1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: getpath.c,v 2.10 2003/02/25 02:47:21 greg Exp $"; |
3 |
#endif |
4 |
5 |
* getpath.c - function to search for file in a list of directories |
6 |
7 |
* External symbols declared in standard.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <string.h> |
13 |
#include <ctype.h> |
14 |
#ifndef _WIN32 /* XXX was NIX, do we still compile on Amiga? */ |
15 |
#include <pwd.h> |
16 |
#include <sys/types.h> |
17 |
#endif |
18 |
19 |
#include "paths.h" |
20 |
21 |
22 |
23 |
#ifdef _WIN32 |
24 |
static char * |
25 |
core_getpath /* wrapped below: expand fname, return full path */ |
26 |
#else |
27 |
char * |
28 |
getpath /* expand fname, return full path */ |
29 |
#endif |
30 |
31 |
register char *fname, |
32 |
register char *searchpath, |
33 |
int mode |
34 |
35 |
36 |
37 |
struct passwd *pwent; |
38 |
#endif |
39 |
static char pname[PATH_MAX]; |
40 |
register char *cp; |
41 |
42 |
if (fname == NULL) { return(NULL); } |
43 |
44 |
pname[0] = '\0'; /* check for full specification */ |
45 |
46 |
if (ISABS(fname)) { /* Can't use CASEDIRSEP below on Windows */ |
47 |
strncpy(pname, fname, sizeof(pname)-1); |
48 |
} else { |
49 |
switch (*fname) { |
50 |
/* XXX This doesn't work on Windows */ |
51 |
/* CASEDIRSEP: */ /* relative to root */ |
52 |
case '.': /* relative to cwd */ |
53 |
54 |
break; |
55 |
case '~': /* relative to home directory */ |
56 |
fname++; |
57 |
if (*fname == '\0' || ISDIRSEP(*fname)) { /* ours */ |
58 |
if ((cp = getenv("HOME")) == NULL) |
59 |
#ifdef _WIN32 /* Windows sometimes uses a different var name */ |
60 |
if ((cp = getenv("HOMEDIR")) == NULL) |
61 |
#endif |
62 |
return(NULL); |
63 |
strncpy(pname, cp, sizeof(pname)-1); |
64 |
strncat(pname, fname, sizeof(pname)-strlen(pname)-1); |
65 |
break; |
66 |
67 |
68 |
/* XXX Should we request our own home directory from the |
69 |
XXX system as well if the above fails? */ |
70 |
/* XXX In any case, we need do the same thing on Windows... */ |
71 |
cp = pname; /* user */ |
72 |
do |
73 |
*cp++ = *fname++; |
74 |
while (*fname && !ISDIRSEP(*fname)); |
75 |
*cp = '\0'; |
76 |
if ((pwent = getpwnam(pname)) == NULL) |
77 |
return(NULL); |
78 |
strncpy(pname, pwent->pw_dir, sizeof(pname)-1); |
79 |
80 |
break; |
81 |
#endif |
82 |
83 |
84 |
if (pname[0]) /* got it, check access if search requested */ |
85 |
return(searchpath==NULL||access(pname,mode)==0 ? pname : NULL); |
86 |
87 |
if (searchpath == NULL) { /* don't search */ |
88 |
89 |
return(pname); |
90 |
91 |
/* check search path */ |
92 |
do { |
93 |
cp = pname; |
94 |
while (*searchpath && (*cp = *searchpath++) != PATHSEP) { |
95 |
cp++; |
96 |
97 |
if (cp > pname && !ISDIRSEP(cp[-1])) { |
98 |
*cp++ = DIRSEP; |
99 |
100 |
strncpy(cp, fname, sizeof(pname)-strlen(pname)-1); |
101 |
if (access(pname, mode) == 0) /* file accessable? */ |
102 |
return(pname); |
103 |
} while (*searchpath); |
104 |
/* not found */ |
105 |
return(NULL); |
106 |
107 |
108 |
109 |
#ifdef _WIN32 |
110 |
/* This is a wrapper around the above, "emulating" access mode X_OK, |
111 |
which is not supported on Windows. |
112 |
If we see X_OK and the filename has no extension, then we'll remove |
113 |
the X_OK from the mode, append ".exe" to the file name, and search |
114 |
with the resulting string. If that fails, we'll try again with ".bat". |
115 |
Theoretically, we might still not have execute rights on a file we find |
116 |
like this, but that's rare enough not to be worth checking the ACLs. |
117 |
118 |
char * |
119 |
getpath( /* expand fname, return full path */ |
120 |
register char *ffname, |
121 |
122 |
int mode |
123 |
124 |
125 |
126 |
char fname[PATH_MAX]; |
127 |
128 |
if (ffname == NULL) |
129 |
return(NULL); |
130 |
131 |
/* if we have a dot in the string, we assume there is a file name |
132 |
extension present */ |
133 |
/* XXX We'd better test for .exe/.bat/.etc explicitly */ |
134 |
if (!(mode & X_OK) || (strrchr(ffname, '.') != NULL)) { |
135 |
return core_getpath(ffname, searchpath, mode); |
136 |
137 |
138 |
/* We're looking for an executable, Windows doesn't have X_OK. */ |
139 |
mode &= ~X_OK; |
140 |
/* Append .exe */ |
141 |
strncpy(fname, ffname, sizeof(fname)-5); |
142 |
strcat(fname, ".exe"); |
143 |
cp = core_getpath(fname, searchpath, mode); |
144 |
if (cp != NULL) return cp; |
145 |
146 |
/* Try with .bat this time... */ |
147 |
148 |
strcat(fname, ".bat"); |
149 |
150 |
return cp; |
151 |
152 |
#endif /* _WIN32 */ |
153 |
154 |
155 |
#ifdef TEST_MODULE |
156 |
int main() |
157 |
158 |
char * fp; |
159 |
char fmt[] = "%15s %-10s %s: %s\n"; |
160 |
161 |
fp = getpath("rayinit.cal", getenv("RAYPATH"), R_OK); |
162 |
printf(fmt, "rayinit.cal", "RAYPATH", "R_OK", fp); |
163 |
fp = getpath("mkillum", getenv("PATH"), X_OK); |
164 |
printf(fmt, "mkillum", "PATH", "X_OK", fp); |
165 |
fp = getpath("/", getenv("PATH"), W_OK); |
166 |
printf(fmt, "/", "PATH", "W_OK", fp); |
167 |
fp = getpath("~", getenv("PATH"), F_OK); |
168 |
printf(fmt, "~", "PATH", "F_OK", fp); |
169 |
printf("Undefining HOME and HOMEDIR\n"); |
170 |
unsetenv("HOME"); |
171 |
unsetenv("HOMEDIR"); |
172 |
173 |
174 |
175 |
fp = getpath("~lp", getenv("PATH"), F_OK); |
176 |
printf(fmt, "~lp", "PATH", "F_OK", fp); |
177 |
#endif |
178 |
179 |
#endif |
180 |
