1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
#include <stdio.h> |
5 |
#include <stdlib.h> |
6 |
7 |
#include "g3affine.h" |
8 |
#include "gbasic.h" |
9 |
#include "g3sphere.h" |
10 |
11 |
static g3AVec g3av_zero = {0.0,0.0,0.0,0.0}; |
12 |
13 |
static g3ATrans g3at_unit = {{1.0,0.0,0.0,0.0}, |
14 |
{0.0,1.0,0.0,0.0}, |
15 |
{0.0,0.0,1.0,0.0}, |
16 |
{0.0,0.0,0.0,1.0}}; |
17 |
18 |
static g3ATrans g3at_zero = {{0.0,0.0,0.0,0.0}, |
19 |
20 |
21 |
{0.0,0.0,0.0,0.0}}; |
22 |
23 |
void g3at_tounit(g3ATrans t) |
24 |
25 |
g3at_copy(t,g3at_unit); |
26 |
27 |
28 |
static int nr_gaussj(g3Float a[4][4],g3Float b[4]) |
29 |
30 |
int *indxc,*indxr,*ipiv; |
31 |
int i,icol,irow,j,k,l,ll; |
32 |
g3Float big,dum,pivinv; |
33 |
34 |
indxc = (int*) calloc(4,sizeof(int)); |
35 |
indxr = (int*) calloc(4,sizeof(int)); |
36 |
ipiv = (int*) calloc(4,sizeof(int)); |
37 |
38 |
icol = irow = 0; |
39 |
for (j=0;j<4;j++) |
40 |
ipiv[j]=0; |
41 |
for (i=0;i<4;i++) { |
42 |
big=0.0; |
43 |
for (j=0;j<4;j++) |
44 |
if (ipiv[j] != 1) |
45 |
for (k=0;k<4;k++) { |
46 |
if (ipiv[k] == 0) { |
47 |
if (fabs(a[j][k]) >= big) { |
48 |
big = fabs(a[j][k]); |
49 |
irow = j; |
50 |
icol = k; |
51 |
52 |
} else if (ipiv[k] > 1) { |
53 |
return 0; |
54 |
55 |
56 |
++(ipiv[icol]); |
57 |
if (irow != icol) { |
58 |
for (l=0;l<4;l++) |
59 |
GB_SWAP(a[irow][l],a[icol][l]) |
60 |
GB_SWAP(b[irow],b[icol]) |
61 |
62 |
indxr[i] = irow; |
63 |
indxc[i] = icol; |
64 |
if (a[icol][icol] == 0.0) |
65 |
return 0; |
66 |
pivinv = 1.0/a[icol][icol]; |
67 |
a[icol][icol] = 1.0; |
68 |
for (l=0;l<4;l++) |
69 |
a[icol][l] *= pivinv; |
70 |
b[icol] *= pivinv; |
71 |
for (ll=0;ll<4;ll++) { |
72 |
if (ll != icol) { |
73 |
dum = a[ll][icol]; |
74 |
a[ll][icol] = 0.0; |
75 |
for (l=0;l<4;l++) |
76 |
a[ll][l] -= a[icol][l]*dum; |
77 |
b[ll] -= b[icol]*dum; |
78 |
79 |
80 |
81 |
for (l=3;l>=0;l--) { |
82 |
if (indxr[l] != indxc[l]) |
83 |
for (k=0;k<4;k++) |
84 |
GB_SWAP(a[k][indxr[l]],a[k][indxc[l]]); |
85 |
86 |
free(ipiv); |
87 |
free(indxr); |
88 |
free(indxc); |
89 |
return 1; |
90 |
91 |
92 |
void g3at_translate(g3ATrans t,g3Vec tv) |
93 |
94 |
int i; |
95 |
96 |
for(i=0;i<3;i++) |
97 |
t[i][3] += tv[i]; |
98 |
99 |
100 |
void g3at_add_trans(g3ATrans t,g3Vec tv) |
101 |
102 |
g3ATrans tt; |
103 |
104 |
g3at_translate(tt,tv); |
105 |
g3at_comb_to(t,tt,t); |
106 |
107 |
108 |
void g3at_prepend_trans(g3ATrans t,g3Vec tv) |
109 |
110 |
g3ATrans tt; |
111 |
112 |
113 |
g3at_comb(t,tt); |
114 |
115 |
116 |
void g3at_rotate(g3ATrans t,g3Vec rnorm,g3Float ang) |
117 |
118 |
g3Vec axe; |
119 |
int aid,i; |
120 |
121 |
axe = g3v_create(); |
122 |
123 |
124 |
for(aid=0;aid<3;aid++) { |
125 |
g3v_zero(axe); |
126 |
axe[aid] = 1.0; |
127 |
g3v_rotate(axe,axe,rnorm,ang); |
128 |
for(i=0;i<3;i++) |
129 |
t[i][aid] = axe[i]; |
130 |
131 |
g3v_free(axe); |
132 |
133 |
134 |
void g3at_add_rot(g3ATrans t,g3Vec rnorm,g3Float ang) |
135 |
136 |
g3ATrans rt; |
137 |
138 |
g3at_rotate(rt,rnorm,ang); |
139 |
g3at_comb_to(t,rt,t); |
140 |
141 |
142 |
void g3at_prepend_rot(g3ATrans t,g3Vec rnorm,g3Float ang) |
143 |
144 |
g3ATrans rt; |
145 |
146 |
147 |
g3at_comb(t,rt); |
148 |
149 |
150 |
void g3at_btrans(g3ATrans t,g3Vec xv,g3Vec yv,g3Vec zv) |
151 |
152 |
int i; |
153 |
154 |
155 |
for(i=0;i<3;i++) { |
156 |
t[i][0] = xv[i]; |
157 |
t[i][1] = yv[i]; |
158 |
t[i][2] = zv[i]; |
159 |
160 |
161 |
162 |
int g3at_inverse(g3ATrans t) |
163 |
164 |
g3Float v[] = {0,0,0,0}; |
165 |
166 |
if (!nr_gaussj(t,v)) { |
167 |
fprintf(stderr,"g3at_inverse: singular matrix\n"); |
168 |
return 0; |
169 |
170 |
return 1; |
171 |
172 |
173 |
void g3at_apply_h(g3ATrans t,g3AVec v) |
174 |
175 |
int i,j; |
176 |
g3AVec vt; |
177 |
178 |
g3av_copy(vt,v); |
179 |
g3av_copy(v,g3av_zero); |
180 |
for(i=0;i<4;i++) |
181 |
for(j=0;j<4;j++) |
182 |
v[i] += t[i][j]*vt[j]; |
183 |
g3av_tonorm(v); |
184 |
185 |
186 |
void g3av_print(g3AVec vh,FILE* outf) |
187 |
188 |
int i; |
189 |
190 |
for(i=0;i<4;i++) |
191 |
fprintf(outf,"%f ",vh[i]); |
192 |
193 |
194 |
void g3at_apply(g3ATrans t,g3Vec v) |
195 |
196 |
g3AVec res; |
197 |
198 |
g3av_vectohom(res,v); |
199 |
g3at_apply_h(t,res); |
200 |
g3v_set(v,res[0],res[1],res[2]); |
201 |
202 |
203 |
void g3at_iapply(g3Vec v,g3ATrans t) |
204 |
205 |
g3AVec res; |
206 |
207 |
g3av_copy(res,v); |
208 |
g3at_iapply_h(res,t); |
209 |
210 |
211 |
212 |
void g3at_iapply_h(g3Vec v,g3ATrans t) |
213 |
214 |
int i,j; |
215 |
g3AVec vt; |
216 |
217 |
g3av_copy(vt,v); |
218 |
219 |
for(i=0;i<4;i++) |
220 |
for(j=0;j<4;j++) |
221 |
v[i] += t[j][i]*vt[j]; |
222 |
g3av_tonorm(v); |
223 |
224 |
225 |
void g3at_comb(g3ATrans t,g3ATrans tf) |
226 |
227 |
g3ATrans res; |
228 |
229 |
g3at_comb_to(res,t,tf); |
230 |
g3at_copy(t,res); |
231 |
232 |
233 |
void g3at_comb_to(g3ATrans res,g3ATrans t,g3ATrans tf) |
234 |
235 |
int i,j,k; |
236 |
g3ATrans temp; |
237 |
g3at_copy(temp,g3at_zero); |
238 |
for(i=0;i<4;i++) |
239 |
for(j=0;j<4;j++) |
240 |
for(k=0;k<4;k++) |
241 |
temp[i][j] += t[i][k]*tf[k][j]; |
242 |
g3at_copy(res,temp); |
243 |
244 |
245 |
246 |
void g3av_vectohom(g3AVec res,g3Vec v) |
247 |
248 |
int i; |
249 |
250 |
for(i=0;i<3;i++) |
251 |
res[i] = v[i]; |
252 |
res[3] = 1.0; |
253 |
254 |
255 |
void g3av_homtovec(g3Vec res,g3AVec h) |
256 |
257 |
int i; |
258 |
259 |
g3av_tonorm(h); |
260 |
for(i=0;i<3;i++) |
261 |
res[i] = h[i]; |
262 |
263 |
264 |
int g3av_tonorm(g3AVec v) |
265 |
266 |
int i; |
267 |
268 |
if (gb_epseq(v[3],0.0)) |
269 |
return 0; |
270 |
for(i=0;i<3;i++) |
271 |
v[i] /= v[3]; |
272 |
v[3] = 1.0; |
273 |
return 1; |
274 |
275 |
276 |
void g3av_copy(g3AVec v,g3AVec vsrc) |
277 |
278 |
int i; |
279 |
280 |
for(i=0;i<4;i++) |
281 |
v[i] = vsrc[i]; |
282 |
283 |
284 |
void g3at_print(g3ATrans t,FILE* outf) |
285 |
286 |
int i,j; |
287 |
288 |
for(i=0;i<4;i++) { |
289 |
for(j=0;j<4;j++) |
290 |
fprintf(outf,"%f ",t[i][j]); |
291 |
fprintf(outf,"\n"); |
292 |
293 |
294 |
295 |
void g3at_copy(g3ATrans t,g3ATrans tsrc) |
296 |
297 |
int i,j; |
298 |
299 |
for(i=0;i<4;i++) |
300 |
for(j=0;j<4;j++) |
301 |
t[i][j] = tsrc[i][j]; |
302 |
303 |
304 |
int g3at_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup) |
305 |
306 |
g3Vec x,y,z; |
307 |
308 |
x = g3v_create(); |
309 |
y = g3v_create(); |
310 |
z = g3v_create(); |
311 |
g3v_copy(z,vdir); |
312 |
g3v_copy(x,vup); |
313 |
g3v_normalize(z); |
314 |
g3v_normalize(x); |
315 |
g3v_cross(y,z,x); |
316 |
if (!g3v_normalize(y)) { |
317 |
fprintf(stderr,"g3at_sph_ctrans: parallel\n"); |
318 |
g3v_free(x); |
319 |
g3v_free(y); |
320 |
g3v_free(z); |
321 |
return 0; |
322 |
323 |
g3v_cross(x,y,z); |
324 |
if (!g3v_normalize(x)) { |
325 |
326 |
g3v_free(x); |
327 |
g3v_free(y); |
328 |
g3v_free(z); |
329 |
return 0; |
330 |
331 |
g3at_btrans(t,x,y,z); |
332 |
g3v_free(x); |
333 |
g3v_free(y); |
334 |
g3v_free(z); |
335 |
return 1; |
336 |
337 |
338 |
int g3at_sph_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup) |
339 |
340 |
g3Vec x,z; |
341 |
int res; |
342 |
343 |
x = g3v_create(); |
344 |
z = g3v_create(); |
345 |
g3v_copy(z,vdir); |
346 |
g3v_copy(x,vup); |
347 |
z[G3S_RAD] = x[G3S_RAD] = 1.0; |
348 |
g3s_sphtocc(x,x); |
349 |
g3s_sphtocc(z,z); |
350 |
res = g3at_ctrans(t,z,x); |
351 |
g3v_free(x); |
352 |
g3v_free(z); |
353 |
354 |
return res; |
355 |
356 |
357 |
#ifdef GL_CONVERSIONS |
358 |
void g3at_get_openGL(g3ATrans t,GLdouble* glm) |
359 |
360 |
int r,c; |
361 |
362 |
for(r=0;r<4;r++) |
363 |
for(c=0;c<4;c++) |
364 |
glm[c+(r*4)] = t[c][r]; |
365 |
366 |
367 |
void g3at_from_openGL(g3ATrans t,GLdouble* glm) |
368 |
369 |
int r,c; |
370 |
371 |
for(r=0;r<4;r++) |
372 |
for(c=0;c<4;c++) |
373 |
t[c][r] = glm[c+(r*4)]; |
374 |
375 |
#endif |
376 |
377 |
#ifdef G3AFFINETEST |
378 |
379 |
380 |
int main(int argc,char** argv) |
381 |
382 |
g3Vec v,iv,x,y,z; |
383 |
g3ATrans t,it; |
384 |
385 |
386 |
v = g3v_create(); |
387 |
iv = g3v_create(); |
388 |
x = g3v_create(); |
389 |
y = g3v_create(); |
390 |
z = g3v_create(); |
391 |
g3v_set(z,1,0,0); |
392 |
g3v_set(x,atof(argv[1]),atof(argv[2]),atof(argv[3])); |
393 |
//g3v_set(y,atof(argv[4]),atof(argv[5]),atof(argv[6])); |
394 |
//g3v_set(z,atof(argv[7]),atof(argv[8]),atof(argv[9])); |
395 |
g3at_tounit(t); |
396 |
g3at_rotate(t,z,DEG2RAD(-90)); |
397 |
g3v_set(z,0,0,1); |
398 |
g3at_rotate(it,z,DEG2RAD(180)); |
399 |
g3at_comb_to(t,it,t); |
400 |
g3at_apply(t,x); |
401 |
g3v_print(x,stdout); |
402 |
printf("\n"); |
403 |
//g3v_print(y,stdout); |
404 |
//printf("\n"); |
405 |
exit(19); |
406 |
g3v_set(z,1,DEG2RAD(atof(argv[1])),DEG2RAD(atof(argv[2]))); |
407 |
g3v_set(x,1,DEG2RAD(atof(argv[3])),DEG2RAD(atof(argv[4]))); |
408 |
g3at_sph_ctrans(t,z,x); |
409 |
g3at_copy(it,t); |
410 |
g3at_inverse(it); |
411 |
g3at_print(t,stderr); |
412 |
fprintf(stderr,"\n"); |
413 |
g3v_set(v,1,DEG2RAD(atof(argv[5])),DEG2RAD(atof(argv[6]))); |
414 |
g3s_sphtocc(v,v); |
415 |
g3v_copy(iv,v); |
416 |
g3at_apply(it,iv); |
417 |
g3at_apply(t,v); |
418 |
g3s_cctosph(v,v); |
419 |
g3s_cctosph(iv,iv); |
420 |
g3s_sphwrap(v); |
421 |
g3s_sphwrap(iv); |
422 |
fprintf(stderr,"tt %f %f\n",RAD2DEG(v[1]),RAD2DEG(v[2])); |
423 |
fprintf(stderr,"ise %f %f\n",RAD2DEG(iv[1]),RAD2DEG(iv[2])); |
424 |
return EXIT_SUCCESS; |
425 |
426 |
427 |
#endif |
