--- ray/src/common/getpath.c 2004/02/12 18:55:50 2.17 +++ ray/src/common/getpath.c 2019/12/28 18:05:14 2.21 @@ -1,22 +1,21 @@ #ifndef lint -static const char RCSid[] = "$Id: getpath.c,v 2.17 2004/02/12 18:55:50 greg Exp $"; +static const char RCSid[] = "$Id: getpath.c,v 2.21 2019/12/28 18:05:14 greg Exp $"; #endif /* * getpath.c - function to search for file in a list of directories * - * External symbols declared in standard.h + * External symbols declared in rtio.h */ #include "copyright.h" -#include #include #include "rtio.h" #include "paths.h" -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) static char * core_getpath /* wrapped below: expand fname, return full path */ #else @@ -24,14 +23,14 @@ char * getpath /* expand fname, return full path */ #endif ( -register char *fname, -register char *searchpath, -int mode + char *fname, + char *searchpath, + int mode ) { static char pname[PATH_MAX]; char uname[512]; - register char *cp; + char *cp; int i; if (fname == NULL) { return(NULL); } @@ -39,41 +38,41 @@ int mode pname[0] = '\0'; /* check for full specification */ if (ISABS(fname)) { /* absolute path */ - strncpy(pname, fname, sizeof(pname)-1); + strlcpy(pname, fname, sizeof(pname)); } else { switch (*fname) { - case '.': /* relative to cwd */ - strncpy(pname, fname, sizeof(pname)-1); + case '.': /* relative to cwd */ + strlcpy(pname, fname, sizeof(pname)); break; - case '~': /* relative to home directory */ + case '~': /* relative to home directory */ fname++; cp = uname; - for (i=0;i pname && !ISDIRSEP(cp[-1])) { + while (*searchpath && (*cp = *searchpath++) != PATHSEP) + cp += (cp-pname < sizeof(pname)-2); + if (cp > pname && !ISDIRSEP(cp[-1])) *cp++ = DIRSEP; - } - strncpy(cp, fname, sizeof(pname)-strlen(pname)-1); + *cp = '\0'; + strlcat(pname, fname, sizeof(pname)); if (access(pname, mode) == 0) /* file accessable? */ return(pname); } while (*searchpath); @@ -82,7 +81,7 @@ int mode } -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) /* This is a wrapper around the above, "emulating" access mode X_OK, which is not supported on Windows. If we see X_OK and the filename has no extension, then we'll remove @@ -93,12 +92,12 @@ int mode */ char * getpath( /* expand fname, return full path */ -register char *ffname, -register char *searchpath, -int mode + char *ffname, + char *searchpath, + int mode ) { - register char *cp; + char *cp; char fname[PATH_MAX]; if (ffname == NULL)
