root/Development/ray/src/common/getpath.c
Sat Jun 7 05:09:45 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.23: +2 -3 lines
Diff to previous 2.23 , to selected 2.21
Sun Dec 5 15:44:15 2021 UTC (4 years ago) by greg
Diff to previous 2.22 , to selected 2.21
fix: repaired regression introduced to Windows version
Mon Nov 22 18:23:56 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.21: +10 -9 lines
Diff to previous 2.21
fix: allow getpath() to be passed its own buffer as file name
Revision 2.21 - (view) (download) (annotate) - [selected]
Sat Dec 28 18:05:14 2019 UTC (6 years ago) by greg
Changes since 2.20: +1 -2 lines
Diff to previous 2.20
Sun Jul 21 16:48:34 2019 UTC (6 years, 5 months ago) by greg
Changes since 2.19: +16 -16 lines
Diff to previous 2.19 , to selected 2.21
Replaced strncpy() and strncat() with strlcpy() and strlcat() and other fixes
Sun Mar 6 01:13:17 2016 UTC (9 years, 9 months ago) by schorsch
CVS Tags: rad5R1, rad5R2
Diff to previous 2.18 , to selected 2.21
Thu Dec 19 16:38:12 2013 UTC (12 years ago) by greg
Changes since 2.17: +10 -10 lines
Diff to previous 2.17 , to selected 2.21
Thu Feb 12 18:55:50 2004 UTC (21 years, 10 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.21
Fri Nov 14 17:22:06 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.15: +1 -2 lines
Diff to previous 2.15 , to selected 2.21
Mon Oct 27 10:19:31 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.14: +12 -38 lines
Diff to previous 2.14 , to selected 2.21
Thu Jul 17 09:21:29 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.13 , to selected 2.21
Thu Jul 3 20:59:00 2003 UTC (22 years, 6 months ago) by schorsch
Diff to previous 2.12 , to selected 2.21
Gotta pay more attention when replacing conditionals. Reversing test.
Mon Jun 30 14:59:11 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.11: +5 -5 lines
Diff to previous 2.11 , to selected 2.21
Thu Jun 26 00:58:09 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.10: +140 -45 lines
Diff to previous 2.10 , to selected 2.21
Tue Feb 25 02:47:21 2003 UTC (22 years, 10 months ago) by greg
Diff to previous 2.9 , to selected 2.21
Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.8: +60 -4 lines
Diff to previous 2.8 , to selected 2.21
Thu Aug 26 10:14:32 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.7: +6 -3 lines
Diff to previous 2.7 , to selected 2.21
changed behavior to check access whenever search path is given
Mon Sep 21 11:59:42 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.6: +4 -6 lines
Diff to previous 2.6 , to selected 2.21
Changes for PC port
Tue Sep 8 10:04:34 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.5: +7 -7 lines
Diff to previous 2.5 , to selected 2.21
Tue Sep 8 09:09:24 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.4: +5 -10 lines
Diff to previous 2.4 , to selected 2.21
Mon Jul 13 16:33:19 1992 UTC (33 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 2.21
fixed sloppiness on conditional compiles for UNIX
Tue Jun 16 13:29:35 1992 UTC (33 years, 6 months ago) by greg
Changes since 2.2: +16 -11 lines
Diff to previous 2.2 , to selected 2.21
added macros for directory and path separation characters
Wed Mar 25 10:57:29 1992 UTC (33 years, 9 months ago) by greg
Changes since 2.1: +5 -1 lines
Diff to previous 2.1 , to selected 2.21
added escape character for paths including colon
Tue Nov 12 16:55:56 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1 , to selected 2.21
Fri Jul 19 13:34:29 1991 UTC (34 years, 5 months ago) by greg
Diff to selected 2.21
