1 |
#include <stdlib.h> |
2 |
#include <stdio.h> |
3 |
#include <string.h> |
4 |
5 |
#include "g3vector.h" |
6 |
7 |
8 |
9 |
g3Vec g3v_create() |
10 |
11 |
return ((g3Vec) calloc(3,sizeof(g3Float))); |
12 |
13 |
14 |
void g3v_free(g3Vec v) |
15 |
16 |
if (v) { |
17 |
free(v); |
18 |
v = NULL; |
19 |
20 |
21 |
22 |
g3Vec g3v_copy(g3Vec dest,g3Vec src) |
23 |
24 |
if (dest == src) |
25 |
return dest; |
26 |
memcpy(dest,src,(3*sizeof(g3Float))); |
27 |
return dest; |
28 |
29 |
30 |
g3Vec g3v_zero(g3Vec v) |
31 |
32 |
memset(v,0,3*sizeof(g3Float)); |
33 |
return v; |
34 |
35 |
36 |
g3Vec g3v_set(g3Vec v,g3Float x,g3Float y,g3Float z) |
37 |
38 |
v[0] = x; |
39 |
v[1] = y; |
40 |
v[2] = z; |
41 |
return v; |
42 |
43 |
44 |
g3Vec g3v_sane(g3Vec v) |
45 |
46 |
int i; |
47 |
for(i=0;i<3;i++) |
48 |
if (gb_epseq(v[i],0.0)) |
49 |
v[i] = 0.0; |
50 |
return v; |
51 |
52 |
53 |
g3Vec g3v_fromrad(g3Vec v,FVECT rv) |
54 |
55 |
int i; |
56 |
57 |
for(i=0;i<3;i++) |
58 |
v[i] = rv[i]; |
59 |
return v; |
60 |
61 |
62 |
void g3v_torad(FVECT rv,g3Vec v) |
63 |
64 |
int i; |
65 |
66 |
for(i=0;i<3;i++) |
67 |
rv[i] = v[i]; |
68 |
69 |
70 |
int g3v_epszero(g3Vec v) |
71 |
72 |
int i; |
73 |
74 |
for(i=0;i<3;i++) |
75 |
if (!gb_epseq(v[i],0)) |
76 |
return 0; |
77 |
return 1; |
78 |
79 |
80 |
int g3v_epsorder(g3Vec v1,g3Vec v2) |
81 |
82 |
int i; |
83 |
int res; |
84 |
85 |
for(i=0;i<3;i++) |
86 |
if ((res = gb_epsorder(v1[i],v2[i]))) |
87 |
return res; |
88 |
return 0; |
89 |
90 |
91 |
int g3v_epseq(g3Vec v1,g3Vec v2) |
92 |
93 |
return (g3v_epsorder(v1,v2) == 0); |
94 |
95 |
96 |
g3Float g3v_dot(g3Vec v1,g3Vec v2) |
97 |
98 |
int i; |
99 |
g3Float res = 0.0; |
100 |
101 |
for(i=0;i<3;i++) |
102 |
res += v1[i]*v2[i]; |
103 |
return res; |
104 |
105 |
106 |
107 |
g3Float g3v_length(g3Vec v) |
108 |
109 |
return sqrt(g3v_dot(v,v)); |
110 |
111 |
112 |
g3Vec g3v_normalize(g3Vec v) |
113 |
114 |
int i; |
115 |
g3Float len = g3v_length(v); |
116 |
117 |
if (gb_epseq(len,0)) |
118 |
return NULL; |
119 |
for(i=0;i<3;i++) |
120 |
v[i] /= len; |
121 |
return v; |
122 |
123 |
124 |
g3Vec g3v_cross(g3Vec res,g3Vec v1,g3Vec v2) |
125 |
126 |
g3Vec h = NULL; |
127 |
if ((res == v1) || (res == v2)) |
128 |
h = g3v_create(); |
129 |
else |
130 |
h = res; |
131 |
h[0] = v1[1]*v2[2] - v1[2]*v2[1]; |
132 |
h[1] = v1[2]*v2[0] - v1[0]*v2[2]; |
133 |
h[2] = v1[0]*v2[1] - v1[1]*v2[0]; |
134 |
if (h != res) { |
135 |
g3v_copy(res,h); |
136 |
g3v_free(h); |
137 |
138 |
return res; |
139 |
140 |
141 |
g3Vec g3v_sub(g3Vec res,g3Vec v1,g3Vec v2) |
142 |
143 |
int i; |
144 |
145 |
for(i=0;i<3;i++) |
146 |
res[i] = v1[i] - v2[i]; |
147 |
return res; |
148 |
149 |
150 |
g3Vec g3v_add(g3Vec res,g3Vec v1,g3Vec v2) |
151 |
152 |
int i; |
153 |
154 |
for(i=0;i<3;i++) |
155 |
res[i] = v1[i] + v2[i]; |
156 |
return res; |
157 |
158 |
159 |
g3Vec g3v_scale(g3Vec res,g3Vec v,g3Float sc) |
160 |
161 |
int i; |
162 |
163 |
for(i=0;i<3;i++) |
164 |
res[i] = v[i] * sc; |
165 |
return res; |
166 |
167 |
168 |
g3Vec g3v_rotate(g3Vec res,g3Vec v,g3Vec rnorm,g3Float ang) |
169 |
170 |
g3Vec c1; |
171 |
int copy = 0; |
172 |
173 |
if (res == v) { |
174 |
res = g3v_create(); |
175 |
copy = 1; |
176 |
177 |
ang = -ang; |
178 |
c1 = g3v_create(); |
179 |
g3v_scale(res,v,cos(ang)); |
180 |
g3v_add(res,res,g3v_scale(c1,rnorm,g3v_dot(rnorm,v)*(1 - cos(ang)))); |
181 |
g3v_add(res,res,g3v_scale(c1,g3v_cross(c1,v,rnorm),sin(ang))); |
182 |
g3v_free(c1); |
183 |
if (copy) { |
184 |
g3v_copy(v,res); |
185 |
g3v_free(res); |
186 |
res = v; |
187 |
188 |
return res; |
189 |
190 |
191 |
g3Vec g3v_print(g3Vec v,FILE* fp) |
192 |
193 |
int i; |
194 |
195 |
for(i=0;i<3;i++) |
196 |
fprintf(fp,"%f ",v[i]); |
197 |
return v; |
198 |
199 |
200 |
int g3v_read(g3Vec v,FILE* fp) |
201 |
202 |
char st[100]; |
203 |
204 |
if (!fgets(st,99,fp)) |
205 |
return 0; |
206 |
#if USE_DOUBLE |
207 |
if (sscanf(st,"%lf %lf %lf",&(v[0]),&(v[1]),&(v[2])) != 3) |
208 |
return 0; |
209 |
#else |
210 |
if (sscanf(st,"%f %f %f",&(v[0]),&(v[1]),&(v[2])) != 3) |
211 |
return 0; |
212 |
#endif |
213 |
return 1; |
214 |
215 |
216 |
#ifdef VEC_TEST |
217 |
218 |
int main(int argc,char** argv) |
219 |
220 |
g3Vec a,b; |
221 |
char st[100]; |
222 |
223 |
a = g3v_create(); |
224 |
b = g3v_create(); |
225 |
g3v_set(b,atof(argv[1]),atof(argv[2]),atof(argv[3])); |
226 |
while (fgets(st,99,stdin)) { |
227 |
sscanf(st,"%lf %lf %lf",a,(a+1),(a+2)); |
228 |
g3v_rotate(a,a,b,DEG2RAD(atof(argv[4]))); |
229 |
g3v_print(a,stdout); |
230 |
231 |
return EXIT_SUCCESS; |
232 |
233 |
234 |
#endif |
