root/radiance/ray/src/common/fvect.h
Revision: 2.21
Committed: Fri Jul 23 17:54:47 2021 UTC (4 years ago) by greg
fix: repaired incorrect equality tests
1 /* RCSid $Id: fvect.h,v 2.20 2021/04/09 17:37:47 greg Exp $ */
2 /*
3 * Declarations for floating-point vector operations.
4 */
5 #ifndef _RAD_FVECT_H_
6 #define _RAD_FVECT_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #ifdef SMLFLT
12 #define RREAL float
13 #define FTINY (1e-3)
14 #define FVFORMAT "%f %f %f"
15 #else
16 #define RREAL double
17 #define FTINY (1e-6)
18 #define FVFORMAT "%lf %lf %lf"
19 #endif
20 #define FHUGE (1e10)
21
22 #define FABSEQ(x1,x2) (fabs((x1)-(x2)) <= FTINY)
23 #define FRELEQ(x1,x2) (fabs((x1)-(x2)) <= FTINY*0.5*(fabs(x1)+fabs(x2)))
24
25 #define VABSEQ(v,w) (FABSEQ((v)[0],(w)[0]) && FABSEQ((v)[1],(w)[1]) \
26 && FABSEQ((v)[2],(w)[2]))
27 #define VRELEQ(v,w) (FRELEQ((v)[0],(w)[0]) && FRELEQ((v)[1],(w)[1]) \
28 && FRELEQ((v)[2],(w)[2]))
29
30 typedef RREAL FVECT[3];
31
32 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
33 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
34 #define VLEN(v) sqrt(DOT(v,v))
35 #define VADD(vr,v1,v2) ((vr)[0]=(v1)[0]+(v2)[0], \
36 (vr)[1]=(v1)[1]+(v2)[1], \
37 (vr)[2]=(v1)[2]+(v2)[2])
38 #define VSUB(vr,v1,v2) ((vr)[0]=(v1)[0]-(v2)[0], \
39 (vr)[1]=(v1)[1]-(v2)[1], \
40 (vr)[2]=(v1)[2]-(v2)[2])
41 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
42 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
43 (vr)[2]=(v1)[2]+(f)*(v2)[2])
44 #define VLERP(vr,v1,a,v2) ((vr)[0]=(1.-(a))*(v1)[0]+(a)*(v2)[0], \
45 (vr)[1]=(1.-(a))*(v1)[1]+(a)*(v2)[1], \
46 (vr)[2]=(1.-(a))*(v1)[2]+(a)*(v2)[2])
47 #define VCROSS(vr,v1,v2) \
48 ((vr)[0]=(v1)[1]*(v2)[2]-(v1)[2]*(v2)[1], \
49 (vr)[1]=(v1)[2]*(v2)[0]-(v1)[0]*(v2)[2], \
50 (vr)[2]=(v1)[0]*(v2)[1]-(v1)[1]*(v2)[0])
51
52 #define GEOD_RAD 0 /* geodesic distance specified in radians */
53 #define GEOD_ABS 1 /* absolute geodesic distance */
54 #define GEOD_REL 2 /* relative geodesic distance */
55
56 extern double Acos(double x);
57 extern double Asin(double x);
58 extern double fdot(const FVECT v1, const FVECT v2);
59 extern double dist2(const FVECT v1, const FVECT v2);
60 extern double dist2line(const FVECT p, const FVECT ep1, const FVECT ep2);
61 extern double dist2lseg(const FVECT p, const FVECT ep1, const FVECT ep2);
62 extern void fcross(FVECT vres, const FVECT v1, const FVECT v2);
63 extern void fvsum(FVECT vres, const FVECT v0, const FVECT v1, double f);
64 extern double normalize(FVECT v);
65 extern int getperpendicular(FVECT vp, const FVECT v, int randomize);
66 extern int closestapproach(RREAL t[2],
67 const FVECT rorg0, const FVECT rdir0,
68 const FVECT rorg1, const FVECT rdir1);
69 extern void spinvector(FVECT vres, const FVECT vorig,
70 const FVECT vnorm, double theta);
71 extern double geodesic(FVECT vres, const FVECT vorig,
72 const FVECT vtarg, double t, int meas);
73 #ifdef __cplusplus
74 }
75 #endif
76 #endif /* _RAD_FVECT_H_ */
77
