| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: getpath.c,v 2.16 2003/11/14 17:22:06 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* getpath.c - function to search for file in a list of directories
| 6 |
| 7 |
* External symbols declared in standard.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <string.h>
| 13 |
#include <ctype.h>
| 14 |
| 15 |
#include "rtio.h"
| 16 |
#include "paths.h"
| 17 |
| 18 |
| 19 |
#ifdef _WIN32
| 20 |
static char *
| 21 |
core_getpath /* wrapped below: expand fname, return full path */
| 22 |
#else
| 23 |
char *
| 24 |
getpath /* expand fname, return full path */
| 25 |
#endif
| 26 |
| 27 |
register char *fname,
| 28 |
register char *searchpath,
| 29 |
int mode
| 30 |
| 31 |
| 32 |
static char pname[PATH_MAX];
| 33 |
char uname[512];
| 34 |
register char *cp;
| 35 |
int i;
| 36 |
| 37 |
if (fname == NULL) { return(NULL); }
| 38 |
| 39 |
pname[0] = '\0'; /* check for full specification */
| 40 |
| 41 |
if (ISABS(fname)) { /* absolute path */
| 42 |
strncpy(pname, fname, sizeof(pname)-1);
| 43 |
} else {
| 44 |
switch (*fname) {
| 45 |
case '.': /* relative to cwd */
| 46 |
| 47 |
break;
| 48 |
case '~': /* relative to home directory */
| 49 |
fname++;
| 50 |
cp = uname;
| 51 |
for (i=0;i<sizeof(uname)&&*fname!='\0'&&!ISDIRSEP(*fname);i++)
| 52 |
*cp++ = *fname++;
| 53 |
*cp = '\0';
| 54 |
cp = gethomedir(uname, pname, sizeof(pname));
| 55 |
if(cp == NULL) return NULL;
| 56 |
strncat(pname, fname, sizeof(pname)-strlen(pname)-1);
| 57 |
break;
| 58 |
| 59 |
| 60 |
if (pname[0]) /* got it, check access if search requested */
| 61 |
return(searchpath==NULL||access(pname,mode)==0 ? pname : NULL);
| 62 |
| 63 |
if (searchpath == NULL) { /* don't search */
| 64 |
| 65 |
return(pname);
| 66 |
| 67 |
/* check search path */
| 68 |
do {
| 69 |
cp = pname;
| 70 |
while (*searchpath && (*cp = *searchpath++) != PATHSEP) {
| 71 |
cp++;
| 72 |
| 73 |
if (cp > pname && !ISDIRSEP(cp[-1])) {
| 74 |
*cp++ = DIRSEP;
| 75 |
| 76 |
strncpy(cp, fname, sizeof(pname)-strlen(pname)-1);
| 77 |
if (access(pname, mode) == 0) /* file accessable? */
| 78 |
return(pname);
| 79 |
} while (*searchpath);
| 80 |
/* not found */
| 81 |
return(NULL);
| 82 |
| 83 |
| 84 |
| 85 |
#ifdef _WIN32
| 86 |
/* This is a wrapper around the above, "emulating" access mode X_OK,
| 87 |
which is not supported on Windows.
| 88 |
If we see X_OK and the filename has no extension, then we'll remove
| 89 |
the X_OK from the mode, append ".exe" to the file name, and search
| 90 |
with the resulting string. If that fails, we'll try again with ".bat".
| 91 |
Theoretically, we might still not have execute rights on a file we find
| 92 |
like this, but that's rare enough not to be worth checking the ACLs.
| 93 |
| 94 |
char *
| 95 |
getpath( /* expand fname, return full path */
| 96 |
register char *ffname,
| 97 |
| 98 |
int mode
| 99 |
| 100 |
| 101 |
register char *cp;
| 102 |
char fname[PATH_MAX];
| 103 |
| 104 |
if (ffname == NULL)
| 105 |
return(NULL);
| 106 |
| 107 |
/* if we have a dot in the string, we assume there is a file name
| 108 |
extension present */
| 109 |
/* XXX We'd better test for .exe/.bat/.etc explicitly */
| 110 |
if (!(mode & X_OK) || (strrchr(ffname, '.') != NULL)) {
| 111 |
return core_getpath(ffname, searchpath, mode);
| 112 |
| 113 |
| 114 |
/* We're looking for an executable, Windows doesn't have X_OK. */
| 115 |
mode &= ~X_OK;
| 116 |
/* Append .exe */
| 117 |
strncpy(fname, ffname, sizeof(fname)-5);
| 118 |
strcat(fname, ".exe");
| 119 |
cp = core_getpath(fname, searchpath, mode);
| 120 |
if (cp != NULL) return cp;
| 121 |
| 122 |
/* Try with .bat this time... */
| 123 |
| 124 |
strcat(fname, ".bat");
| 125 |
| 126 |
return cp;
| 127 |
| 128 |
#endif /* _WIN32 */
| 129 |
| 130 |
| 131 |
#ifdef TEST_MODULE
| 132 |
int main()
| 133 |
| 134 |
char * fp;
| 135 |
char fmt[] = "%15s %-10s %s: %s\n";
| 136 |
| 137 |
fp = getpath("rayinit.cal", getenv("RAYPATH"), R_OK);
| 138 |
printf(fmt, "rayinit.cal", "RAYPATH", "R_OK", fp);
| 139 |
fp = getpath("mkillum", getenv("PATH"), X_OK);
| 140 |
printf(fmt, "mkillum", "PATH", "X_OK", fp);
| 141 |
fp = getpath("/", getenv("PATH"), W_OK);
| 142 |
printf(fmt, "/", "PATH", "W_OK", fp);
| 143 |
fp = getpath("~", getenv("PATH"), F_OK);
| 144 |
printf(fmt, "~", "PATH", "F_OK", fp);
| 145 |
printf("Undefining HOME and HOMEPATH\n");
| 146 |
unsetenv("HOME");
| 147 |
unsetenv("HOMEPATH");
| 148 |
| 149 |
| 150 |
fp = getpath("~lp/blah", getenv("PATH"), F_OK);
| 151 |
printf(fmt, "~lp/blah", "PATH", "F_OK", fp);
| 152 |
| 153 |
#endif
| 154 |
