root/Development/ray/src/common/g3vector.h
Revision: 2.1
Committed: Wed Aug 12 23:07:59 2015 UTC (10 years, 3 months ago) by greg
1 /*
2 ** Author: Christian Reetz ([email protected])
3 */
4 #ifndef __G3VECTOR_H
5 #define __G3VECTOR_H
6
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11
12 #include <stdio.h>
13
14 #include "gbasic.h"
15 #include "fvect.h"
16
17 typedef g3Float* g3Vec;
18
19 #define g3v_angle(v1,v2) (acos(g3v_dot((v1),(v2))))
20
21
22 g3Vec g3v_create();
23 void g3v_free(g3Vec v);
24 g3Vec g3v_copy(g3Vec dest,g3Vec src);
25 g3Vec g3v_zero(g3Vec v);
26
27 g3Vec g3v_set(g3Vec v,g3Float x,g3Float y,g3Float z);
28 g3Vec g3v_sane(g3Vec v);
29
30 g3Vec g3v_fromrad(g3Vec v,FVECT rv);
31 void g3v_torad(FVECT rv,g3Vec v);
32
33 /*
34 ** Orderering is done component wise, with decreasing significance
35 ** Returns -1, 0 or 1 if v1 is less, equal or greater than v2
36 */
37 int g3v_epsorder(g3Vec v1,g3Vec v2);
38
39 /*
40 ** Returns true if v1 and v2 are epsilon equal
41 */
42 int g3v_epseq(g3Vec v1,g3Vec v2);
43
44 int g3v_epszero(g3Vec v);
45
46 /* Euclidean length of vector */
47 g3Float g3v_length(g3Vec v);
48
49 /*
50 ** Common operations on vectors. All routines returns zero on errors or
51 ** the result as a g3Float
52 */
53 g3Float g3v_dot(g3Vec v1,g3Vec v2);
54 g3Vec g3v_scale(g3Vec res,g3Vec v,g3Float sc);
55 g3Vec g3v_normalize(g3Vec v);
56 g3Vec g3v_cross(g3Vec res,g3Vec v1,g3Vec v2);
57 g3Vec g3v_sub(g3Vec res,g3Vec v1,g3Vec v2);
58 g3Vec g3v_add(g3Vec res,g3Vec v1,g3Vec v2);
59
60 g3Vec g3v_rotate(g3Vec res,g3Vec v,g3Vec rnorm,g3Float ang);
61
62 g3Vec g3v_print(g3Vec v,FILE* fp);
63 int g3v_read(g3Vec v,FILE* fp);
64
65 #ifdef __cplusplus
66 }
67 #endif
68
69 #endif
