root/Development/ray/src/common/g3vector.c
Revision: 2.2
Committed: Tue Aug 18 15:02:53 2015 UTC (10 years, 4 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, HEAD
Changes since 2.1: +3 -0 lines
Added RCCS id's to new source files (forgotten during initial check-in)
# User Rev Content
1 greg 2.2 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4 greg 2.1 #include <stdlib.h>
5     #include <stdio.h>
6     #include <string.h>
7
8     #include "g3vector.h"
9
10
11
12     g3Vec g3v_create()
13     {
14     return ((g3Vec) calloc(3,sizeof(g3Float)));
15     }
16
17     void g3v_free(g3Vec v)
18     {
19     if (v) {
20     free(v);
21     v = NULL;
22     }
23     }
24
25     g3Vec g3v_copy(g3Vec dest,g3Vec src)
26     {
27     if (dest == src)
28     return dest;
29     memcpy(dest,src,(3*sizeof(g3Float)));
30     return dest;
31     }
32
33     g3Vec g3v_zero(g3Vec v)
34     {
35     memset(v,0,3*sizeof(g3Float));
36     return v;
37     }
38
39     g3Vec g3v_set(g3Vec v,g3Float x,g3Float y,g3Float z)
40     {
41     v[0] = x;
42     v[1] = y;
43     v[2] = z;
44     return v;
45     }
46
47     g3Vec g3v_sane(g3Vec v)
48     {
49     int i;
50     for(i=0;i<3;i++)
51     if (gb_epseq(v[i],0.0))
52     v[i] = 0.0;
53     return v;
54     }
55
56     g3Vec g3v_fromrad(g3Vec v,FVECT rv)
57     {
58     int i;
59
60     for(i=0;i<3;i++)
61     v[i] = rv[i];
62     return v;
63     }
64
65     void g3v_torad(FVECT rv,g3Vec v)
66     {
67     int i;
68
69     for(i=0;i<3;i++)
70     rv[i] = v[i];
71     }
72
73     int g3v_epszero(g3Vec v)
74     {
75     int i;
76
77     for(i=0;i<3;i++)
78     if (!gb_epseq(v[i],0))
79     return 0;
80     return 1;
81     }
82
83     int g3v_epsorder(g3Vec v1,g3Vec v2)
84     {
85     int i;
86     int res;
87
88     for(i=0;i<3;i++)
89     if ((res = gb_epsorder(v1[i],v2[i])))
90     return res;
91     return 0;
92     }
93
94     int g3v_epseq(g3Vec v1,g3Vec v2)
95     {
96     return (g3v_epsorder(v1,v2) == 0);
97     }
98
99     g3Float g3v_dot(g3Vec v1,g3Vec v2)
100     {
101     int i;
102     g3Float res = 0.0;
103
104     for(i=0;i<3;i++)
105     res += v1[i]*v2[i];
106     return res;
107     }
108
109
110     g3Float g3v_length(g3Vec v)
111     {
112     return sqrt(g3v_dot(v,v));
113     }
114
115     g3Vec g3v_normalize(g3Vec v)
116     {
117     int i;
118     g3Float len = g3v_length(v);
119
120     if (gb_epseq(len,0))
121     return NULL;
122     for(i=0;i<3;i++)
123     v[i] /= len;
124     return v;
125     }
126
127     g3Vec g3v_cross(g3Vec res,g3Vec v1,g3Vec v2)
128     {
129     g3Vec h = NULL;
130     if ((res == v1) || (res == v2))
131     h = g3v_create();
132     else
133     h = res;
134     h[0] = v1[1]*v2[2] - v1[2]*v2[1];
135     h[1] = v1[2]*v2[0] - v1[0]*v2[2];
136     h[2] = v1[0]*v2[1] - v1[1]*v2[0];
137     if (h != res) {
138     g3v_copy(res,h);
139     g3v_free(h);
140     }
141     return res;
142     }
143
144     g3Vec g3v_sub(g3Vec res,g3Vec v1,g3Vec v2)
145     {
146     int i;
147
148     for(i=0;i<3;i++)
149     res[i] = v1[i] - v2[i];
150     return res;
151     }
152
153     g3Vec g3v_add(g3Vec res,g3Vec v1,g3Vec v2)
154     {
155     int i;
156
157     for(i=0;i<3;i++)
158     res[i] = v1[i] + v2[i];
159     return res;
160     }
161
162     g3Vec g3v_scale(g3Vec res,g3Vec v,g3Float sc)
163     {
164     int i;
165
166     for(i=0;i<3;i++)
167     res[i] = v[i] * sc;
168     return res;
169     }
170
171     g3Vec g3v_rotate(g3Vec res,g3Vec v,g3Vec rnorm,g3Float ang)
172     {
173     g3Vec c1;
174     int copy = 0;
175
176     if (res == v) {
177     res = g3v_create();
178     copy = 1;
179     }
180     ang = -ang;
181     c1 = g3v_create();
182     g3v_scale(res,v,cos(ang));
183     g3v_add(res,res,g3v_scale(c1,rnorm,g3v_dot(rnorm,v)*(1 - cos(ang))));
184     g3v_add(res,res,g3v_scale(c1,g3v_cross(c1,v,rnorm),sin(ang)));
185     g3v_free(c1);
186     if (copy) {
187     g3v_copy(v,res);
188     g3v_free(res);
189     res = v;
190     }
191     return res;
192     }
193
194     g3Vec g3v_print(g3Vec v,FILE* fp)
195     {
196     int i;
197
198     for(i=0;i<3;i++)
199     fprintf(fp,"%f ",v[i]);
200     return v;
201     }
202
203     int g3v_read(g3Vec v,FILE* fp)
204     {
205     char st[100];
206
207     if (!fgets(st,99,fp))
208     return 0;
209     #if USE_DOUBLE
210     if (sscanf(st,"%lf %lf %lf",&(v[0]),&(v[1]),&(v[2])) != 3)
211     return 0;
212     #else
213     if (sscanf(st,"%f %f %f",&(v[0]),&(v[1]),&(v[2])) != 3)
214     return 0;
215     #endif
216     return 1;
217     }
218
219     #ifdef VEC_TEST
220
221     int main(int argc,char** argv)
222     {
223     g3Vec a,b;
224     char st[100];
225
226     a = g3v_create();
227     b = g3v_create();
228     g3v_set(b,atof(argv[1]),atof(argv[2]),atof(argv[3]));
229     while (fgets(st,99,stdin)) {
230     sscanf(st,"%lf %lf %lf",a,(a+1),(a+2));
231     g3v_rotate(a,a,b,DEG2RAD(atof(argv[4])));
232     g3v_print(a,stdout);
233     }
234     return EXIT_SUCCESS;
235     }
236
237     #endif
