root/radiance/ray/src/common/g3affine.c
Revision: 2.2
Committed: Tue Aug 18 15:02:53 2015 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, HEAD
Changes since 2.1: +3 -0 lines
Error occurred while calculating annotation data.
Added RCCS id's to new source files (forgotten during initial check-in)
4 #include <stdio.h>
5 #include <stdlib.h>
6
7 #include "g3affine.h"
8 #include "gbasic.h"
9 #include "g3sphere.h"
10
11 static g3AVec g3av_zero = {0.0,0.0,0.0,0.0};
12
13 static g3ATrans g3at_unit = {{1.0,0.0,0.0,0.0},
14 {0.0,1.0,0.0,0.0},
15 {0.0,0.0,1.0,0.0},
16 {0.0,0.0,0.0,1.0}};
17
18 static g3ATrans g3at_zero = {{0.0,0.0,0.0,0.0},
19 {0.0,0.0,0.0,0.0},
20 {0.0,0.0,0.0,0.0},
21 {0.0,0.0,0.0,0.0}};
22
23 void g3at_tounit(g3ATrans t)
24 {
25 g3at_copy(t,g3at_unit);
26 }
27
28 static int nr_gaussj(g3Float a[4][4],g3Float b[4])
29 {
30 int *indxc,*indxr,*ipiv;
31 int i,icol,irow,j,k,l,ll;
32 g3Float big,dum,pivinv;
33
34 indxc = (int*) calloc(4,sizeof(int));
35 indxr = (int*) calloc(4,sizeof(int));
36 ipiv = (int*) calloc(4,sizeof(int));
37
38 icol = irow = 0;
39 for (j=0;j<4;j++)
40 ipiv[j]=0;
41 for (i=0;i<4;i++) {
42 big=0.0;
43 for (j=0;j<4;j++)
44 if (ipiv[j] != 1)
45 for (k=0;k<4;k++) {
46 if (ipiv[k] == 0) {
47 if (fabs(a[j][k]) >= big) {
48 big = fabs(a[j][k]);
49 irow = j;
50 icol = k;
51 }
52 } else if (ipiv[k] > 1) {
53 return 0;
54 }
55 }
56 ++(ipiv[icol]);
57 if (irow != icol) {
58 for (l=0;l<4;l++)
59 GB_SWAP(a[irow][l],a[icol][l])
60 GB_SWAP(b[irow],b[icol])
61 }
62 indxr[i] = irow;
63 indxc[i] = icol;
64 if (a[icol][icol] == 0.0)
65 return 0;
66 pivinv = 1.0/a[icol][icol];
67 a[icol][icol] = 1.0;
68 for (l=0;l<4;l++)
69 a[icol][l] *= pivinv;
70 b[icol] *= pivinv;
71 for (ll=0;ll<4;ll++) {
72 if (ll != icol) {
73 dum = a[ll][icol];
74 a[ll][icol] = 0.0;
75 for (l=0;l<4;l++)
76 a[ll][l] -= a[icol][l]*dum;
77 b[ll] -= b[icol]*dum;
78 }
79 }
80 }
81 for (l=3;l>=0;l--) {
82 if (indxr[l] != indxc[l])
83 for (k=0;k<4;k++)
84 GB_SWAP(a[k][indxr[l]],a[k][indxc[l]]);
85 }
86 free(ipiv);
87 free(indxr);
88 free(indxc);
89 return 1;
90 }
91
92 void g3at_translate(g3ATrans t,g3Vec tv)
93 {
94 int i;
95 g3at_copy(t,g3at_unit);
96 for(i=0;i<3;i++)
97 t[i][3] += tv[i];
98 }
99
100 void g3at_add_trans(g3ATrans t,g3Vec tv)
101 {
102 g3ATrans tt;
103
104 g3at_translate(tt,tv);
105 g3at_comb_to(t,tt,t);
106 }
107
108 void g3at_prepend_trans(g3ATrans t,g3Vec tv)
109 {
110 g3ATrans tt;
111
112 g3at_translate(tt,tv);
113 g3at_comb(t,tt);
114 }
115
116 void g3at_rotate(g3ATrans t,g3Vec rnorm,g3Float ang)
117 {
118 g3Vec axe;
119 int aid,i;
120
121 axe = g3v_create();
122 g3at_copy(t,g3at_unit);
123
124 for(aid=0;aid<3;aid++) {
125 g3v_zero(axe);
126 axe[aid] = 1.0;
127 g3v_rotate(axe,axe,rnorm,ang);
128 for(i=0;i<3;i++)
129 t[i][aid] = axe[i];
130 }
131 g3v_free(axe);
132 }
133
134 void g3at_add_rot(g3ATrans t,g3Vec rnorm,g3Float ang)
135 {
136 g3ATrans rt;
137
138 g3at_rotate(rt,rnorm,ang);
139 g3at_comb_to(t,rt,t);
140 }
141
142 void g3at_prepend_rot(g3ATrans t,g3Vec rnorm,g3Float ang)
143 {
144 g3ATrans rt;
145
146 g3at_rotate(rt,rnorm,ang);
147 g3at_comb(t,rt);
148 }
149
150 void g3at_btrans(g3ATrans t,g3Vec xv,g3Vec yv,g3Vec zv)
151 {
152 int i;
153
154 g3at_copy(t,g3at_unit);
155 for(i=0;i<3;i++) {
156 t[i][0] = xv[i];
157 t[i][1] = yv[i];
158 t[i][2] = zv[i];
159 }
160 }
161
162 int g3at_inverse(g3ATrans t)
163 {
164 g3Float v[] = {0,0,0,0};
165
166 if (!nr_gaussj(t,v)) {
167 fprintf(stderr,"g3at_inverse: singular matrix\n");
168 return 0;
169 }
170 return 1;
171 }
172
173 void g3at_apply_h(g3ATrans t,g3AVec v)
174 {
175 int i,j;
176 g3AVec vt;
177
178 g3av_copy(vt,v);
179 g3av_copy(v,g3av_zero);
180 for(i=0;i<4;i++)
181 for(j=0;j<4;j++)
182 v[i] += t[i][j]*vt[j];
183 g3av_tonorm(v);
184 }
185
186 void g3av_print(g3AVec vh,FILE* outf)
187 {
188 int i;
189
190 for(i=0;i<4;i++)
191 fprintf(outf,"%f ",vh[i]);
192 }
193
194 void g3at_apply(g3ATrans t,g3Vec v)
195 {
196 g3AVec res;
197
198 g3av_vectohom(res,v);
199 g3at_apply_h(t,res);
200 g3v_set(v,res[0],res[1],res[2]);
201 }
202
203 void g3at_iapply(g3Vec v,g3ATrans t)
204 {
205 g3AVec res;
206
207 g3av_copy(res,v);
208 g3at_iapply_h(res,t);
209 g3v_set(v,res[0],res[1],res[2]);
210 }
211
212 void g3at_iapply_h(g3Vec v,g3ATrans t)
213 {
214 int i,j;
215 g3AVec vt;
216
217 g3av_copy(vt,v);
218 g3av_copy(v,g3av_zero);
219 for(i=0;i<4;i++)
220 for(j=0;j<4;j++)
221 v[i] += t[j][i]*vt[j];
222 g3av_tonorm(v);
223 }
224
225 void g3at_comb(g3ATrans t,g3ATrans tf)
226 {
227 g3ATrans res;
228
229 g3at_comb_to(res,t,tf);
230 g3at_copy(t,res);
231 }
232
233 void g3at_comb_to(g3ATrans res,g3ATrans t,g3ATrans tf)
234 {
235 int i,j,k;
236 g3ATrans temp;
237 g3at_copy(temp,g3at_zero);
238 for(i=0;i<4;i++)
239 for(j=0;j<4;j++)
240 for(k=0;k<4;k++)
241 temp[i][j] += t[i][k]*tf[k][j];
242 g3at_copy(res,temp);
243 }
244
245
246 void g3av_vectohom(g3AVec res,g3Vec v)
247 {
248 int i;
249
250 for(i=0;i<3;i++)
251 res[i] = v[i];
252 res[3] = 1.0;
253 }
254
255 void g3av_homtovec(g3Vec res,g3AVec h)
256 {
257 int i;
258
259 g3av_tonorm(h);
260 for(i=0;i<3;i++)
261 res[i] = h[i];
262 }
263
264 int g3av_tonorm(g3AVec v)
265 {
266 int i;
267
268 if (gb_epseq(v[3],0.0))
269 return 0;
270 for(i=0;i<3;i++)
271 v[i] /= v[3];
272 v[3] = 1.0;
273 return 1;
274 }
275
276 void g3av_copy(g3AVec v,g3AVec vsrc)
277 {
278 int i;
279
280 for(i=0;i<4;i++)
281 v[i] = vsrc[i];
282 }
283
284 void g3at_print(g3ATrans t,FILE* outf)
285 {
286 int i,j;
287
288 for(i=0;i<4;i++) {
289 for(j=0;j<4;j++)
290 fprintf(outf,"%f ",t[i][j]);
291 fprintf(outf,"\n");
292 }
293 }
294
295 void g3at_copy(g3ATrans t,g3ATrans tsrc)
296 {
297 int i,j;
298
299 for(i=0;i<4;i++)
300 for(j=0;j<4;j++)
301 t[i][j] = tsrc[i][j];
302 }
303
304 int g3at_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup)
305 {
306 g3Vec x,y,z;
307
308 x = g3v_create();
309 y = g3v_create();
310 z = g3v_create();
311 g3v_copy(z,vdir);
312 g3v_copy(x,vup);
313 g3v_normalize(z);
314 g3v_normalize(x);
315 g3v_cross(y,z,x);
316 if (!g3v_normalize(y)) {
317 fprintf(stderr,"g3at_sph_ctrans: parallel\n");
318 g3v_free(x);
319 g3v_free(y);
320 g3v_free(z);
321 return 0;
322 }
323 g3v_cross(x,y,z);
324 if (!g3v_normalize(x)) {
325 fprintf(stderr,"g3at_sph_ctrans: parallel\n");
326 g3v_free(x);
327 g3v_free(y);
328 g3v_free(z);
329 return 0;
330 }
331 g3at_btrans(t,x,y,z);
332 g3v_free(x);
333 g3v_free(y);
334 g3v_free(z);
335 return 1;
336 }
337
338 int g3at_sph_ctrans(g3ATrans t,g3Vec vdir,g3Vec vup)
339 {
340 g3Vec x,z;
341 int res;
342
343 x = g3v_create();
344 z = g3v_create();
345 g3v_copy(z,vdir);
346 g3v_copy(x,vup);
347 z[G3S_RAD] = x[G3S_RAD] = 1.0;
348 g3s_sphtocc(x,x);
349 g3s_sphtocc(z,z);
350 res = g3at_ctrans(t,z,x);
351 g3v_free(x);
352 g3v_free(z);
353
354 return res;
355 }
356
357 #ifdef GL_CONVERSIONS
358 void g3at_get_openGL(g3ATrans t,GLdouble* glm)
359 {
360 int r,c;
361
362 for(r=0;r<4;r++)
363 for(c=0;c<4;c++)
364 glm[c+(r*4)] = t[c][r];
365 }
366
367 void g3at_from_openGL(g3ATrans t,GLdouble* glm)
368 {
369 int r,c;
370
371 for(r=0;r<4;r++)
372 for(c=0;c<4;c++)
373 t[c][r] = glm[c+(r*4)];
374 }
375 #endif
376
377 #ifdef G3AFFINETEST
378
379
380 int main(int argc,char** argv)
381 {
382 g3Vec v,iv,x,y,z;
383 g3ATrans t,it;
384
385 g3at_copy(t,g3at_unit);
386 v = g3v_create();
387 iv = g3v_create();
388 x = g3v_create();
389 y = g3v_create();
390 z = g3v_create();
391 g3v_set(z,1,0,0);
392 g3v_set(x,atof(argv[1]),atof(argv[2]),atof(argv[3]));
393 //g3v_set(y,atof(argv[4]),atof(argv[5]),atof(argv[6]));
394 //g3v_set(z,atof(argv[7]),atof(argv[8]),atof(argv[9]));
395 g3at_tounit(t);
396 g3at_rotate(t,z,DEG2RAD(-90));
397 g3v_set(z,0,0,1);
398 g3at_rotate(it,z,DEG2RAD(180));
399 g3at_comb_to(t,it,t);
400 g3at_apply(t,x);
401 g3v_print(x,stdout);
402 printf("\n");
403 //g3v_print(y,stdout);
404 //printf("\n");
405 exit(19);
406 g3v_set(z,1,DEG2RAD(atof(argv[1])),DEG2RAD(atof(argv[2])));
407 g3v_set(x,1,DEG2RAD(atof(argv[3])),DEG2RAD(atof(argv[4])));
408 g3at_sph_ctrans(t,z,x);
409 g3at_copy(it,t);
410 g3at_inverse(it);
411 g3at_print(t,stderr);
412 fprintf(stderr,"\n");
413 g3v_set(v,1,DEG2RAD(atof(argv[5])),DEG2RAD(atof(argv[6])));
414 g3s_sphtocc(v,v);
415 g3v_copy(iv,v);
416 g3at_apply(it,iv);
417 g3at_apply(t,v);
418 g3s_cctosph(v,v);
419 g3s_cctosph(iv,iv);
420 g3s_sphwrap(v);
421 g3s_sphwrap(iv);
422 fprintf(stderr,"tt %f %f\n",RAD2DEG(v[1]),RAD2DEG(v[2]));
423 fprintf(stderr,"ise %f %f\n",RAD2DEG(iv[1]),RAD2DEG(iv[2]));
424 return EXIT_SUCCESS;
425 }
426
427 #endif
