Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Gotta pay more attention when replacing conditionals. Reversing test.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed behavior to check access whenever search path is given
Changes for PC port
fixed sloppiness on conditional compiles for UNIX
added macros for directory and path separation characters
added escape character for paths including colon
