root/radiance/ray/src/common/getpath.c
Thu Feb 12 18:55:50 2004 UTC (20 years, 3 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.15
Changes since 2.15: +1 -2 lines
Diff to previous 2.15
Revision 2.15 - (view) (download) (annotate) - [selected]
Mon Oct 27 10:19:31 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.14: +12 -38 lines
Diff to previous 2.14
Diff to previous 2.13 , to selected 2.15
Thu Jul 3 20:59:00 2003 UTC (20 years, 11 months ago) by schorsch
Diff to previous 2.12 , to selected 2.15
Gotta pay more attention when replacing conditionals. Reversing test.
Changes since 2.11: +5 -5 lines
Diff to previous 2.11 , to selected 2.15
Changes since 2.10: +140 -45 lines
Diff to previous 2.10 , to selected 2.15
Diff to previous 2.9 , to selected 2.15
Changes since 2.8: +60 -4 lines
Diff to previous 2.8 , to selected 2.15
Thu Aug 26 10:14:32 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.7: +6 -3 lines
Diff to previous 2.7 , to selected 2.15
changed behavior to check access whenever search path is given
Mon Sep 21 11:59:42 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.6: +4 -6 lines
Diff to previous 2.6 , to selected 2.15
Changes for PC port
Tue Sep 8 10:04:34 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.5: +7 -7 lines
Diff to previous 2.5 , to selected 2.15
Tue Sep 8 09:09:24 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.4: +5 -10 lines
Diff to previous 2.4 , to selected 2.15
Mon Jul 13 16:33:19 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.3 , to selected 2.15
fixed sloppiness on conditional compiles for UNIX
Tue Jun 16 13:29:35 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.2: +16 -11 lines
Diff to previous 2.2 , to selected 2.15
added macros for directory and path separation characters
Wed Mar 25 10:57:29 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.1: +5 -1 lines
Diff to previous 2.1 , to selected 2.15
added escape character for paths including colon
Tue Nov 12 16:55:56 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1 , to selected 2.15
Fri Jul 19 13:34:29 1991 UTC (32 years, 10 months ago) by greg
Diff to selected 2.15
