root/radiance/ray/src/common/g3nlist.h
Revision: 2.2
Committed: Tue Aug 18 15:02:53 2015 UTC (9 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad6R0, HEAD
Added RCCS id's to new source files (forgotten during initial check-in)
# User Rev Content
1 greg 2.2 /* RCSid $Id$ */
2 greg 2.1 #ifndef __G3NAMEDLIST_H
3     #define __G3NAMEDLIST_H
4
5     #ifdef __cplusplus
6     extern "C" {
7     #endif
8
9     #include <string.h>
10     #include "gbasic.h"
11     #include "g3list.h"
12
13     #define G3NL_NAME_LEN 200
14     #define G3NL_STARTCAP 2
15
16
17
18     typedef char g3nl_names[G3NL_NAME_LEN];
19
20     typedef struct g3nList {
21     create_f ocreate;
22     free_f ofree;
23     copy_f ocopy;
24     int cap;
25     int size;
26     unsigned char** items;
27     g3nl_names* names;
28     } g3nList;
29
30
31
32     g3nList* g3nl_create(create_f cf,free_f ff,copy_f cpf);
33     //void g3nl_free(g3nList* nl);
34
35     //unsigned char* g3nl_append_new(g3nList* nl,const char* name);
36     int g3nl_append(g3nList* nl,const char* name,unsigned char* el);
37     unsigned char* g3nl_get(g3nList* nl,int id);
38     char* g3nl_get_name(g3nList* nl,int id);
39     unsigned char* g3nl_get_by_name(g3nList* nl,const char* name);
40     //unsigned char* g3nl_get_copy(g3nList* nl,int id);
41     //unsigned char* g3nl_get_copy_by_name(g3nList* nl,const char* name);
42
43     int g3nl_remove(g3nList* nl,int id);
44     int g3nl_remove_by_name(g3nList* nl,const char* name);
45     unsigned char* g3nl_remove_last(g3nList* nl);
46     int g3nl_get_size(g3nList* nl);
47
48
49
50     #define G3N_MKHEADER(pref,type) \
51     g3nList* pref ## _nlist_create(); \
52     void pref ## _nlist_free(g3nList* nl); \
53     void pref ## _nlist_free_content(g3nList* nl); \
54     type* pref ## _nlist_append_new(g3nList* nl,const char* name); \
55     int pref ## _nlist_append(g3nList* nl,const char* name,type* it); \
56     type* pref ## _nlist_get(g3nList* nl,int id); \
57     char* pref ## _nlist_get_name(g3nList* nl,int id); \
58     type* pref ## _nlist_get_by_name(g3nList* nl,const char* name); \
59     type* pref ## _nlist_get_copy(g3nList* nl,int id); \
60     type* pref ## _nlist_get_copy_by_name(g3nList* nl,const char* name); \
61     int pref ## _nlist_remove(g3nList* nl,int id); \
62     int pref ## _nlist_remove_by_name(g3nList* nl,const char* name); \
63     type* pref ## _nlist_remove_last(g3nList* nl); \
64     int pref ## _nlist_get_size(g3nList* nl); \
65     void pref ## _nlist_clear(g3nList* nl);
66
67
68
69     #define G3N_MKLIST(pref,type,crf,ff,cpf) \
70     g3nList* pref ## _nlist_create() { \
71     return g3nl_create((create_f) crf,(free_f) ff,(copy_f) cpf); \
72     }; \
73     void pref ## _nlist_free(g3nList* nl) { \
74     free(nl->items); \
75     free(nl); \
76     nl = NULL; \
77     } \
78     void pref ## _nlist_free_content(g3nList* nl) { \
79     int i; \
80     for(i=0;i<nl->cap;i++)\
81     nl->ofree((unsigned char*) nl->items[i]);\
82     free(nl->items); \
83     free(nl); \
84     nl = NULL; \
85     } \
86     type* pref ## _nlist_append_new(g3nList* nl,const char* name) { \
87     type* res = (type*) nl->ocreate(); \
88     if (!g3nl_append(nl,name,((unsigned char*) res))) \
89     return NULL; \
90     return res; \
91     } \
92     int pref ## _nlist_append(g3nList* nl,const char* name,type* it) { \
93     return g3nl_append(nl,name,((unsigned char*) it)); \
94     } \
95     type* pref ## _nlist_get(g3nList* nl,int id) { \
96     return ((type*) g3nl_get(nl,id)); \
97     } \
98     char* pref ## _nlist_get_name(g3nList* nl,int id) { \
99     return g3nl_get_name(nl,id); \
100     } \
101     type* pref ## _nlist_get_by_name(g3nList* nl,const char* name) { \
102     return ((type*) g3nl_get_by_name(nl,name)); \
103     } \
104     type* pref ## _nlist_get_copy(g3nList* nl,int id) { \
105     unsigned char* it; \
106     unsigned char* res; \
107     if (!(nl->ocopy)) \
108     return NULL; \
109     res = nl->ocreate(); \
110     if (!(it = (unsigned char*) pref ## _nlist_get(nl,id))) \
111     return NULL; \
112     if (!(nl->ocopy(res,it))) { \
113     fprintf(stderr,"nlist: copying failed for type %s\n","type"); \
114     return NULL; \
115     } \
116     return ((type*) res); \
117     } \
118     type* pref ## _nlist_get_copy_by_name(g3nList* nl,const char* name) { \
119     int i; \
120     unsigned char* it; \
121     unsigned char* res; \
122     if (!(nl->ocopy)) \
123     return NULL; \
124     res = nl->ocreate(); \
125     for(i=0;i<nl->size;i++)\
126     if (strncmp(nl->names[i],name,G3NL_NAME_LEN-1)) \
127     break; \
128     if (i == nl->size) \
129     return NULL; \
130     if (!(it = (unsigned char*) pref ## _nlist_get_copy(nl,i))) \
131     return NULL; \
132     if (!(nl->ocopy(res,it))) { \
133     fprintf(stderr,"nlist: copying failed for type %s\n","type"); \
134     return NULL; \
135     } \
136     return ((type*) res); \
137     } \
138     int pref ## _nlist_remove(g3nList* nl,int id) { \
139     return g3nl_remove(nl,id); \
140     }\
141     int pref ## _nlist_remove_by_name(g3nList* nl,const char* name) {\
142     return g3nl_remove_by_name(nl,name); \
143     } \
144     type* pref ## _nlist_remove_last(g3nList* nl) { \
145     return ((type*) g3nl_remove_last(nl)); \
146     } \
147     int pref ## _nlist_get_size(g3nList* nl) { \
148     return g3nl_get_size(nl); \
149     } \
150     void pref ## _nlist_clear(g3nList* nl) { \
151     nl->size = 0; \
152     }
153
154
155
156     #ifdef __cplusplus
157     }
158     #endif
159     #endif
