root/radiance/ray/src/common/gbasic.h
Revision: 2.1
Committed: Wed Aug 12 23:07:59 2015 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, HEAD
Error occurred while calculating annotation data.
1 /*
2 ** Author: Christian Reetz ([email protected])
3 */
4 #ifndef __GBASIC_H
5 #define __GBASIC_H
6
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11
12 #include <math.h>
13
14 #ifndef g3Float
15 #define g3Float double
16 #define USE_DOUBLE 1
17 #define GB_EPSILON 1e-6
18 #else
19 #define GB_EPSILON 1e-4
20 #endif
21
22 typedef unsigned char uchar;
23
24 #define DEG2RAD(x) ((x)*M_PI/180.0)
25 #define RAD2DEG(x) ((x)*180.0/M_PI)
26
27 #define GB_SWAP(a,b) {g3Float temp=(a);(a)=(b);(b)=temp;}
28 #define gb_swap(a,b) GB_SWAP(a,b)
29
30 #define gb_random() (((g3Float) rand())/(RAND_MAX-1))
31
32 int gb_epsorder(g3Float a,g3Float b);
33
34 int gb_epseq(g3Float a,g3Float b);
35
36 int gb_inrange(g3Float a,g3Float rb,g3Float re);
37
38 int gb_signum(g3Float a);
39
40 g3Float gb_max(g3Float a,g3Float b);
41 g3Float gb_min(g3Float a,g3Float b);
42
43 /* Roots of quadratic formula
44 Returns zero if roots are not real, 1 for single root and 2 otherwise
45 */
46 int gb_getroots(g3Float* r1,g3Float* r2,g3Float a,g3Float b,g3Float c);
47
48 #ifdef __cplusplus
49 }
50 #endif
51
52
53 #endif
