root/radiance/ray/src/common/g3affine.c
Revision: 2.2
Committed: Tue Aug 18 15:02:53 2015 UTC (9 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, HEAD
Changes since 2.1: +3 -0 lines
Added RCCS id's to new source files (forgotten during initial check-in)
# User Rev Content
1 greg 2.2 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4 greg 2.1 #include <stdio.h>
5     #include <stdlib.h>
6
7     #include "g3affine.h"
8     #include "gbasic.h"
9     #include "g3sphere.h"
10
11     static g3AVec g3av_zero = {0.0,0.0,0.0,0.0};
12
13     static g3ATrans g3at_unit = {{1.0,0.0,0.0,0.0},
14     {0.0,1.0,0.0,0.0},
15     {0.0,0.0,1.0,0.0},
16     {0.0,0.0,0.0,1.0}};
17
18     static g3ATrans g3at_zero = {{0.0,0.0,0.0,0.0},
19     {0.0,0.0,0.0,0.0},
20     {0.0,0.0,0.0,0.0},
21     {0.0,0.0,0.0,0.0}};
22
23     void g3at_tounit(g3ATrans t)
24     {
25     g3at_copy(t,g3at_unit);
26     }
27
28     static int nr_gaussj(g3Float a[4][4],g3Float b[4])
29     {
30     int *indxc,*indxr,*ipiv;
31     int i,icol,irow,j,k,l,ll;
32     g3Float big,dum,pivinv;
33
34     indxc = (int*) calloc(4,sizeof(int));
35     indxr = (int*) calloc(4,sizeof(int));
36     ipiv = (int*) calloc(4,sizeof(int));
37
38     icol = irow = 0;
39     for (j=0;j<4;j++)
40     ipiv[j]=0;
41     for (i=0;i<4;i++) {
42     big=0.0;
43     for (j=0;j<4;j++)
44     if (ipiv[j] != 1)
45     for (k=0;k<4;k++) {
46     if (ipiv[k] == 0) {
47     if (fabs(a[j][k]) >= big) {
48     big = fabs(a[j][k]);
49     irow = j;
50     icol = k;
51     }
52     } else if (ipiv[k] > 1) {
53     return 0;
54     }
55     }
56     ++(ipiv[icol]);
57     if (irow != icol) {
58     for (l=0;l<4;l++)
59     GB_SWAP(a[irow][l],a[icol][l])
60     GB_SWAP(b[irow],b[icol])
61     }
62     indxr[i] = irow;
63     indxc[i] = icol;
64     if (a[icol][icol] == 0.0)
65     return 0;
66     pivinv = 1.0/a[icol][icol];
67     a[icol][icol] = 1.0;
68     for (l=0;l<4;l++)
69     a[icol][l] *= pivinv;
70     b[icol] *= pivinv;
71     for (ll=0;ll<4;ll++) {
72     if (ll != icol) {
73     dum = a[ll][icol];
74     a[ll][icol] = 0.0;
75     for (l=0;l<4;l++)
76     a[ll][l] -= a[icol][l]*dum;
77     b[ll] -= b[icol]*dum;
78     }
79     }
80     }
81     for (l=3;l>=0;l--) {
82     if (indxr[l] != indxc[l])
83     for (k=0;k<4;k++)
84     GB_SWAP(a[k][indxr[l]],a[k][indxc[l]]);
85     }
86     free(ipiv);
87     free(indxr);
88     free(indxc);
89     return 1;
90     }
91
92     void g3at_translate(g3ATrans t,g3Vec tv)
93     {
94     int i;
95     g3at_copy(t,g3at_unit);
96     for(i=0;i<3;i++)
97     t[i][3] += tv[i];
98     }
99
100     void g3at_add_trans(g3ATrans t,g3Vec tv)
101     {
102     g3ATrans tt;
103
104     g3at_translate(tt,tv);
105     g3at_comb_to(t,tt,t);
106     }
107
108     void g3at_prepend_trans(g3ATrans t,g3Vec tv)
109     {
110     g3ATrans tt;
111
112     g3at_translate(tt,tv);
113     g3at_comb(t,tt);
114     }
115
116     void g3at_rotate(g3ATrans t,g3Vec rnorm,g3Float ang)
117     {
118     g3Vec axe;
119     int aid,i;
120
121     axe = g3v_create();
122     g3at_copy(t,g3at_unit);
123
124     for(aid=0;aid<3;aid++) {
125     g3v_zero(axe);
126     axe[aid] = 1.0;
127     g3v_rotate(axe,axe,rnorm,ang);
128     for(i=0;i<3;i++)
129     t[i][aid] = axe[i];
130     }
131     g3v_free(axe);
132     }
133
134     void g3at_add_rot(g3ATrans t,g3Vec rnorm,g3Float ang)
135     {
136     g3ATrans rt;
137
138     g3at_rotate(rt,rnorm,ang);
139     g3at_comb_to(t,rt,t);
140     }
141
142     void g3at_prepend_rot(g3ATrans t,g3Vec rnorm,g3Float ang)
143     {
144     g3ATrans rt;
145
146     g3at_rotate(rt,rnorm,ang);
147     g3at_comb(t,rt);
148     }
149
150     void g3at_btrans(g3ATrans t,g3Vec xv,g3Vec yv,g3Vec zv)
151     {
152     int i;
153
154     g3at_copy(t,g3at_unit);
155     for(i=0;i<3;i++) {
156     t[i][0] = xv[i];
157     t[i][1] = yv[i];
158     t[i][2] = zv[i];
159     }
160     }
161
162     int g3at_inverse(g3ATrans t)
163     {
164     g3Float v[] = {0,0,0,0};
165
166     if (!nr_gaussj(t,v)) {
167     fprintf(stderr,"g3at_inverse: singular matrix\n");
168     return 0;
169     }
170     return 1;
171     }
172
173     void g3at_apply_h(g3ATrans t,g3AVec v)
174     {
175     int i,j;
176     g3AVec vt;
177
178     g3av_copy(vt,v);
179     g3av_copy(v,g3av_zero);
180     for(i=0;i<4;i++)
181     for(j=0;j<4;j++)
182     v[i] += t[i][j]*vt[j];
183     g3av_tonorm(v);
184     }
185
186     void g3av_print(g3AVec vh,FILE* outf)
187     {
188     int i;
189
190     for(i=0;i<4;i++)
191     fprintf(outf,"%f ",vh[i]);
192     }
193
194     void g3at_apply(g3ATrans t,g3Vec v)
195     {
196     g3AVec res;
197
198     g3av_vectohom(res,v);
199     g3at_apply_h(t,res);
200     g3v_set(v,res[0],res[1],res[2]);
201     }
202
203     void g3at_iapply(g3Vec v,g3ATrans t)
204     {
205     g3AVec res;
206
207     g3av_copy(res,v);
208     g3at_iapply_h(res,t);
209     g3v_set(v,res[0],res[1],res[2]);
210     }
211
212     void g3at_iapply_h(g3Vec v,g3ATrans t)
213     {
214     int i,j;
215     g3AVec vt;
216
217     g3av_copy(vt,v);
218     g3av_copy(v,g3av_zero);
219     for(i=0;i<4;i++)
220     for(j=0;j<4;j++)
221     v[i] += t[j][i]*vt[j];
222     g3av_tonorm(v);
223     }
224
225     void g3at_comb(g3ATrans t,g3ATrans tf)
226     {
227     g3ATrans res;
228
229     g3at_comb_to(res,t,tf);
230     g3at_copy(t,res);
231     }
232
233     void g3at_comb_to(g3ATrans res,g3ATrans t,g3ATrans tf)
234     {
235     int i,j,k;
236     g3ATrans temp;
237     g3at_copy(temp,g3at_zero);
238     for(i=0;i<4;i++)
239     for(j=0;j<4;j++)
240     for(k=0;k<4;k++)
241     temp[i][j] += t[i][k]*tf[k][j];
242     g3at_copy(res,temp);
243     }
244
245
246     void g3av_vectohom(g3AVec res,g3Vec v)
247     {
248     int i;
249
250     for(i=0;i<3;i++)
251     res[i] = v[i];
252     res[3] = 1.0;
253     }
254
255     void g3av_homtovec(g3Vec res,g3AVec h)
256     {
257     int i;
258
259     g3av_tonorm(h);
260     for(i=0;i<3;i++)
261     res[i] = h[i];
262     }
263
264     int g3av_tonorm(g3AVec v)
265     {
266     int i;
267
268     if (gb_epseq(v[3],0.0))
269     return 0;
270     for(i=0;i<3;i++)
271     v[i] /= v[3];
272     v[3] = 1.0;
273     return 1;
274     }
275
276     void g3av_copy(g3AVec v,g3AVec vsrc)
277     {
278     int i;
279
280     for(i=0;i<4;i++)
281     v[i] = vsrc[i];
282     }
283
284     void g3at_print(g3ATrans t,FILE* outf)
285     {
286     int i,j;
287
288     for(i=0;i<4;i++) {
289     for(j=0;j<4;j++)
290     fprintf(outf,"%f ",t[i][j]);
291     fprintf(outf,"\n");
292     }
293     }
294
295     void g3at_copy(g3ATrans t,g3ATrans tsrc)
296     {
297     int i,j;
298
299     for(i=0;i<4;i++)
300     for(j=0;j<4;j++)
301     t[i][j] = tsrc[i][j];
302     }
303
304     int g3at_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup)
305     {
306     g3Vec x,y,z;
307
308     x = g3v_create();
309     y = g3v_create();
310     z = g3v_create();
311     g3v_copy(z,vdir);
312     g3v_copy(x,vup);
313     g3v_normalize(z);
314     g3v_normalize(x);
315     g3v_cross(y,z,x);
316     if (!g3v_normalize(y)) {
317     fprintf(stderr,"g3at_sph_ctrans: parallel\n");
318     g3v_free(x);
319     g3v_free(y);
320     g3v_free(z);
321     return 0;
322     }
323     g3v_cross(x,y,z);
324     if (!g3v_normalize(x)) {
325     fprintf(stderr,"g3at_sph_ctrans: parallel\n");
326     g3v_free(x);
327     g3v_free(y);
328     g3v_free(z);
329     return 0;
330     }
331     g3at_btrans(t,x,y,z);
332     g3v_free(x);
333     g3v_free(y);
334     g3v_free(z);
335     return 1;
336     }
337
338     int g3at_sph_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup)
339     {
340     g3Vec x,z;
341     int res;
342
343     x = g3v_create();
344     z = g3v_create();
345     g3v_copy(z,vdir);
346     g3v_copy(x,vup);
347     z[G3S_RAD] = x[G3S_RAD] = 1.0;
348     g3s_sphtocc(x,x);
349     g3s_sphtocc(z,z);
350     res = g3at_ctrans(t,z,x);
351     g3v_free(x);
352     g3v_free(z);
353
354     return res;
355     }
356
357     #ifdef GL_CONVERSIONS
358     void g3at_get_openGL(g3ATrans t,GLdouble* glm)
359     {
360     int r,c;
361
362     for(r=0;r<4;r++)
363     for(c=0;c<4;c++)
364     glm[c+(r*4)] = t[c][r];
365     }
366
367     void g3at_from_openGL(g3ATrans t,GLdouble* glm)
368     {
369     int r,c;
370
371     for(r=0;r<4;r++)
372     for(c=0;c<4;c++)
373     t[c][r] = glm[c+(r*4)];
374     }
375     #endif
376
377     #ifdef G3AFFINETEST
378
379
380     int main(int argc,char** argv)
381     {
382     g3Vec v,iv,x,y,z;
383     g3ATrans t,it;
384
385     g3at_copy(t,g3at_unit);
386     v = g3v_create();
387     iv = g3v_create();
388     x = g3v_create();
389     y = g3v_create();
390     z = g3v_create();
391     g3v_set(z,1,0,0);
392     g3v_set(x,atof(argv[1]),atof(argv[2]),atof(argv[3]));
393     //g3v_set(y,atof(argv[4]),atof(argv[5]),atof(argv[6]));
394     //g3v_set(z,atof(argv[7]),atof(argv[8]),atof(argv[9]));
395     g3at_tounit(t);
396     g3at_rotate(t,z,DEG2RAD(-90));
397     g3v_set(z,0,0,1);
398     g3at_rotate(it,z,DEG2RAD(180));
399     g3at_comb_to(t,it,t);
400     g3at_apply(t,x);
401     g3v_print(x,stdout);
402     printf("\n");
403     //g3v_print(y,stdout);
404     //printf("\n");
405     exit(19);
406     g3v_set(z,1,DEG2RAD(atof(argv[1])),DEG2RAD(atof(argv[2])));
407     g3v_set(x,1,DEG2RAD(atof(argv[3])),DEG2RAD(atof(argv[4])));
408     g3at_sph_ctrans(t,z,x);
409     g3at_copy(it,t);
410     g3at_inverse(it);
411     g3at_print(t,stderr);
412     fprintf(stderr,"\n");
413     g3v_set(v,1,DEG2RAD(atof(argv[5])),DEG2RAD(atof(argv[6])));
414     g3s_sphtocc(v,v);
415     g3v_copy(iv,v);
416     g3at_apply(it,iv);
417     g3at_apply(t,v);
418     g3s_cctosph(v,v);
419     g3s_cctosph(iv,iv);
420     g3s_sphwrap(v);
421     g3s_sphwrap(iv);
422     fprintf(stderr,"tt %f %f\n",RAD2DEG(v[1]),RAD2DEG(v[2]));
423     fprintf(stderr,"ise %f %f\n",RAD2DEG(iv[1]),RAD2DEG(iv[2]));
424     return EXIT_SUCCESS;
425     }
426
427     #endif
