declared in rtio.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <string.h> |
13 |
#include <ctype.h> |
14 |
15 |
#include "rtio.h" |
16 |
#include "paths.h" |
17 |
18 |
19 |
#ifdef _WIN32 |
20 |
static char * |
21 |
core_getpath /* wrapped below: expand fname, return full path */ |
22 |
#else |
23 |
char * |
24 |
getpath /* expand fname, return full path */ |
25 |
#endif |
26 |
27 |
char *fname, |
28 |
char *searchpath, |
29 |
int mode |
30 |
31 |
32 |
static char pname[PATH_MAX]; |
33 |
char uname[512]; |
34 |
char *cp; |
35 |
int i; |
36 |
37 |
if (fname == NULL) { return(NULL); } |
38 |
39 |
pname[0] = '\0'; /* check for full specification */ |
40 |
41 |
if (ISABS(fname)) { /* absolute path */ |
42 |
strncpy(pname, fname, sizeof(pname)-1); |
43 |
} else { |
44 |
switch (*fname) { |
45 |
case '.': /* relative to cwd */ |
46 |
47 |
break; |
48 |
case '~': /* relative to home directory */ |
49 |
fname++; |
50 |
cp = uname; |
51 |
for (i=0;i<sizeof(uname)&&*fname!='\0'&&!ISDIRSEP(*fname);i++) |
52 |
*cp++ = *fname++; |
53 |
*cp = '\0'; |
54 |
cp = gethomedir(uname, pname, sizeof(pname)); |
55 |
if(cp == NULL) return NULL; |
56 |
strncat(pname, fname, sizeof(pname)-strlen(pname)-1); |
57 |
break; |
58 |
59 |
60 |
if (pname[0]) /* got it, check access if search requested */ |
61 |
return(searchpath==NULL||access(pname,mode)==0 ? pname : NULL); |
62 |
63 |
if (searchpath == NULL) { /* don't search */ |
64 |
65 |
return(pname); |
66 |
67 |
/* check search path */ |
68 |
do { |
69 |
cp = pname; |
70 |
while (*searchpath && (*cp = *searchpath++) != PATHSEP) { |
71 |
cp++; |
72 |
73 |
if (cp > pname && !ISDIRSEP(cp[-1])) { |
74 |
*cp++ = DIRSEP; |
75 |
76 |
strncpy(cp, fname, sizeof(pname)-strlen(pname)-1); |
77 |
if (access(pname, mode) == 0) /* file accessable? */ |
78 |
return(pname); |
79 |
} while (*searchpath); |
80 |
/* not found */ |
81 |
return(NULL); |
82 |
83 |
84 |
85 |
#ifdef _WIN32 |
86 |
/* This is a wrapper around the above, "emulating" access mode X_OK, |
87 |
which is not supported on Windows. |
88 |
If we see X_OK and the filename has no extension, then we'll remove |
89 |
the X_OK from the mode, append ".exe" to the file name, and search |
90 |
with the resulting string. If that fails, we'll try again with ".bat". |
91 |
Theoretically, we might still not have execute rights on a file we find |
92 |
like this, but that's rare enough not to be worth checking the ACLs. |
93 |
94 |
char * |
95 |
getpath( /* expand fname, return full path */ |
96 |
char *ffname, |
97 |
char *searchpath, |
98 |
int mode |
99 |
100 |
101 |
char *cp; |
102 |
char fname[PATH_MAX]; |
103 |
104 |
if (ffname == NULL) |
105 |
return(NULL); |
106 |
107 |
/* if we have a dot in the string, we assume there is a file name |
108 |
extension present */ |
109 |
/* XXX We'd better test for .exe/.bat/.etc explicitly */ |
110 |
if (!(mode & X_OK) || (strrchr(ffname, '.') != NULL)) { |
111 |
return core_getpath(ffname, searchpath, mode); |
112 |
113 |
114 |
/* We're looking for an executable, Windows doesn't have X_OK. */ |
115 |
mode &= ~X_OK; |
116 |
/* Append .exe */ |
117 |
strncpy(fname, ffname, sizeof(fname)-5); |
118 |
strcat(fname, ".exe"); |
119 |
cp = core_getpath(fname, searchpath, mode); |
120 |
if (cp != NULL) return cp; |
121 |
122 |
/* Try with .bat this time... */ |
123 |
124 |
strcat(fname, ".bat"); |
125 |
126 |
return cp; |
127 |
128 |
#endif /* _WIN32 */ |
129 |
130 |
131 |
#ifdef TEST_MODULE |
132 |
int main() |
133 |
134 |
char * fp; |
135 |
char fmt[] = "%15s %-10s %s: %s\n"; |
136 |
137 |
fp = getpath("rayinit.cal", getenv("RAYPATH"), R_OK); |
138 |
printf(fmt, "rayinit.cal", "RAYPATH", "R_OK", fp); |
139 |
fp = getpath("mkillum", getenv("PATH"), X_OK); |
140 |
printf(fmt, "mkillum", "PATH", "X_OK", fp); |
141 |
fp = getpath("/", getenv("PATH"), W_OK); |
142 |
printf(fmt, "/", "PATH", "W_OK", fp); |
143 |
fp = getpath("~", getenv("PATH"), F_OK); |
144 |
printf(fmt, "~", "PATH", "F_OK", fp); |
145 |
printf("Undefining HOME and HOMEPATH\n"); |
146 |
unsetenv("HOME"); |
147 |
unsetenv("HOMEPATH"); |
148 |
149 |
150 |
fp = getpath("~lp/blah", getenv("PATH"), F_OK); |
151 |
printf(fmt, "~lp/blah", "PATH", "F_OK", fp); |
152 |
153 |
#endif |
154 |
