root/radiance/ray/src/common/fvect.h
Tue Sep 16 06:30:20 2003 UTC (21 years, 8 months ago) by greg
Changes since 2.11: +3 -1 lines
Wrote closestapproach() function to find closest point for two rays
Fri Jun 27 06:53:21 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.10: +1 -3 lines
Thu Jun 26 00:58:09 2003 UTC (21 years, 11 months ago) by schorsch
Fri Jun 6 16:38:47 2003 UTC (22 years ago) by schorsch
Changes since 2.8: +11 -7 lines
*** empty log message ***
Tue Feb 25 02:47:21 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +76 -2 lines
Wed Aug 12 17:56:51 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 2.5: +12 -2 lines
added VSUB(), VADD() and VCROSS() macros
Wed Oct 22 14:15:47 1997 UTC (27 years, 7 months ago) by gregl
added VLEN(v) macro for vector magnitude
Fri Oct 2 15:54:57 1992 UTC (32 years, 8 months ago) by greg
Thu Jul 9 15:34:29 1992 UTC (32 years, 11 months ago) by greg
changed FTINY for SMLFLT
Fri Jan 17 13:27:49 1992 UTC (33 years, 4 months ago) by greg
increased value of FTINY with SMLFLT
Tue Nov 12 16:54:16 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.3
Wed Oct 23 13:43:07 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.2: +4 -3 lines
Diff to previous 1.2
Wed Oct 23 12:19:23 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.1: +12 -1 lines
Diff to previous 1.1
added FLOAT definition for vectors and matrices
Thu Feb 2 10:34:16 1989 UTC (36 years, 4 months ago) by greg
