root/Development/ray/src/common/g3affine.h
Revision: 2.2
Committed: Tue Aug 18 15:02:53 2015 UTC (10 years, 2 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, HEAD
Added RCCS id's to new source files (forgotten during initial check-in)
1 /* RCSid $Id$ */
2 /*
3 ** Author: Christian Reetz ([email protected])
4 */
5 #ifndef __G3AFFINE_H
6 #define __G3AFFINE_H
7
8
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 #include "g3vector.h"
15
16 #ifdef GL_CONVERSIONS
17 #include "GL/gl.h"
18 #endif
19
20
21 typedef g3Float g3AVec[4];
22 typedef g3Float g3ATrans[4][4];
23
24
25 void g3av_copy(g3AVec res,g3AVec v);
26 void g3at_tounit(g3ATrans t);
27 void g3av_vectohom(g3AVec res,g3Vec v);
28 void g3av_homtovec(g3Vec res,g3AVec h);
29 int g3av_tonorm(g3AVec v);
30
31 #ifdef GL_CONVERSIONS
32 void g3at_get_openGL(g3ATrans t,GLdouble* glm);
33 void g3at_from_openGL(g3ATrans t,GLdouble* glm);
34 #endif
35
36
37 void g3at_copy(g3ATrans t,g3ATrans tsrc);
38 void g3at_print(g3ATrans t,FILE* outf);
39 void g3at_comb(g3ATrans t,g3ATrans tf);
40 void g3at_comb_to(g3ATrans res,g3ATrans t,g3ATrans tf);
41 void g3at_translate(g3ATrans t,g3Vec tv);
42 void g3at_add_trans(g3ATrans t,g3Vec tv);
43 void g3at_prepend_trans(g3ATrans t,g3Vec tv);
44 void g3at_rotate(g3ATrans t,g3Vec rnorm,g3Float ang);
45 void g3at_add_rot(g3ATrans t,g3Vec rnorm,g3Float ang);
46 void g3at_prepend_rot(g3ATrans t,g3Vec rnorm,g3Float ang);
47
48 void g3at_btrans(g3ATrans t,g3Vec xv,g3Vec yv,g3Vec zv);
49 int g3at_sph_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup);
50 int g3at_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup);
51 int g3at_inverse(g3ATrans t);
52 void g3at_apply_h(g3ATrans t,g3AVec v);
53 void g3at_iapply_h(g3Vec v,g3ATrans t);
54 void g3at_apply(g3ATrans t,g3Vec v);
55 void g3at_iapply(g3Vec v,g3ATrans t);
56
57 #ifdef __cplusplus
58 }
59 #endif
60
61
62 #endif
